Visit our LabVIEW Wiki Apple article
Dec 19 2007, 10:37 AM
Post
#1
Active Member Posts: 21 Joined: 21-March 06 From: Paris Member No.: 4507 Using LabVIEW Since:2004 LV:8.20 ,. ,.
Hello to you, leopards...
I posted a technical topic on ni.com (http://forums.ni.com/ni/board/message?board.id=170&message.id=291094) which explain a shared variable buffering problem. In this post I didn't discuss the OS depending issue to not worry windows-only users (not rare in ni forums !...). I get the chance to do it here in our small place of peace. What network protocols work on mac ? - PSP (shared variable) : Yes. I read that it's ok for read/write with datasocket VIs but that you can't deploy the Shared Variable Engine (SVE) on a mac (no deploy of the shared variable library). When needed, I thought I could deploy the library on a distant PC (the programmatic deploy method allow that. I didn't tested yet). You can't use the sharedvariable node but datasocket VIs allow to do the same. You also have access to a "wait" ability when reading data (get data only when an update is available). - DTSP : I think it doesn't, but I'm not sure. Perhaps the same limitations as PSP (read/write only ?) - TCP : yes but it doesn't have any buffering ability (I kno I could emulate something but it's long and hard work) Do you have information or experience using something for multiplatform network and buffered communication between executables ? Thanks Boris This post has been edited by tibobo: Dec 19 2007, 10:38 AM Tags
| Ad |
Post
Tags
Dec 19 2007, 02:13 PM
Post
#2
Hello
I have solved my shared variable buffering problem and posted the solution (in fact my error) on ni forum : http://forums.ni.com/ni/board/message?boar...mp=true#M291094 One solved problem, one :-) Boris Tags
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
1 | VDB | 1417 | 8th May 2004 - 01:45 AM Last post by: Michael_Aivaliotis |
1 | regisphilbin | 1243 | 22nd July 2005 - 09:15 PM Last post by: regisphilbin |
7 | klessm1 | 1903 | 14th October 2005 - 05:58 PM Last post by: klessm1 |
3 | atreding | 1659 | 2nd November 2005 - 08:36 PM Last post by: atreding |
| Time is now: 6th October 2008 - 01:57 PM |
