> Related links
Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags
> Broken code with no broken arrow., Strange bug?
Michael_Aivaliot...
post Nov 16 2007, 12:37 AM
Post #1
Group Icon
Admin
Using LabVIEW Since:1994
LV:8.5 ,8.2.1 ,7.1.1
Not sure what causes this but I've experienced this several times lately.
I run a toplevel VI several times and somewhere I get an error on the error cluster. So I decide to start debugging by opening up the subVI's. When I open one of the subVI's I notice that it has a broken run arrow and now I also notice that my toplevel VI has a broken run arrow. How is it possible for LabVIEW to run broken code? The only thing I can think of is that the broken code has not propogated to the current running application instance until I open it up. Not sure why however since I only have one instance. I have the project environment open too.
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
jdunham
post Nov 16 2007, 01:42 AM
Post #2
Member
LV:8.5 ,. ,.
United States us_california Nothing Selected
Do you have a conditional disable structure on the diagram or in a subvi? If you have changed the conditional symbol definition in your project, then the same VI could definitely be working inside the project but broken outside of it.
Tags
+Quote Post
Michael_Aivaliot...
post Nov 16 2007, 07:31 AM
Post #3
Group Icon
Admin
QUOTE (jdunham @ Nov 15 2007, 05:42 PM) *
No, it's not that.
Tags
+Quote Post
silmaril
post Nov 16 2007, 04:45 PM
Post #4
Member
Using LabVIEW Since:2001
LV:8.6 ,8.5.1 ,7.1.1
Germany ger_bavaria Nothing Selected
Did you try Ctrl-Shift-Run on your top level VI?
Was the run arrow still unbroken after this?
The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.
Isaac Asimov
Tags
+Quote Post
Michael_Aivaliot...
post Nov 22 2007, 01:34 AM
Post #5
Group Icon
Admin
Well, it happened again. Check this out. There's a broken wire on the diagram but the arrow's intact.
Attached thumbnail(s)
Tags
+Quote Post
Val Brown
post Nov 22 2007, 03:07 AM
Post #6
Member
Using LabVIEW Since:1998
LV:8.6 ,8.5.1 ,8.2.1
Canada United States Nothing Selected
Are you working in XP or Vista?
The power of NeuroCARETM
Tags
+Quote Post
Michael_Aivaliot...
post Aug 20 2008, 06:15 AM
Post #7
Group Icon
Admin
Here's a video that shows how you can have a broken VI on the diagram of a non-broken VI. No I'm not using a disable structure. If I click on the run arrow of the caller it breaks and shows the error list. The arrow then stays broken.
Attached File(s)
Tags
+Quote Post
Aristos Queue
post Aug 20 2008, 06:42 AM
Post #8
LV R&D Envoy
NI
Using LabVIEW Since:2000
LV:8.5.1 ,. ,.
United States Nothing Selected Nothing Selected My Gallery
You have filed a CAR, right?
"A VI outside a class is a gun without a safety. Data outside a class is a target."
--- A message from LabVOOP R&D
Tags
+Quote Post
neB
post Aug 20 2008, 12:36 PM
Post #9
Certified Kool-Aid Kid
Premium Member
LV:7.1 ,. ,.
United States Germany Nothing Selected
QUOTE (Aristos Queue @ Aug 20 2008, 02:42 AM) *
Have you ever tried to file a CAr without being able to reproduce the issue on demand?
I have seen a couple of those myself, also working LabVIEW 8.5. I'm not using globals so if its the same bug I have seen it is not due them. THe other observation that I can add is that a really fuzzy general type observation. I would swear (if pressed) that code changes are not propagating to all of the VI's that are not open. I say this because I work with a tree.VI open and after amking changes (but before running) I save everything (from tree.vi save all) then close the tree.vi. Backup then re-open and test the code. WHen closing the tree.vi, I see VI's that want to be saved. As a result I ahve resorted to an old habit of opening and closing the tree a couple of times to make sure all of the changes get propogated.
Just reporting what I have ben seing.
Ben
Tags
+Quote Post
hfettig
post Aug 20 2008, 03:27 PM
Post #10
Premium Member
LV:8.6 ,8.5.1 ,.
Canada Germany Nothing Selected
Hey Mike,
I think I found your Broken Arrow. Somehow it found its way into my VI. tongue.gif
I seem to be experiencing the opposite of your problem. I have a broken arrow and 0 errors and warnings listed in the error list. wacko.gif
Cheers,
Heiko
Tags
+Quote Post
Michael_Aivaliot...
post Aug 22 2008, 08:14 AM
Post #11
Group Icon
Admin
QUOTE (neB @ Aug 20 2008, 05:36 AM) *
I agree. Reporting this to NI is a futile exercise. Not reproducible at all.
Ben, there's a thread for this issue here.
Tags
+Quote Post
Time is now: 22nd November 2008 - 10:46 AM
