Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags |
Jan 21 2007, 11:42 PM
Post
#1
Very Active Member Posts: 59 Joined: 1-June 06 Member No.: 5178 Using LabVIEW Since:2006 LV:7.0 ,7.0 ,.
File Name: RTM to ENUM File Submitter: BOBILLIER File Submitted: 18 Jan 2007 File Updated: 24 Feb 2007 File Category: LabVIEW Development Environment RTM to Enum V1.0.2 Copyright © 2007, ERIC BOBILLIER All rights reserved. ERIC BOBILLIER. Author: ERIC BOBILLIER eric.bobillier@rennes.inra.fr Ok for support Distribution: This code was downloaded from the LAVA Code Repository: http://forums.lavag.org/downloads.html Description: This Vi creat an enum control(orindicator or constant)from a RunTime Menu (.rtm files) data files. You can also choose from Tag or Name Data ,and select the destination of creation between clipboard or enum.Vi (place on desktop). I have add a second tool, call Enum to tree who show RTM data in tree control . Why This tool ? If to speed scripting :When you have creat the enum you can connect it to case structure and apply "creat case for all value" Test on Labview 7.0 and XP (for other OS you must modify the Desktop Path .Vi) For test: Look at readme.txt Uses the following OpenG packages: oglib_file-2.7-1 To get these OpenG packages use VIPM (http://jkisoft.com/vipm/) Support: If you have any problems with this code or want to suggest features: http://forums.lavag.org/CR-RTM-to-ENUM-t5931.html Change Log: 1.0.0: Initial release of the code. 1.0.1: ADD show label for constant 1.0.2 : Correct minor bug and Now the control and indicator is copy in frontpanel clipboard, and constant in diagram clipboard License: Creative Commons Attribution 2.5 License Click here to download this file
| Ad |
Post
| Time is now: 2nd December 2008 - 04:17 AM |
