> Related links
Visit our LabVIEW Wiki LabVIEW Embedded Portal
Tags
> Batch compile for FPGA?
DaveKielpinski
post Nov 14 2007, 09:35 AM
Post #1
More Active
Member
Using LabVIEW Since:2006
LV:8.2.1 ,. ,.
Australia Nothing Selected Nothing Selected
Dear all,
I have an FPGA VI with many subVIs in my project. I would like to compile the entire project at once, but I can't seem to find a way to do this. So right now I have to pull up 30+ subVIs individually and compile them at the rate of about one every 20 minutes, which is really inconvenient.
Is there any way to do a batch compile of my project?
Thanks,
Dave Kielpinski
(cross-posted to NI forums)
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Götz Becker
post Nov 14 2007, 08:17 PM
Post #2
Member
Using LabVIEW Since:2005
LV:8.5 ,8.2.1 ,7.1.1
Germany ger_baden ger_bavaria
QUOTE (DaveKielpinski @ Nov 14 2007, 10:35 AM) *
As far as I know (last time I touched LV-FPGA was in 7.1.1), compiling subVIs of a FPGA-MainVI doesn´t help. Since the result of a subvi compiled separatly would always output a bitstream for the whole FPGA. The same intermediate HDL-Code from the subvi will normally end up different, when its implicitly compiled as part of the mainVI to a bitstream, due to timing and size constraints require other/more optimizations at low level. I don´t think there is a way to incrementally compile HDL-code below RTL
Tags
+Quote Post
DaveKielpinski
post Nov 15 2007, 10:19 AM
Post #3
More Active
Member
LV:8.2.1 ,. ,.
QUOTE (Götz Becker @ Nov 15 2007, 06:17 AM) *
Actually, you are perfectly right. The bug I am trying to track down is not related to improper compiling - unfortunately!
Thanks,
Dave
Tags
+Quote Post
Time is now: 22nd November 2008 - 09:02 AM
