Visit the LabVIEW Wiki Application Design & Architecture Portal
Tags |
Dec 27 2004, 07:01 AM
Post
#1
![]() More Active Member Posts: 35 Joined: 27-August 04 From: Baltimore, MD Member No.: 632 LV:7.1
I'm sure most people working on large applications have developed several methods for controlling many subVI's, and probably someone has had a similar application to mine. It seems there are several ways to do this, but before starting to implement it I'd like to know which option(s) other users think would be best.
I am acquiring data from a subset of the various instruments in our lab. For example, I'll often measure the I-V curve of a device, which involves using a current source and a nanovoltmeter. What makes this a challenge is that in our lab we have several different models of current sources, nanovoltemeters, and even some units that do both functions. Which instrument(s) I use depends on the type of sample I'll measure, as well as which instruments are currently free. Originally I had a whole slew of VI's written for the various combinations of equipment, but this is from before I learned the ways to dynamically control VI's (of which I'm still a novice, BTW). Similarly, these VI's have been used as subVI's in larger data acquisition programs, which I would re-wire each time to use the right equipment. Now I want to be able to select which current source and voltmeter I'll use from the master program, and have it dynamically choose the proper subroutines. To make things even more confusing, there are a variety of parameters to be adjusted on the equipment, such as analog filtering, digital filtering, range, triggering, buffering, etc. This has proven to be too many controls to put on the front panel, even for the subVI's to take the I-V data. And it varies too, for example some units don't have filters, some only have analog filters, etc. What I've considered was to dynamically add menu items on the main control panel, depending upon which instrumentation I would be using for that run. Each menu item would correspond to the exact piece of equipment I was using. I was then hoping to either add sub-menus for the various options that can be adjusted on that particular piece of equipment, or to have the menu item create a popup which would control the settings on that particular piece of equipment. I envision having some cluster on the main VI denote which instruments are being used, and correspondingly each instrument would have it's own specific cluster describing all of its settings. So - has anybody done anything like this before and can either suggest this way or a better way to control the instruments? I'm also not too sure how to capture the menu item events. I was thinking of using an event structure on the main VI to call a dedicated menu item processor VI, and I would register with that processor VI which subVI's to call depending on which piece of equipment is being used, etc. As far as I know this should all be possible, but I don't have much experience with this. Would using the VI server be a way to go? And/or would it be advisable to use globals to access things, or should I avoid them? Namely, when I change which equipment I'm using and the settings of that equipment, what is the best way to allow the other subVI's to access that information (presumably through the clusters)?
| Ad |
Post
Dec 27 2004, 05:28 PM
Post
#2
Very Active Member Posts: 66 Joined: 15-October 04 From: Braunschweig Member No.: 833 Using LabVIEW Since:1993 LV:8.5 ,8.2.1 ,7.1
QUOTE (jeffwass @ Dec 27 2004, 09:01 AM) I'm sure most people working on large applications have developed several methods for controlling many subVI's, and probably someone has had a similar application to mine. It seems there are several ways to do this, but before starting to implement it I'd like to know which option(s) other users think would be best. Originally I had a whole slew of VI's written for the various combinations of equipment, but this is from before I learned the ways to dynamically control VI's (of which I'm still a novice, BTW). Similarly, these VI's have been used as subVI's in larger data acquisition programs, which I would re-wire each time to use the right equipment. Now I want to be able to select which current source and voltmeter I'll use from the master program, and have it dynamically choose the proper subroutines. Sounds like a familiar scenario. I use an approach with plugins (instrument driver VIs loaded dynamically at run time). Each instrument is represented by ONE (driver) VI. Everything that the main.vi needs to access from this instrument has to go through this driver VI. The connector pane of the driver VI is always the same, for all instruments. One of the parameters to driver VI is a string, labeled 'ACTION'. The values of ACTION at run-time ar: INIT, CONFIG, TRIGGER, MEAS, SET, RESET. Within the VI there is a case structure with the corresponding action cases. For each instrument in our institute there is (or hopefully will be at some day) ONE such driver VI. In the main.vi a user can select from the available drivers the subset he needs. (Of course such a selection be stored in a config file for later retrieval). The selected drivers are loaded at runtime as plugins (as is e.g demostrated in \examples\viserver\plugins.llb). QUOTE (jeffwass @ Dec 27 2004, 09:01 AM) To make things even more confusing, there are a variety of parameters to be adjusted on the equipment, such as analog filtering, digital filtering, range, triggering, buffering, etc. This has proven to be too many controls to put on the front panel, even for the subVI's to take the I-V data. And it varies too, for example some units don't have filters, some only have analog filters, etc. The available parameters of a given instrument are stored in what I call 'informative controls' on the driver VI front panel (using the 'Make current values default' feature). The informative controls are not used on the connector pane or at any place on the block diagram. They are just read by the VI from the main hierarchy which loads the driver VI. That way the main knows everything about the intrument you want it to know. The momentary settings of an instrument can be changed with a pop-up dialog in the main hierarchy. Again, they are stored in a file to keep them between runs of main.vi QUOTE (jeffwass @ Dec 27 2004, 09:01 AM) Would using the VI server be a way to go? And/or would it be advisable to use globals to access things, or should I avoid them? Namely, when I change which equipment I'm using and the settings of that equipment, what is the best way to allow the other subVI's to access that information (presumably through the clusters)? I avoid globals as much as possible, only use them to make some general config information available throughout the main hierarchy. The plugin mechanism I use is wrapped into an object oriented framework that I developed with the old (freely available) version of the GOOP toolkit. This GOOP approach makes it possible to encapsulate the config information of a loaded driver plugin with the driver code itself. The GOOP appraoch allows for another nice feature: The destructor method of a driver VI object contains code which stores all the info in a file when the main.vi destroys all dynamically created objects before it terminates. The next time when main.vi is run it recreates all the previously used objects with the same status they had before, since the constructor method of the driver VI object recreates the object using the stored information. (One of the private data of the driver object is of course a reference to the actual instrument driver VI). In an earlier approach I also used to store the information collected during a measurement (the "measurement data") within the instrument object data space. That turned out to become slower and slower when the data size was large (> 10000 data per scan). I decided to use what is called a LabVIEW 2 style global (basically this is an 'intelligent' global which uses a VI with a shift register just for data storage). I actually implemented a storage heap mechanism and the instrument objects now only need to store a pointer to their data on the heap, not the data itself. That was fairly efficient. I know this may all sound rather complicated, but it works really well. We use this program now at many different places and there is no problem with quickly plugging in a new instrument if the driver VI for it is available. If it is not and needs to be written, it takes a bit longer, and of course there needs to be somebody who can write it. But that is not awfully difficult either (depends of course on the instrument's complexity). I attach a hardcopy of the main.vi, so you get an impression how it looks:
Dec 28 2004, 07:13 AM
Post
#3
QUOTE (ahlers01 @ Dec 27 2004, 12:28 PM) Sounds like a familiar scenario. I use an approach with plugins (instrument driver VIs loaded dynamically at run time). Each instrument is represented by ONE (driver) VI. Everything that the main.vi needs to access from this instrument has to go through this driver VI. The connector pane of the driver VI is always the same, for all instruments. That sounds pretty cool, I didn't really think to make a common driver plugin like that. That makes sense, especially in light of the SCPI syntax for many new GPIB devices. So for the CONFIG action, the main vi calls the driver plugin's specific popup routine? I was also thinking of keeping the state of the instrument, or perhaps different files for saving various commonly-used states. I also want a 'log' state where the relevent device operating parameters would be sent to a datafile associated with that particular data set from the main, such that 5 months down the line I can see exactly how the instruments were configured that day. Maybe even set it up such that the instrument states can all be fully recalled to duplicate specific datasets. QUOTE The available parameters of a given instrument are stored in what I call 'informative controls' on the driver VI front panel (using the 'Make current values default' feature). The informative controls are not used on the connector pane or at any place on the block diagram. So does the driver popup come over the main vi? And how do you capture the events to send the config command to the plugin, from an event loop or similar in main? I assume you build the menus dynamically. I'm pretty new to these topics, so I'm not sure how to best implement them in a large setting. Namely having subVI's stop or pause in the middle of their operation, from a control on the main VI. For example, due to changing a parameter or quitting the main vi.QUOTE The GOOP appraoch allows for another nice feature: The destructor method of a driver VI object contains code which stores all the info in a file when the main.vi destroys all dynamically created objects before it terminates. Yeah, that does sound pretty useful. Would it be that much harder to implement without GOOP, just using initializing and shut-down routines? I don't know GOOP yet (I do know OOP through Java), but between dynamic VI calls, VI server, event loops, using HDF files, and maybe Lua scripting through LabVIEW, I feel like I'm drowning in LabVIEW overload before getting involved with GOOP. So I'll try to go OOP-less at first.QUOTE I decided to use what is called a LabVIEW 2 style global (basically this is an 'intelligent' global which uses a VI with a shift register just for data storage). I actually implemented a storage heap mechanism and the instrument objects now only need to store a pointer to their data on the heap, not the data itself. That was fairly efficient. That sounds useful, I've read about those LabVIEW 2 globals and at first they just seemed bizarre to me, almost counter-intuitive. But I guess it works pretty well. So the way you implement that, then, is to have all your data stored through the uninitialized shift register, indexed in some manner, and when you want to extract it, you send a pointer to the proper index of the LV2 global to whichever subVI wants that data? That seems pretty sensible to me. Is there anything special you do for scripting the batch commands in that window? Ie, if you want to sweep magnetic field and record data, or another time you want to sweep pressure (if you can) and at each pressure sweep the magnetic field, can your program dynamically accomodate these two different data-taking methods? I want to implement things dynamically like that, and it gets really annoying to re-wire all the time. So I've been looking at LuaVIEW lately, which lets one call LabVIEW VI's from within a Lua script (Lua is a very elegant and small scripting language). What makes it great is that you can call the Lua script from LabVIEW, so you can have a text window on the main VI with a user-controlled script describing the batch operations, for example. Thanks for the response, it was pretty useful.
Dec 28 2004, 03:37 PM
Post
#4
QUOTE (jeffwass @ Dec 28 2004, 09:13 AM) That makes sense, especially in light of the SCPI syntax for many new GPIB devices. So for the CONFIG action, the main vi calls the driver plugin's specific popup routine? Actually, the driver VIs are meant to cover ANY type of instrument, not just GPIB. I have driver VIs for serial, USB instruments and some which just simulate an instrument (so I can do some testing of the main.vi without having any instrument connected. Look at the HTML Doc of a typical driver VI. It is a driver for a Agilent HF source. There is only code in the action case 'SET'. Everything that I want the driver to be capable of I have to program into the various cases. Here I just put code in the SET case. The good thing with my approach is that one can start with such a minimum of coding (and later add more if needed). The configuraton you mentioned is done from the main panel. The attached image shows the main panel when the user clicks on the button labeled 'Current I/nA': a pop-up dialog occurs and one can configure the instrument. (Actually the objects are what I call a 'Signal': a signal consists of an instrument, transformation rule (maybe you read e.g. a resistance, but its physical meaning is a temperature, so one needs a transformation), and some other onfi like name, unit etc.) In the displayed example there is not really a current meter shown, but a simulated instrument called 'Random'. It has 2 parameters, 'offset' and 'scale', but this could be anything for a real instrument, like e.g. sensitivity, filter, cut-off freq, time-constant, .... If YES is activated in the last column of the dialog table, the corresponding entry is saved in the metadata of the measurement file. QUOTE I was also thinking of keeping the state of the instrument, or perhaps different files for saving various commonly-used states. I also want a 'log' state where the relevent device operating parameters would be sent to a datafile associated with that particular data set from the main, such that 5 months down the line I can see exactly how the instruments were configured that day. Maybe even set it up such that the instrument states can all be fully recalled to duplicate specific datasets. That would be cool, my program does not yet allow this. Just as I said above, I can have those instrument settings which I consider as relevant stored in the measurement file's metadata.QUOTE So does the driver popup come over the main vi? And how do you capture the events to send the config command to the plugin, from an event loop or similar in main? I assume you build the menus dynamically. I'm pretty new to these topics, so I'm not sure how to best implement them in a large setting. Namely having subVI's stop or pause in the middle of their operation, from a control on the main VI. For example, due to changing a parameter or quitting the main vi. OK, this place is too short to describe in detail what my program does (It's size is ~ 280 VIs). See the link at the end of this post. I use menus only for configuration things (saving the status, assembling a new set of signals etc.). Things which are done seldom. Most of the user interaction is with the list of signals in the lower part of the main panel. The main.vi is always in one of three states: 1) running idle: user selects which measurement he wants to do next 2) user has opened a configuration pop-up dialog 3) a measurement is running: controls (except STOP button) are disabled, ongoing measurement is displayed in the graph panel. Updating of the graph is done by a separately running VI which peeks on the heap and displays (at low rep rate) what is new. QUOTE Would it be that much harder to implement without GOOP, just using initializing and shut-down routines? I should definitely be possible without GOOP, but for me it was of great help to use such a prestructured framework (..I am a pretty chaotic programmer. No fishing for compliments here, just plain truth)QUOTE Is there anything special you do for scripting the batch commands in that window? The batch capability is based on a minimal scripting language invented ad-hoc. It basically allows to make most user selections on the front panel also programatically (via the batch kob). Technically it was not too difficult to implement since my main.vi consists of an queue driven state machine. It does not matter if the queued actions come directly from the user or from a batch processor (which is just another state in the state machine). The batch language has only 8 different commands, but even they are difficult to remember, so I added a 'batchmaker' which programmatically creates a batch job for the most useful cases: e.g. measure I-V curves at 300 different gate voltages, repeat this at 20 different vales of B-field and so on.. Here you find the complete doc of Modulab One of the things that I might change in the future is the format of the stored data. I use a custom format which was defined a few years ago with some ideas (about connectivity to a selfmade database) which are now obsolete. I'm therefore very much interested in the thread on HDF format which you started in one of the forums.
Dec 29 2004, 07:39 AM
Post
#5
Active Member Posts: 20 Joined: 6-May 04 From: Italy Member No.: 395 LV:7.1
Hi, i'm working in a framework for instruments control.
You use the loader with vi server for calling the driver of instruments. I use this in advance but when i build the executable, the complex vi called by the loader, don't load correct (more errors appeare)... The secon way now i build a database from setting-storage results. The driver vi read a propery value from database, for example: Rs232 take from database value of baud rade,the communication port ecc. I think it's a hard to create but if the work is good is easy to plug a new instruments on the future (or edit an existent driver)..... --------------------
Dec 31 2004, 06:30 AM
Post
#6
QUOTE (nicB @ Dec 29 2004, 09:39 AM) You use the loader with vi server for calling the driver of instruments. I use this in advance but when i build the executable, the complex vi called by the loader, don't load correct (more errors appeare)... I do not experience any problems when I load the dynamic VIs into a built application (.exe file). The instrument drivers are not included in the .exe but are located, as regular LabVIEW VIs, in the filesystem. Important is that their location is made known to the .exe at runtime (and of course that they are in a runnable state). I use config files (.ini files) for this. Driver VIs which the user wants to make available to the bulit app are simply added to this config VI (which you can consider as a sort of primitive database) with a text editor. There is one slight drawback to this approach: when a new driver is written it usually needs some debugging to optimize it. In the LabVIEW Runtime environment (RTE) this is not possible. BUT you can also run the compiled main app in the RTE. Just rename main.exe to main.llb and open the llb's top level main.vi in the LabVIEW development environment. Then you can set breakpoints, probes etc. in the driver.vi (and its subVIs) which you developped. (The hierarchy of main.vi is of course still inaccessible to debugging since its BD was remved during the application build.)
Dec 31 2004, 07:54 AM
Post
#7
Well, in this days i've try to perform a database system, but the appplication don't work like plug in. I return in the loader system and slave vi's for the driver.... In effect i can use a vi panel to edit the ini file. But i have another question, when i build the executable i attach the dinamics vi in my application, the vi's wich have a dll or other parts joined don't work in the target PC's. I think to lock all subvi's and dll joined, to group in .llb, but how i call the top level vi from a llb? Can you give me a suggestion for this? Very thanks for your feedback Have a happy new year day Nicola This post has been edited by nicB: Dec 31 2004, 08:13 AM --------------------
Dec 31 2004, 02:42 PM
Post
#8
Instant Human, just add coffee Premium Member ![]() Posts: 889 Joined: 31-January 03 From: Waterford, CT USA Member No.: 45 Using LabVIEW Since:1992 LV:8.2.1 ,7.1 ,8.0.1
All of the functions above are part of one version of what is called a Test Executive (TE). Creating configurations, calling drivers, saving data, saving configs and scripts to be reused later.
There are two main models of TE: 1. The TE calls "Modules" or discrete Tests, each of which has a PASS/FAIL and may internally call one or dozens of drivers/instruments. This is the model favored by TestStand and the majority of TEs that have been built for the commercial market. 2. The TE calls individual drivers/instruments, returns the data which maybe logged, or evaluated by analysis plugins. This is the model favored by the Open Source Test Executive (OSTE) project some of us are working on. Of course, most TEs can be made to work with either model above, and only favor one type or the other. On the production floor, version 1 seems to predominate, but in the laboratory, during design, development and later debug, version 2 predominates due to the greater need for interactivity with the test and more flexible control of the instruments available. -------------------- ************************************************************* "Always listen to the experts, they'll tell you what can't be done, and why. Then go do it." ~The Notebooks of Lazarus Long (by Robert Heinlein) *************************************************************
Dec 31 2004, 05:26 PM
Post
#9
QUOTE (ahlers01 @ Dec 28 2004, 10:37 AM) Actually, the driver VIs are meant to cover ANY type of instrument, not just GPIB..<SNIP>.. The good thing with my approach is that one can start with such a minimum of coding (and later add more if needed). The configuraton you mentioned is done from the main panel. I've started working on my Test Executive as Michael called it, and I'm following a model similar to yours. Instead of using GOOP (I probably will want to use OpenGOOP in the future, but its documentation is too confusing for me now), I add two extra routines for the drivers - Construct and Destruct, to handle constructor and destructor functions. The instrument drivers open the driver VI by reference, and pass a function enum, as well as a main cluster, which contain refs to all the relevent information of the system. All items are strictly-typed (LabVIEW docs say I cannot pass strictly-typedef'd controls to a VI by reference, but it worked in 7.1). Regarding typedefs, my overall cluster is getting pretty complicated, and each time I put it on the front panel it takes up a huge space. For now I've gotten around this by hiding it on the front panel, but I'd like to make a "normal-sized" reference-like picture for it on the front panel, but I can't find any decent documentation on editing control appearances. Does anybody have a decent link to this? Another question regarding sending information. You mention three states, such as running idle, opening popus, etc. Do you run the risk of race conditions as you update information on the whole system state, or do you have specific read/write routines to access the overall system parameters? As I said previously, I have a strict typedef cluster, which contains a link to the main VI reference, the main VI's menubar (I searched through all the invoke and property methods I could find, and couldn't figure out how to get a ref to another VI's menubar), and so far a cluster with all the menu/driver/instrument information. I'm in the early stages, so I don't have actual data or files yet, but they will be added soon (data will be through indexing to a LV2 global). What I've been doing now is passing this overall cluster into and out of each function I call, kind of like error in/out. DOes this seem like a stupid thing to do? The vi's can get kind of annoying dealing with this, but I think it can help prevent race conditions, or maybe I'll need to either add non-reentrant subVI's to read/write from the cluster and/or use semaphores. My main isn't queue-driven, I basically have an event structure that captures all relevent front-panel events and process them. As I'm only in the starting stages, I don't know if this approach will be too limiting later on. Do you suggest using queued state machines? Or does the event structure help make it easier to work without those? IIRC, the event structure has queueing built into it? Of course the benefit of your approach is batching looks the same as user interactions. And I'm also not sure how the event structure will handle routines that will take a long time to run, Ie, if the main VI can respond to other events or not. QUOTE I'm therefore very much interested in the thread on HDF format which you started in one of the forums. I've made further progress on using HDF. The basic synopsis so far - it's a real pain in the arse to use so far, NI provides a few of the most-common lowest-level calls, and made a few slightly higher-level calls. NI also provided high-level methods for saving LabVIEW waveforms, which might be quite user friendly, but I don't have the need for them now. There are so many low-level calls of the HDF5 library, though, it can be pretty daunting. Two annoying things to deal with are the continuous usage of 64-bit integers (which they provide some VI's to convert either 32-or-less ints, floats, doubles, or 2 32-bit ints into), as well as the large number of typedef's in the HDF5 header file (which they provide another DLL to get a few of these values back). So while creating and writing data into simple HDF5 file can be done with only a handful of lines of C code, the corresponding LabVIEW Vi gets pretty complicated pretty quickly, with all the repeated calls to the 64-bit integer and typedef libraries. I've thought the NI approach isn't the easiest, and pretty soon I'll start making my own set of libraries built on top of the NI-provided libraries. I'd consider re-doing the whole thing, but dealing with re-creating the DLL's is too time-consuming for me now.
Dec 31 2004, 06:50 PM
Post
#10
QUOTE (jeffwass @ Dec 31 2004, 12:26 PM) Regarding typedefs, my overall cluster is getting pretty complicated, and each time I put it on the front panel it takes up a huge space. (data will be through indexing to a LV2 global). What I've been doing now is passing this overall cluster into and out of each function I call, kind of like error in/out. You might want to look at passing variants or arrays of variants. These are some nice tools in the OpenG Toolkit for working with them and converting between clusters, etc. QUOTE (jeffwass @ Dec 31 2004, 12:26 PM) My main isn't queue-driven, I basically have an event structure that captures all relevent front-panel events and process them. As I'm only in the starting stages, I don't know if this approach will be too limiting later on. Do you suggest using queued state machines ([QSM])? Or does the event structure help make it easier to work without those? You might want to look at using the event structure to drive a QSM in another loop. This is becoming pretty common nowadays. To make it slightly more flexible don't pass just strings in the queue, but a cluster of the command string and an array of variants that serves as sort of a polymorphic parameter list to the command string. This all takes a little more work, but pays off in a very flexible and extensible architecture. This post has been edited by Michael Ashe: Dec 31 2004, 06:52 PM -------------------- ************************************************************* "Always listen to the experts, they'll tell you what can't be done, and why. Then go do it." ~The Notebooks of Lazarus Long (by Robert Heinlein) *************************************************************
Dec 31 2004, 07:36 PM
Post
#11
QUOTE (Michael Ashe @ Dec 31 2004, 01:50 PM) You might want to look at using the event structure to drive a QSM in another loop. This is becoming pretty common nowadays. Michael, I'm not exactly sure what you are talking about here. Do you mean having the event structure push a message onto the QSM? |
