Tags |
Jan 22 2008, 02:03 AM
Post
#1
Changing the world, one VI at a time. JKI ![]() Posts: 1692 Joined: 22-October 02 From: San Francisco, CA Member No.: 17 Using LabVIEW Since:1995 LV:8.2.1 ,8.5 ,7.1.1
My Blog
My Gallery
Do you find working with XML data in LabVIEW to be difficult? I sure do, and I've written an article about it here:What XML tools are you using to work with XML data? What tools do you wish you had?
[cross posted] --------------------
| Ad |
Post
Jan 22 2008, 05:01 AM
Post
#2
Very Active Member Posts: 163 Joined: 14-June 05 From: Seattle, WA Member No.: 2411 Using LabVIEW Since:1993 LV:8.5.1 ,8.20 ,7.1.1
I read your article. I agree that to the novice, using XML in LabVIEW is not easy. You do need to understand a lot about XML features, like the schema and namespaces. But it is not impossible and can be a very powerful tool for large and complex data driven applications.
Also, the best way to read and write XML from LabVIEW (in my opinion) is to use the MSXML .NET assemblies. I have tried the XML toolkit from NI as well and find it lacking compared to rolling my own with .NET calls. I am actually working on a presentation to our local LabVIEW user group about .net and using it to work with XML files. I use XML extensively in my LabVIEW applications, mainly as a universal script format to drive data driven portions of my application. I have tried many ways of parsing XML within LabVIEW. Given the tree nature of XML, my first method was to use recursion (via VI server) to walk an XML structure and then build a representation in a LabVIEW data structure. The first attempt used an array of clusters with elements to contain the node links and the data at the node. The second version used a Variant tree (via attributes) to construct the tree in the LabVIEW data space. This was a more natural representation of the data but was slow to access (due to the overhead of the variant attribute VIs, I suspect). This was before LVOOP. I understand there are better ways to represent tree structure in LabVIEW using the new OOP features but I have not explored that yet. Each of these methods required you to then translate the data into a LabVIEW structure (nested arrays of clusters) to make it usable (and the code readable) in the rest of the app. My current implementation is to parse the schema directly into a LabVIEW data structure consisting of arrays of clusters of arrays of clusters...etc... This is the fastest method so far and goes directly to a structure that can be used in the rest of your application. The downside of this approach is the structure of the schema is directly coded into the LabVIEW parsing VIs. So, if the schema changes, so must your code. For my applications this is usually not a big issue since we design schemas up front that are flexible for the design goal of the application. However, this certainly is not a good generic solution for LabVIEW and XML. I think the holy grail here is likely some sort of LVOOP implementation that can dynamically traverse an XML file and then build a representation in memory that is simple and clear to access in the rest of the application. Another approach is to use the .NET interfaces to interact with the XML file 'live' instead of preloading and parsing it into a LabVIEW structure. This may have advantages in some applications, but in my experience I have always wanted the data to be resident in memory and fast to access with standard LabVIEW array and cluster tools. One caveat with using .NET assemblies to access XML is the confounding documentation (or lack thereof) of how to do this. I have spent many an hour staring at MSDN pages trying to understand how to call or what to call to get the result I wanted. Also, there are some pitfalls to watch out for. For example, if you use the MSXML schema validation methods, you cannot simply close the reference to the XML reader when you are done. Instead you must call the CLOSE method in the XMLValidatingReader and the XMLReader before you close their references. If you don't then the OS will keep a file lock on the XML file until LabVIEW is closed. Once I complete my presentation I will try to remember to post the PowerPoint and VIs here for other to view. In the meantime, I would be happy to share my code with anyone who is interested. I also strongly recommend looking at the w3schools website (http://www.w3schools.com/xml/default.asp) to learn more about XML. Also, the best tool I have found for editing XML and creating schema is XMLSpy. It is not cheap, but it has paid for itself many times over on my projects. -John This post has been edited by jlokanis: Jan 22 2008, 05:04 AM -------------------- ---------
You mean you still use a keyboard to write your code? How quaint...
Jan 22 2008, 06:01 AM
Post
#3
![]() Very Active Member Posts: 147 Joined: 21-November 05 From: Amsterdam, the Netherlands Member No.: 3523 Using LabVIEW Since:2000 LV:8.5 ,7.1.1 ,.
yup, it's not easy.
I for one have been most comfortable with the MSXML activeX interface. Nevertheless, I'm currently using a virtual class defining (my most relevent) XML related methods and a couple of child classes which implement these methods. If I need a very safe-and-simple-backwardscompatible-etc routine, I use my LV-string based childclass which honestly can't do a lot; most of the time I use the ActiveX implementing childclass; and for some other projects the (presently rudementary) .NET implementing class. ps: since both the activeX and .Net stuff is "by-reference", I implemented this whole class hierarchy as "by-reference"
Jan 22 2008, 12:44 PM
Post
#4
Very Active Member Posts: 91 Joined: 7-March 07 From: Munich Member No.: 7932 Using LabVIEW Since:2001 LV:8.6 ,8.5.1 ,7.1.1
I think the holy grail here is likely some sort of LVOOP implementation that can dynamically traverse an XML file and then build a representation in memory that is simple and clear to access in the rest of the application. That's exactly what I would like to have! Sounds great, but I don't know where to start. -------------------- The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.
Isaac Asimov
Jan 22 2008, 01:11 PM
Post
#5
![]() Extremely Active Member Posts: 359 Joined: 6-February 07 From: Homburg/Germany Member No.: 7689 Using LabVIEW Since:2004 LV:8.5 ,8.0.1 ,.
My Gallery
I use LVs XML Flatten/Unflatten instead of Config File VIs, because it's very easy to use like Flatten/Unflatten binary string, but is readable by user like INI-file.
Jan 22 2008, 01:50 PM
Post
#6
![]() Very Active Member Posts: 51 Joined: 2-November 06 From: Montreal, Qc Member No.: 6703 Using LabVIEW Since:1997 LV:8.5.1 ,8.2.1 ,6.1
I use XML Flatten/Unflatten because it's fast and easy to implement. But we have to deal with the limitation of this method.
For more sophisticated design, we use MSXML. Then, it could be more difficult depend on your XML knowledge.
Jan 22 2008, 03:52 PM
Post
#7
Enough LAVA to be dangerous Member Posts: 4 Joined: 17-October 05 Member No.: 3256 LV:7.1.1
One of the options in the poll is LabXML, which is what I use. It inherently uses the MSXML parser, so I'm not sure which poll answer to choose in this case (went for LabXML).
The earlier comment regarding using .NET is interesting because I actually tried to use it and I found it to be abhorently slow, as compared to LabXML. I essentially duplicated the operations that were being performed in LabXML in reading an XML node, so as not to hard-code the schema, as mentioned in the post. I found that the same operation was an order of magnitude slower with the .NET XML interface.
Jan 22 2008, 04:58 PM
Post
#8
Very Active Member Posts: 78 Joined: 12-October 04 Member No.: 793 Using LabVIEW Since:2002 LV:8.2.1 ,7.1 ,6.0.2
Jim, I couldn't agree more.
From my experience, the internet toolkit XML vi's are hugely inconsistent in their interface and the native LabVIEW schema is brittle to the point of being useless. I ended up writing a private API based around the MSXML support for XPATH queries, but even it suffers from versioning problems on different machines. I will admit, I didn't investigate the LabXML interface too closely because of its dependency on yet another library (Gnome's libXML2). Joe Z.
Jan 22 2008, 09:19 PM
Post
#9
![]() Very Active Premium Member ![]() Posts: 119 Joined: 21-January 06 From: Leeds, UK Member No.: 3951 Using LabVIEW Since:1994 LV:8.5.1 ,8.6 ,8.2.1
One of the options in the poll is LabXML, which is what I use. It inherently uses the MSXML parser, so I'm not sure which poll answer to choose in this case (went for LabXML). Ummm, I thought the later versions of LabXML used libxml2 - the open source XML parser ? The earlier versions did use the MS XML parser though. It doesn't seem to have had active development for a couple of years - somehow I don't think that's because it's perfect already -------------------- Gavin Burnell
Lecturer and EPSRC Advanced Research Fellow School Physics and Astronomy University of Leeds, UK.
Jan 22 2008, 09:31 PM
Post
#10
I've come back for more. Member Posts: 2 Joined: 25-January 05 Member No.: 1441 Using LabVIEW Since:2001 LV:8.2.1 ,. ,.
I went down the "cluster of array of cluster of array of ... ... string" approach. It worked, but it was cumbersome.
Jan 23 2008, 01:07 AM
Post
#11
Enough LAVA to be dangerous Member Posts: 4 Joined: 18-May 05 Member No.: 2221 Using LabVIEW Since:1993 LV:8.20 ,. ,.
For writing XML files I wrote my own simple Flatten-to-XML VI, which works in a similar way to the OpenG Variant Config File tools. In fact, that is where I got the idea from.
It involves converting a cluster of strings (or cluster of cluster of strings, or array of cluster of strings) to a variant, which is fed to the VI, which then converts it to an XML string. It automatically converts the string names to the XML Tag names, and the string values to the XML element values. Cheers, Mark.
Jan 23 2008, 01:31 AM
Post
#12
My Blog
My Gallery
For writing XML files I wrote my own simple Flatten-to-XML VI, which works in a similar way to the OpenG Variant Config File tools. In fact, that is where I got the idea from. It involves converting a cluster of strings (or cluster of cluster of strings, or array of cluster of strings) to a variant, which is fed to the VI, which then converts it to an XML string. It automatically converts the string names to the XML Tag names, and the string values to the XML element values. Cheers, Mark. Bingo. --------------------
Jan 23 2008, 09:23 AM
Post
#13
Bingo. maybe, but reading from xml is still not trivial. and yes, the .NET thing is whoofully slow.
Jan 24 2008, 12:14 AM
Post
#14
