Check out our XNodes Code Repository Files and visit our LabVIEW Wiki XNodes Portal
Tags |
Nov 7 2007, 03:47 PM
Post
#1
Drawing Tool - LVOOP example application Premium Member ![]() Posts: 1168 Joined: 29-January 06 From: Helsinki Member No.: 4014 Using LabVIEW Since:2004 LV:8.5.1 ,8.2.1 ,7.1.1
My Blog
I've developed some XNodes that I now want to add to functions palette. The problem is that I don't know how to define the palette icon for an XNode. If I add MyXNode.xnode to functions palette, then for some reason LabVIEW shows the icon of MyXNode.xnode:Help.vi and not the library icon. Has anybody succesfully defined the palette icon of the XNode? Tomi --------------------
| Ad |
Post
Nov 7 2007, 05:20 PM
Post
#2
![]() Extremely Active JKI ![]() Posts: 612 Joined: 19-June 03 From: Bay Area, CA (USA) Member No.: 121 Using LabVIEW Since:1998 LV:8.5.1 ,8.6 ,8.2.1
My Blog
I had the same problem.
By error and trial I figure out that you have to change the icon of the help ability and the palette will display it. Just to be safe I typically put the icon I want in both the XNode and in the Help ability. If you don't have a help ability I think you can use the initialize ability icon. PJM --------------------
Nov 7 2007, 06:26 PM
Post
#3
My Blog
By error and trial I figure out that you have to change the icon of the help ability and the palette will display it. Just to be safe I typically put the icon I want in both the XNode and in the Help ability. If you don't have a help ability I think you can use the initialize ability icon. Thanks Tomi --------------------
Nov 7 2007, 07:11 PM
Post
#4
My Blog
Cool
Nov 8 2007, 08:12 AM
Post
#5
![]() Extremely Active Member Posts: 262 Joined: 26-January 05 Member No.: 1450 Using LabVIEW Since:2000 LV:8.5 ,8.20 ,7.1.1
Has anybody succesfully defined the palette icon of the XNode? Yes, it's easy. Things go more or less like this:
Saludos, Aitor This post has been edited by Aitor Solar: Nov 8 2007, 08:13 AM
| Time is now: 22nd November 2008 - 07:26 AM |
