Check out our Database and File IO Code Repository Files or visit the LabVIEW Wiki Database and File IO articles.
Tags |
Dec 13 2004, 07:09 PM
Post
#1
3 more posts to go! Member Posts: 7 Joined: 13-December 04 Member No.: 1228 LV:6.1
I've been in the past able to read/write from Microsoft Access database.
Recently, I am trying to do the same with MySQL. I have read the PDF file from this website. I am having trouble with the basic of just using a SELECT * query. I want to see the data returned. I can't figure out how. Anyone who has done this?
| Ad |
Post
Dec 14 2004, 12:40 AM
Post
#2
![]() Confucius say: Crowded elevator always smell different to midget Admin ![]() Posts: 2363 Joined: 13-October 02 From: Planet Earth Member No.: 2 Using LabVIEW Since:1994 LV:8.5 ,8.2.1 ,7.1.1
My Blog
My Gallery
QUOTE (nyc10036 @ Dec 13 2004, 03:09 PM) What method are you using to communicate with your database? --------------------
Dec 14 2004, 12:46 PM
Post
#3
Active Member Posts: 17 Joined: 11-June 04 From: Netherlands Member No.: 459 Using LabVIEW Since:2008 LV:7.1 ,8.0.1 ,7.0
QUOTE (Michael_Aivaliotis @ Dec 13 2004, 07:40 PM) Hi, You should try creating a connection to the MySQL server using a DSN connection, this means you create a Data Source Name to your MySQL server that contains all the necessary connection information. You can create a DSN in every Windows based pc by opening the "ODBC Administrator" in your "control panel". If you name your DSN "LVMYSQL" than you can open a connection in LabVIEW by using. "DSN=LVMYSQL". If you are interested in a more easy way, consider upgrading to LabVIEW 7.0 or higher. We have created a Database Toolkit that allows you to easily connect to a database using Express VI technology, you can also create queries without having to know SQL. On of the most import features is the automatic creation of the appropriate clusters and arrays, this according to the retrieved information from the database. Conversion like varchar to string, and float to double are already created for you! Have a look at: http://www.tm-solutions.nl/eng/produkten/produkten.html T&M Database Wizard for LabVIEW If you have any other questions, please do ask! With kinds regards, Arnoud de Kuijper T&M Solutions BV
Dec 14 2004, 03:13 PM
Post
#4
QUOTE (Michael_Aivaliotis @ Dec 13 2004, 08:40 PM) I am using a DSN-less connection. I am attaching my VI. I do not get an error, but the RecordCount returns a -1.
Attached File(s)
Dec 15 2004, 10:30 AM
Post
#5
QUOTE (nyc10036 @ Dec 14 2004, 10:13 AM) I am using a DSN-less connection. I am attaching my VI. I do not get an error, but the RecordCount returns a -1. The attached VI show a correct connection code, but their are 2 options that could cause problems: 1) The Recordcount property is only usable when you can fully lock the recordset (set the correct locktype and cursurtype options). Otherwise the result always will be -1, but you do can read the records in the recordset! 2) This is the most likely problem: MySQL does not use an Cursor Location, you have the options: adUseNone, adUserClient, adUseServer. If you sets the Cursor Location before you open the recordset you do can retrieve the RecordCount Value. I have attached the new LV_mysql.vi with the new appropriate code, I do not have a MySQL server installed so I cannot test the code. If you are still experiencing problems, please do ask! Arnoud de Kuijper T&M Solutions BV T&M Database Wizard for LabVIEW!
Attached File(s)
Dec 16 2004, 03:33 PM
Post
#6
Arnoud,
thanks very much. setting the CursorLocation for the Recordset before opening is the key also, in LabVIEW 6.1, I found that if the Recordset has NULLs in any field, the Invoke Node -> GetRows will not work
| Time is now: 22nd November 2008 - 10:30 AM |
