> Related links
Check out our User Interface Code Repository Files or visit the LabVIEW Wiki User Interface Portal
Tags
> How to hide/show task bar at windows Bar ?
Cool-LV
post Apr 11 2006, 10:09 AM
Post #1
Member
Using LabVIEW Since:2003
LV:8.5 ,8.2.1 ,7.1
China United States United Kingdom
Anybody knows how to hide/show application's task bar at windows bar ? thanks in advance smile.gif
Best Regards!
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Aitor Solar
post Apr 11 2006, 12:13 PM
Post #2
Member
Using LabVIEW Since:2000
LV:8.5 ,8.20 ,7.1.1
Spain spn_Madrid Nothing Selected
IIRC, when a front panel has both "allow user to resize window" and "allow user to minimize window" options disabled, it has no taskbar button (maybe the same happens if its modal, I don't remember). If you want to get rid of the LabVIEW taskbar button too, use "HideRootWindow=True" in the application .ini file.
To have the taskbar button back, just change those options dinamically through a VI Server call (FP.Resizeable and FP.Minimizeable).
Hope that helps
Tags
+Quote Post
FLX
post Apr 11 2006, 07:04 PM
Post #3
Member
LV:7.1 ,8.0 ,7.0
ger_bavaria Nothing Selected Nothing Selected
QUOTE (Aitor Solar @ Apr 11 2006, 02:13 PM) *
If I remember correctly, only the minimize window option is responsible for a visible task bar button.
alex
This post has been edited by FLX: Apr 11 2006, 07:07 PM
Tags
+Quote Post
Cool-LV
post Apr 12 2006, 06:30 AM
Post #4
Member
LV:8.5 ,8.2.1 ,7.1
QUOTE (FLX @ Apr 11 2006, 07:04 PM) *
alex
Thanks all, I already know how to hide root window bar, but I want to hide both of them, root window bar and main window bar, disable "allow user to resize window" and "allow user to minimize window" options can hide applications task bar ? I don't think so. en, would you kindly help to make a simple sample for me ?
Best Regards!
Tags
+Quote Post
rolfk
post Apr 12 2006, 07:31 AM
Post #5
<customize this text>
Premium Member
Using LabVIEW Since:1992
LV:8.5.1 ,8.2.1 ,7.1.1
Netherlands Switzerland Nothing Selected
QUOTE (Cool-LV @ Apr 12 2006, 01:30 AM) *
But it is the case! The Windows extended properties for a window determine if the window will have a taskbar button or not. And I do not see why you couldn't make this test yourself. It is really simple and asking for a ready made example sounds a little like a HH (homwork hustler).
Rolf Kalbermatter
Tags
+Quote Post
Cool-LV
post Apr 12 2006, 08:31 AM
Post #6
Member
LV:8.5 ,8.2.1 ,7.1
QUOTE (rolfk @ Apr 12 2006, 07:31 AM) *
Rolf Kalbermatter
rolfk.
I have tested, and made it yet, that I cann't achieve that function which I mentioned, before call this help. mention again, my hide bar is my program's task bar ! see enclosed
QUOTE (Cool-LV @ Apr 12 2006, 08:13 AM) *
rolfk.
Sorry all, Yes it can, as disable "allow user to resize window" and "allow user to minimize window" options can hide task bar, sad.gif I don't know why couldn't just now. maybe I missed to disable "allow user to minimize window" options biggrin.gif
Attached image(s)
Best Regards!
Tags
+Quote Post
Aitor Solar
post Apr 12 2006, 08:47 AM
Post #7
Member
LV:8.5 ,8.20 ,7.1.1
Here you have an example, it works.
Saludos,
Aitor
Attached File(s)
Tags
+Quote Post
Cool-LV
post Apr 12 2006, 09:17 AM
Post #8
Member
LV:8.5 ,8.2.1 ,7.1
QUOTE (Aitor Solar @ Apr 12 2006, 08:47 AM) *
Saludos,
Aitor
thanks Aitor Solar,
See my sample, the vi can hide the task bar firstly running, as I press hide window, the bar is showing ? why ? cann't hide it again.
Attached File(s)
Best Regards!
Tags
+Quote Post
Aitor Solar
post Apr 12 2006, 09:31 AM
Post #9
Member
LV:8.5 ,8.20 ,7.1.1
QUOTE (Cool-LV @ Apr 12 2006, 11:17 AM) *
thanks Aitor Solar,
Not sure, but probably a minimized state prevents a VI being un-minimizeable, sounds logical. If you want to minimize and not to have a taskbutton (that is, the VI to dissapear from view), just use the "hidden" FP state, is much simpler.
Saludos,
Aitor
Tags
+Quote Post
Cool-LV
post Apr 13 2006, 12:36 AM
Post #10
Member
LV:8.5 ,8.2.1 ,7.1
QUOTE (Aitor Solar @ Apr 12 2006, 09:31 AM) *
Saludos,
Aitor
Aitor Solar,
Thanks for your reply, if LabVIEW prevents a VI being un-minimizeable, as open the block diagram, and run the VI the status is the same, Hidden FP ?
no, I want to show FP for user, and the FP hasn't title bar, menu bar, tool bar, just a pure FP, and no task bar. and I will use "System tray" to restore window status.
Best Regards!
Tags
+Quote Post
Time is now: 9th January 2009 - 01:56 AM
