Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags |
Nov 8 2007, 06:01 PM
Post
#1
![]() CCT It Premium Member ![]() Posts: 1331 Joined: 13-June 05 From: Woerden, Netherlands Member No.: 2399 Using LabVIEW Since:2001 LV:8.5.1 ,6.1 ,8.2.1
My Blog
My Gallery
File Name: Code Capture Tool File Submitter: Ton File Submitted: 7 Nov 2007 File Updated: 8 Jul 2008 File Category: LabVIEW Development Environment Code Capture Tool Readme This tool can be used to get shots of LabVIEW code or GUIs and store them on disk or the OS clipboard. It resides on the Tools menu and inside the user.lib palette. The palette provides access to a full API for capturing specific parts of code and/or GUI of VIs. Installation instructions Upon downloading the zip file extract it to the folder of your choice and open the Install Code Capture Tool.vi file. This will launch the installer. After finishing the install wizard a LabVIEW restart is necessary to load the VI into the Tools menu and the user.lib palette. Contact The Code Capture Tool is finished by Ton Plomp and Yair Neeman. Thank yous can be expressed to the NI Forums community, bugs and comments on the LAVA community. Usage Open the Code Capture Tool via the 'Tools' menu A lot of information is shown in the about screen. A comprehensive explanation of the API and GUI is given on the LabVIEW Wiki page on this item Uninstalling To remove the Code Capture Tool from your LabVIEW installation remove the following files in your LabVIEW folder: ProjectCode Capture Tool.vi user.libCCT.mnu And the following folder: user.lib_Code Capture Tool In your LabVIEW data folder (On windows normally: My documentsLabVIEW Data) is a file called Code Capture Tool.ini, this can be removed at any moment The latest version is 1.0.0, later edits on this page shift the date of release. License This code is covered under the BSD license, parts are covered by the GNU LGPL. Further information about licensing and acknowledgements can be found in the about screen of the Code Capture Tool. LabVIEW is a trademark of National Instruments Click here to download this file --------------------
| Ad |
Post
Nov 8 2007, 06:16 PM
Post
#2
![]() Extwemely Active Premium Member ![]() Posts: 1621 Joined: 23-January 05 From: Here Member No.: 1431 Using LabVIEW Since:2003 LV:8.6 ,7.0 ,.
Please note that the main use case for this (and the reason it was originally written) is for online use - you can write a quick example and then have an image of it and have the path to that image in the clipboard, so that you just need to paste it in the attachment field.
-------------------- More than meets the eye...
Nov 8 2007, 06:47 PM
Post
#3
![]() Confucius say: Crowded elevator always smell different to midget Admin ![]() Posts: 2363 Joined: 13-October 02 From: Planet Earth Member No.: 2 Using LabVIEW Since:1994 LV:8.5 ,8.2.1 ,7.1.1
My Blog
My Gallery
Thank you tcplomp and Yen for chosing the LAVA CR for your distribution mechanism. I haven't had the chance to look at this yet. I've actually created my own tool that does something similar. I'll provide feedback when I can. Thanks again.
Nov 8 2007, 06:52 PM
Post
#4
![]() Extremely Active Member Posts: 359 Joined: 6-February 07 From: Homburg/Germany Member No.: 7689 Using LabVIEW Since:2004 LV:8.5 ,8.0.1 ,.
My Gallery
Sorry, can anybody say me why not to use Ctrl+A to select all objects on BD or FP than Ctrl+C to copy to cliboard, then open Paint and use Ctrl+V to put the screenshot from clipboard to Paint? Otherwise Alt+Print to copy the Active Window only?
Is this Code Capture Tool much better? What are the advantages? Eugen This post has been edited by Eugen Graf: Nov 8 2007, 06:59 PM --------------------
Nov 8 2007, 07:00 PM
Post
#5
My Blog
My Gallery
Sorry, can anybody say me why not to use Ctrl+A, then open Paint and use Ctrl+V ? Otherwise Alt+Print? Eugen Well it:
Nov 8 2007, 07:16 PM
Post
#6
A couple of additions to what Ton said:
Also, please note that this is version 0.9.x. The API might still change based on feedback we'll get. -------------------- More than meets the eye...
Nov 8 2007, 07:42 PM
Post
#7
![]() Extremely Active Premium Member ![]() Posts: 588 Joined: 8-December 03 From: Dallas, Texas Member No.: 208 Using LabVIEW Since:2000 LV:8.6 ,8.2.1 ,7.1.1
My Gallery
I think you should all look into the Jing Project
http://screencast.com/t/zHuOjFTAk8g -------------------- Norman J. Kirchner Jr.
Automation Software Engineer ~,~ The Captain Was Here Premium Blend ![]()
Nov 8 2007, 07:52 PM
Post
#8
My Blog
My Gallery
I think you should all look into the Jing Project http://screencast.com/t/zHuOjFTAk8g Impressive! Now I know where to make an instruction video for the Code Capture Tool Ton --------------------
Jul 14 2008, 08:39 PM
Post
#9
![]() Extremely Active Premium Member ![]() Posts: 259 Joined: 18-January 08 From: Montréal, Canada Member No.: 10515 Using LabVIEW Since:2000 LV:8.6 ,8.5 ,.
The CodeCapture tool is really impressive and useful. I like the simplicity of it.
Sure will simplify my use of LAVA! For future upgrades, I would suggest also adding an optional capture of the Project Explorer hierarchy... I didn't find any Private methods for "Project: Get Scaled Image"... I wonder if it's easily accessible?
Jul 14 2008, 09:27 PM
Post
#10
![]() Very Active Member Posts: 93 Joined: 11-October 07 From: Tarboro, NC Member No.: 9577 Using LabVIEW Since:2001 LV:7.1 ,. ,.
Is this Code Capture Tool much better? What are the advantages? Eugen I have a program called MWSnap that is easy to use for screen captures, so I had ignored previous postings for the CCT until today. I can without reservation say that it is by far the best way to post images of LabVIEW code and FPs. It is a unitasker in that it only works in LV, but it does it's "unitask" superbly. Thanks again to Ton and Yair. -------------------- Jim
Jul 15 2008, 03:03 PM
Post
#11
I didn't find any Private methods for "Project: Get Scaled Image"... I wonder if it's easily accessible? I don't see why it should be. It makes sense to export the diagram as an image, but it doesn't really make sense to explore the project window as an image. The workarounds I can think of are capturing the image of the window (OS specific and doesn't take scrolling and collapsed elements into account) or using scripting to read the data in the project window and construct a graphical representation of it (assuming the data is even available). Neither sounds like a great option. P.S. Thanks, Jim. Great quotes, both here and in the NI forums. -------------------- More than meets the eye...
Jul 15 2008, 03:46 PM
Post
#12
I don't see why it should be. It makes sense to export the diagram as an image, but it doesn't really make sense to explore the project window as an image. I thought it could be useful for educational purposes (showing project hierarchy as png). But you're right, I was not surprised not to find such a method. Through private methods, we can access the list of VI's in the hierarchy and that's all a programmer really needs I guess. thanks and congrats,
Jul 16 2008, 08:06 AM
Post
#13
<customize this text> Premium Member ![]() Posts: 1001 Joined: 9-April 04 From: Rotterdam Member No.: 349 Using LabVIEW Since:1992 LV:8.5.1 ,8.2.1 ,7.1.1
The CodeCapture tool is really impressive and useful. I like the simplicity of it. Sure will simplify my use of LAVA! For future upgrades, I would suggest also adding an optional capture of the Project Explorer hierarchy... I didn't find any Private methods for "Project: Get Scaled Image"... I wonder if it's easily accessible? This wouldn't be very logical because the project window is not a LabVIEW control but a complete LabVIEW VI. So instead of creating a special method Project: Get Scaled Image method in the LabVIEW application hierarchy what you would need to do is get hold of the VI reference that the project window really is and then get the FP image from there. Of course this would c |
