Visit our LabVIEW Wiki MINDSTORMS® NXT article
Nov 15 2007, 03:32 AM
Post
#1
Enough LAVA to be dangerous Member Posts: 4 Joined: 15-November 06 Member No.: 6852 Using LabVIEW Since:1993 LV:7.1.1 ,8.0.1 ,8.20
Interesting discussions (here and ni week keynote presenter) recently regarding advanced programming of NXT. Too bad LabVIEW is not perceived as a serious contender.
Tags
| Ad |
Post
Tags
Nov 15 2007, 04:32 AM
Post
#2
![]() Confucius say, Man with tight trousers is pressing his luck. Admin ![]() Posts: 2323 Joined: 13-October 02 From: Planet Earth Member No.: 2 Using LabVIEW Since:1994 LV:8.5 ,8.2.1 ,7.1.1
My Blog
My Gallery
I also mentioned this on my blog post.
-------------------- Tags
Nov 15 2007, 07:44 AM
Post
#3
Drawing Tool - LVOOP example application Premium Member ![]() Posts: 1161 Joined: 29-January 06 From: Helsinki Member No.: 4014 Using LabVIEW Since:2004 LV:8.5.1 ,8.2.1 ,7.1.1
My Blog
Perhaps NI didn't pay much enough
Tomi -------------------- Tags
Nov 15 2007, 12:43 PM
Post
#4
![]() LV R&D Envoy NI ![]() Posts: 1197 Joined: 15-August 06 From: Austin, TX Member No.: 5877 Using LabVIEW Since:2000 LV:8.5.1 ,. ,.
My Gallery
Interesting discussions (here and ni week keynote presenter) recently regarding advanced programming of NXT. Too bad LabVIEW is not perceived as a serious contender. Any opinions the author has were pretty much discredited in my book by this statement: (Aside: as I was re-teaching myself how to program in C, I was reminded about the funny logic of computers. -100 is > than -90. Is this true in all languages?) What the...?! No, negative 100 is not greater than negative 90 in C. -------------------- "A VI outside a class is a gun without a safety. Data outside a class is a target."
--- A message from LabVOOP R&D Tags
Nov 15 2007, 01:07 PM
Post
#5
Extremely Active Member Posts: 363 Joined: 24-August 06 Member No.: 5958 Using LabVIEW Since:1995 LV:8.5 ,8.2.1 ,7.1.1
What the...?! No, negative 100 is not greater than negative 90 in C. Maybe in MS Windows /J -------------------- Wired but not weird...
Tags
Nov 15 2007, 01:08 PM
Post
#6
![]() CCT It Premium Member ![]() Posts: 1290 Joined: 13-June 05 From: Woerden, Netherlands Member No.: 2399 Using LabVIEW Since:2001 LV:8.5.1 ,6.1 ,8.2.1
My Blog
My Gallery
Any opinions the author has were pretty much discredited in my book by this statement: (Aside: as I was re-teaching myself how to program in C, I was reminded about the funny logic of computers. -100 is > than -90. Is this true in all languages?) What the...?! No, negative 100 is not greater than negative 90 in C. The discussion revealed that the compiler of NXT took a vector approach in this case and the radius of -100 is > -90. The numbers describe motor speed and the sign is the direction of the movement. Ton -------------------- Tags
Nov 15 2007, 05:03 PM
Post
#7
Any opinions the author has were pretty much discredited in my book by this statement: (Aside: as I was re-teaching myself how to program in C, I was reminded about the funny logic of computers. -100 is > than -90. Is this true in all languages?) What the...?! No, negative 100 is not greater than negative 90 in C. I think discrediting his opinions based on that statement is a mistake. Both articles I referenced communicate what I've observered in the NXT world many times, once you move into discussions about advanced programming of the NXT, LabVIEW rarely even enters the discussion. If the kids using NXT-G today get transitioned into using something like RobotC for more advanced programming tasks, it will be a shame. And right now, I think that is quite likely. I also mentioned this on my blog post. Which I've belatedly added to my RSS reader, based on its most awesome content! Tags
Nov 15 2007, 05:06 PM
Post
#8
Extremely Active Member Posts: 358 Joined: 26-March 06 From: Victoria, BC Canada Member No.: 4568 Using LabVIEW Since:1998 LV:8.6 ,8.5.1 ,8.2.1
Of course it is the completely uninformed and rather parochial OPINION of that author that relegates LabVIEW to the "backburner".
-------------------- The power of NeuroCARETM
Tags
Nov 15 2007, 05:50 PM
Post
#9
Extremely Active Member Posts: 541 Joined: 13-September 05 From: Cary, NC USA Member No.: 2992 Using LabVIEW Since:1997 LV:8.5 ,8.2.1 ,7.1.1
I'm going to play a bit of devil's advocate on this one. I read the geek dad posting via the link from Michael's blog, but I didn't exactly get the impression that Chris Anderson "hates" graphical programming.
Here's sort of the relevant part to me: QUOTE "if...then...else", "while", even "for...next" -- you won't know how much you actually like those constructs until you don't have them. For anyone who's ever programmed, there's nothing better for understanding programming logic than properly tabbed and commented code, all in a column of text as God intended. And for your kids, there's no time like the present to introduce real programming, using coding conventions that will be as relevant in the decades to come as they were in decades past. The only statement I truly take issue with there is where he says "there's nothing better for understanding programming logic than properly tabbed and commented code, all in a column of text as God intended." While I find that statement both laughably inaccurate and dripping with bias, it sounds to me like he's not specifically dissing graphical programming in general, but rather lamenting the limitations of NXT-G. It's disappointing, though, that his solution to the problem was to run back to the warm, calming embrace of his beloved plaintext source files -------------------- If you don't like this post, you might also not like my widgets!
Tags
Nov 15 2007, 07:45 PM
Post
#10
Of course it is the completely uninformed and rather parochial OPINION of that author that relegates LabVIEW to the "backburner". Yes it is his opinion, but it shared by many in the NXT world. Look at the other link I listed, same message, different delivery. [snip]...I didn't exactly get the impression that Chris Anderson "hates" graphical programming....[snip] I agree. I thought NXT-G would naturally lead the NXT community towards LabVIEW. I don't think that so much anymore. Time will tell. Tags
Nov 15 2007, 09:13 PM
Post
#11
Yes it is his opinion, but it shared by many in the NXT world. Look at the other link I listed, same message, different delivery. I agree. I thought NXT-G would naturally lead the NXT community towards LabVIEW. I don't think that so much anymore. Time will tell. Unfortunately bias and prejudice usually "points the way" instead of information. After all, if that weren't the case, we'd all be using Dworak keyboards instead of QWERTY. -------------------- The power of NeuroCARETM
Tags
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
0 | denisetucker | 1745 | 11th May 2004 - 02:18 PM Last post by: denisetucker |
0 | Bryan | 1854 | 13th May 2004 - 03:34 PM Last post by: Bryan |
0 | websid | 1957 | 31st May 2004 - 10:29 AM Last post by: websid |
0 | Peter_22 | 957 | 28th July 2004 - 11:25 AM Last post by: Peter_22 |
| Time is now: 12th October 2008 - 08:37 AM |
