> Related links
Visit our LabVIEW Wiki Hardware Portal
Tags
> Increase Velocity, can't stop motor
zeus224
post Dec 21 2004, 05:24 PM
Post #1
Active
Member
LV:7.1.1
Brazil
THANKS SO MUCH DUDE ......NOW ITS VERY NICE.....IF YOU DONT BE TOO BUSY IF YOU WANT TAKE A LOOK IN ANOTHER PROJECT MY...I WANT LITTLE HELP...I DO A VI TO CONTROL A STEP MOTOR OK...AND THIS WORK FINE...BUT NOW I NEED INCREASY VELOCITY BUT I CANT STOP A MOTOR....WITH YOU WANT SEE MY VI...ILL PUT HE HERE...AND SORRY FOR MY ENGLISH...IM FROM BRZIL AND IM LEARN YOU LANGUAGE...OK SEE YOU
Attached File(s)
Attached File  Move_Motor_FrenteBack_Le_Torquimetro_completo_ronaldo1.vi ( 149.17K ) Number of downloads: 138
Attached File  Move_Motor_FrenteBack_Le_Torquimetro_completo_ronaldo1.vi ( 889.99K ) Number of downloads: 104
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
PJM_labview
post Dec 22 2004, 02:11 AM
Post #2
JKI
Using LabVIEW Since:1998
LV:8.5.1 ,8.6 ,8.2.1
United States France Nothing Selected My Blog
While I dont have an answer to your question, would you be so kind as to stop using caps when you are typing ? using capital letters "LIKE THIS" is considering shouting.
Thank you
PJM
Got VIPM?
JKI . VIPM . EasyXML . OpenG . LAVA . Builder . Blog
Tags
+Quote Post
zeus224
post Dec 22 2004, 04:53 PM
Post #3
Active
Member
LV:7.1.1
Brazil
sorry ....yes now i know.....
Tags
+Quote Post
xseadog
post Dec 23 2004, 10:50 AM
Post #4
Active
Member
LV:7.0
Denmark
QUOTE (zeus224 @ Dec 22 2004, 06:53 PM)
Its between Calender and RSS
Tags
+Quote Post
James McAnanama
post Jan 11 2005, 03:49 PM
Post #5
More Active
Member
LV:7.1
Nothing Selected
QUOTE (zeus224 @ Dec 21 2004, 12:24 PM)
Zeus,
If I understand correctly, you want to be able to send updates to your motor indexer without stopping & starting your program? What I think would help is to divide your program into multiple processes. One process would be responsible for motor communications, while another would be responsible for getting commands from a user interface. You could use a queue to pass messages between the different parts of your program. I have attached a trivial example where a que is used to update indicators on the screen. One process sends commands to update a binary counter, while another process responds to the user request to turn on and off a LED. A main process monitors the queue and reacts to new commands. Let me know if this helps, or let me know if your problem is different than I understand it to be.
Regards,
James
Attached File(s)
Tags
+Quote Post
zeus224
post Jan 11 2005, 04:12 PM
Post #6
Active
Member
LV:7.1.1
Brazil
Hi James all good with you? I looked at the example that you ordered me but not to understood as it can help me, what I am trying to make I am while the program wheel and I to want to increase the rotation of the stepmotor I I obtain without having that it program and to place a new speed and to twirl again, since now very thanks and forgives for my English
Tags
+Quote Post
James McAnanama
post Jan 12 2005, 03:17 PM
Post #7
More Active
Member
LV:7.1
Nothing Selected
QUOTE (zeus224 @ Jan 11 2005, 11:12 AM)
Sorry Zeus, I do not understand. You write in English far better than I could write in Portuguese or Spanish! However, your problem is still unclear to me. I do not understand the following:
"what I am trying to make I am while the program wheel and I to want to increase the rotation of the stepmotor I I obtain without having that it program and to place a new speed and to twirl again"
Can you reword the above statement (maybe I will be able to better understand).
Also, perhaps it would be better if I knew where you were having trouble. Are you having trouble with LabView, or are you having trouble with the 3540i board?
Tags
+Quote Post
Time is now: 22nd November 2008 - 11:03 AM
