Visit our LabVIEW Wiki Linux article
Tags |
Dec 10 2004, 07:28 PM
Post
#1
![]() Very Active Member Posts: 197 Joined: 12-May 04 From: Charlottesville, VA Member No.: 404 Using LabVIEW Since:1999 LV:7.1 ,8.0 ,8.20
We just finished installing LabVIEW 7.1 on Fedora 2 and 3 and came across an interesting issue that would allow us to install LabVIEW but not run it (the splash window would open, then pause, freeze and close).
Turns out that Fedora 2+ uses a filesystem convention that doesn't have "." and ".." as the first two directories. Apparently LabVIEW depends on this. To get LabVIEW to run on Fedora 2+ log in as "root" and execute the following code in your shell for all EXT3 partitions: CODE tune2fs -O ^dir_index /dev/(yourPartition) I'm running Fedora 2 installed on a USB hard drive with (2) EXT3 formatted partitions, so mine was: CODE tune2fs -O ^dir_index /dev/sda1 tune2fs -O ^dir_index /dev/sda2 You should be able to immediately run LabVIEW afterwards.
| Ad |
Post
Jul 6 2007, 10:46 PM
Post
#2
I've come back for more. Member Posts: 2 Joined: 13-February 07 Member No.: 7757 Using LabVIEW Since:2006 LV:7.1 ,8.20 ,.
Hello,
I am using fedora 7 and labview 7 and when i type the tune2fs command on the console it says command not found.The strange thing is that i found the manual for that command. Can you think any reason why is this happening. Many thanks in advance.
Jul 9 2007, 07:46 AM
Post
#3
Active Member Posts: 21 Joined: 10-June 04 From: Milano Member No.: 457 Using LabVIEW Since:2001 LV:8.2.1 ,8.0.1 ,7.1.1
Hello, I am using fedora 7 and labview 7 and when i type the tune2fs command on the console it says command not found.The strange thing is that i found the manual for that command. Can you think any reason why is this happening. Many thanks in advance. Are you sure you are logged in as "root"? You need to be superuser to use it... --- Osvaldo
Jul 9 2007, 02:06 PM
Post
#4
![]() Very Active V I Engineering, Inc. ![]() Posts: 131 Joined: 8-February 06 Member No.: 4078 Using LabVIEW Since:2002 LV:8.20 ,8.0 ,7.1
I am using fedora 7 and labview 7 and when i type the tune2fs command on the console it says command not found.The strange thing is that i found the manual for that command. Can you think any reason why is this happening. Many thanks in advance. tune2fs should be located in the /sbin folder -- Which you may not have located in your PATH variable. Try executing "/sbin/tune2fs" instead. (and as osvaldo mentioned, you'll need to be root)
Aug 12 2007, 02:59 PM
Post
#5
Many thanks for your reply,
Ive tried doing that and i recieved this message: [root@ip-81-23-61-82 christos]# /sbin/tune2fs -O ^dir_index /dev/sda3 tune2fs 1.39 (29-May-2006) /sbin/tune2fs: Bad magic number in super-block while trying to open /dev/sda3 Couldn't find valid filesystem superblock. But it was succesfull for the swap partition. Any ideas? Regards
| Time is now: 7th January 2009 - 11:14 PM |
