> Related links
Visit our LabVIEW Wiki Linux article
Tags
> LabVIEW and Puppy Linux, LabVIEW installes, but can't get RTE to install.
Bryan
post Jan 24 2008, 07:42 PM
Post #1
Member
Using LabVIEW Since:1999
LV:7.1 ,8.0 ,8.20
us_pennsylvania us_california us_virginia
Hello again. I know I've dropped off of the face of the planet for a while. Sorry about that.
I'm working on something for a project and have successfully been able to install LabVIEW 7.1 development environment for Linux on a machine running PuppyLinux 3.01. My only problem is that I can't get the RTE to work, although there were no reported errors when I installed it.
When I try to run my application from a command prompt, like
CODE
./myLinuxLabviewApp
. I get the following error:
CODE
Can't load LabVIEW runtime library /usr/lib/liblvrt.so.7.1  libLVMesaGL.so.3: cannot open shared object file: No such file or directory
The files are all there under the /usr/local/lib/LabVIEW-7.1 directory with symbolic links in the /usr/local/lib directory. I don't know enough about linux to find out where it's trying to look for this file.
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Bryan
post Jan 30 2008, 12:35 PM
Post #2
Member
LV:7.1 ,8.0 ,8.20
Well, just as an update, I was able to get the RTE to install and work by using the "ldconfig" command after I installed it to update the shared library links. However, my only problem now is figuring out how to create an image that includes the RTE.
Tags
+Quote Post
Time is now: 8th January 2009 - 01:51 AM
