Tags
> Labels on shiftregisters
Jeffrey Habets
post Nov 8 2007, 11:55 AM
Post #1
Premium Member
Using LabVIEW Since:1997
LV:8.20 ,8.0.1 ,7.1.1
Netherlands hol_limburg Netherlands Antilles
Hi guys,
I have the habit of always labeling my shiftregs on the left hand side of the loop they're on. I use free labels for that, but it would be nice if the labels where (optionaly) automatically created (like with objects on the FP). They would be attached to the shiftreg, moving with it when the shiftreg is moved up or down.
besides being a handy feature for myself, it would probably also encourage others who don't label their shiftregs now to do it anyway, because it would be the next logical (more or less forced) step after creating the register.
What do you guys think?
Greetings, Jeffrey
NI CLA & VIT
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Yair
post Nov 8 2007, 04:41 PM
Post #2
Extwemely Active
Premium Member
Using LabVIEW Since:2003
LV:7.0 ,7.1 ,.
Israel Nothing Selected Nothing Selected
Definitely a good idea. Sounds like a visit to NI's product suggestion center is in order.
To reduce the number of wires, you can also use a single cluster for all the data. See a recent discussion here.
More than meets the eye...
Tags
+Quote Post
Jeffrey Habets
post Nov 8 2007, 08:22 PM
Post #3
Premium Member
QUOTE (Yen @ Nov 8 2007, 05:41 PM) *
Yes of course.. But for simple (lv2-style) sub-vi's where you know not much will change later on, it's still convenient to just use a shift reg or two-three..
I'll enter it in the product suggestion center...
Greetings, Jeffrey
NI CLA & VIT
Tags
+Quote Post
shoneill
post Nov 8 2007, 09:06 PM
Post #4
Member
Using LabVIEW Since:2006
LV:8.2.1 ,8.20 ,6.1
Ireland Switzerland Nothing Selected
QUOTE (Jeffrey Habets @ Nov 8 2007, 12:55 PM) *
Hi guys,
Yup, sounds like good idea with solid reasoning.
I look forward to this in future versions......
Thanks
Shane.
Tags
+Quote Post
dthomson
post Nov 8 2007, 10:15 PM
Post #5
Member
Using LabVIEW Since:1993
LV:8.20 ,7.1 ,8.0.1
United States Nothing Selected Nothing Selected
QUOTE (Jeffrey Habets @ Nov 8 2007, 04:55 AM) *
Hi guys,
I think it's a great idea. I used to put it in the suggestion box about every version, but lately it slipped off my radar. I would also suggest built-in lables for Sequence-Locals. (Not that I would ever use a Sequence Local!) It seems obvious to me. NI pushes for programming standards, including good documentation, but this obvious feature remains missing.
Cheers,
Dave T.
David Thomson Original Code Consulting
www.originalcode.com
National Instruments Alliance Program Member
Certified LabVIEW Architect
Certified Instrument Driver Developer
Senior Scientist, Droplet Measurement Technologies
Boulder, Colorado
There are 10 kinds of people: those who understand binary,
and those who don't.
{{LabVIEW Champion}}
Tags
+Quote Post
BOBILLIER
post Nov 14 2007, 12:09 AM
Post #6
Member
LV:7.0 ,7.0 ,.
France Nothing Selected Nothing Selected
Hi
Today i have creat a small tool that can perhapse help you . This tool place a name in description attribut for wire that you before select on diagram.
First step:
Please place the "Give name to wire.vi" in your labview\project folder and restart labview.
Second step
Open Vi and select one Wire and make Tools\Give name to wire.vi
If all is correct, this Vi promt you for give name to this wire.
Last step
Place mouse in wire and show it name in contextual help.
Nota : have use CCT_Get User App Reference__CCT.vi part of the Code Capture Tool and is covered by the BSD license (see code reposary of lavag)
Eric
Attached File(s)
Tags
+Quote Post
Ton
post Nov 14 2007, 06:44 AM
Post #7
CCT It
Premium Member
Using LabVIEW Since:2001
LV:8.5.1 ,6.1 ,8.2.1
Netherlands hol_utrecht Nothing Selected My Blog My Gallery
QUOTE (BOBILLIER @ Nov 14 2007, 01:09 AM) *
Last step
Eric
One question, how is this faster than right click->description?
Ton
(good to see you use the CCT thumbup1.gif )
Certified LabVIEW Developer
Shouldn't you be programming a Code Repository solution?
Tags
+Quote Post
BOBILLIER
post Nov 14 2007, 09:05 AM
Post #8
Member
LV:7.0 ,7.0 ,.
QUOTE (tcplomp @ Nov 14 2007, 07:44 AM) *
Ton
oops.gif I forget that you can access to description with right clik. worshippy.gif
Tags
+Quote Post
gosor
post Jan 31 2008, 02:53 PM
Post #9
I want a LabVIEW icon under my name!
Member
Using LabVIEW Since:2000
LV:8.20 ,7.1 ,6.0
I agree, it would be usefull to add a comparable feature for local variables of stacked sequence .
Tags
+Quote Post
silmaril
post Jan 31 2008, 04:56 PM
Post #10
Member
LV:8.6 ,8.5.1 ,7.1.1
Germany ger_bavaria Nothing Selected
QUOTE (gosor @ Jan 31 2008, 03:53 PM) *
I don't agree with this latest addition.
There are virtually no reasons to use any stacked sequences in a well-designed LabVIEW application.
There are even fewer reasons to use sequence locals.
I don't think NI should invest any extra development time in a feature that only supports bad programming style.
Sorry for the harsh words, but I had to go through my share of stacked-sequence-applications, and I didn't find one stacked sequence which could not have been replaced using other features, like sub-VIs. In all cases, this would have improved readability of the code a lot!
The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.
Isaac Asimov
Tags
+Quote Post
crelf
post Jan 31 2008, 05:31 PM
Post #11
I'm a LAVA, not a fighter.
V I Engineering, Inc.
LV:8.5 ,. ,.
Australia United States Nothing Selected My Blog
QUOTE (silmaril @ Jan 31 2008, 11:56 AM) *
This is an arguement that we've had before, so let me cut to the chase: There are few reasons to use any stacked sequences in a well-designed LabVIEW application. Like all rules, there are exceptions. There are cases where you need to force dataflow where it doesn't currently exist, and encapsulating code in a subVI or a flat sequence structure can be equally appropriate. Like all programming paradigms, it's all about using the right tool for the job.
Tags
+Quote Post
Collapse
> Similar Topics
    Topic Title Replies Topic Starter Views Last Action
No New Posts   5 anton.lindner 1244 18th January 2005 - 01:31 PM
Last post by: anton.lindner
No New Posts   2 bekrul 899 21st March 2005 - 10:38 PM
Last post by: bekrul
No New Posts 10 Barrie 3188 27th July 2006 - 10:55 PM
Last post by: Ami
No New Posts   9 Phil Duncan 1223 24th May 2007 - 09:32 AM
Last post by: JFM
Time is now: 7th September 2008 - 07:05 PM
