Tags
> Enable/Disable & Show/Hide Controls, VIs that disable, enable, hide, & show controls.
kbersch
post Oct 30 2007, 10:19 PM
Post #1
Enough LAVA to be dangerous
Member
Using LabVIEW Since:2001
LV:8.2.1 ,6.0.2 ,.
United States Nothing Selected Nothing Selected
I've had several VIs to hide and/or show and enable and/or disable controls and indicators on the front panel. After some discussion on Info-LabVIEW I cleaned them up and combined them. Here are two VIs. One will disable, disable & gray, or enable selected controls on the front panel of the VI it is used in. The other will hide or show (make invisible or visible) selected controls on the front panel of the VI it is used in. Documentation is on the front panel of these VIs as well as in the description of each control/indicator.Kelly Bersch[attachment=7451:Disable_...Controls.vi][attachment=7452:Hide_Show_Controls.vi]I should have included the fact that these VIs are for LabVIEW 8.2.Kelly
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Anders Björk
post Oct 31 2007, 09:57 AM
Post #2
Member
Using LabVIEW Since:1996
LV:8.5 ,7.1.1 ,8.0.1
Sweden Nothing Selected Nothing Selected
QUOTE (kbersch @ Oct 30 2007, 11:19 PM) *
Nice Work!
Tags
+Quote Post
kbersch
post Jul 11 2008, 05:57 PM
Post #3
Member
LV:8.2.1 ,6.0.2 ,.
I've updated my Show/Hide and Enable/Disable controls VIs so they recursively find control refnums. This allows them to now find controls in Tabs and Clusters. You will need to make sure no two clusters/tabs have identically named controls or this will affect all of them.
There are two more VIs along with these because they are used in the recursive search. They are modified versions of the "Get controls on tabs.vi" written by Dave A. Graybeal. All four VIs need to be in the same folder. These VIs were written with LabVIEW 8.5.1.
Attached File(s)
Attached File  Disable_Enable_Controls.vi ( 42.72K ) Number of downloads: 111
Tags
+Quote Post
JiMM
post Jul 11 2008, 06:53 PM
Post #4
Member
LV:7.1 ,. ,.
United States us_north_carolina Nothing Selected
QUOTE (kbersch @ Oct 30 2007, 06:19 PM) *
Kelly,
I'd be interested in checking out your VIs, but I only go up to LV8.0. Any chance that you could save to 8 and post them?
Thanks.
Jim
Tags
+Quote Post
normandinf
post Jul 11 2008, 07:20 PM
Post #5
Premium Member
Using LabVIEW Since:2000
LV:8.6 ,8.5 ,.
ca_quebec Canada Nothing Selected
Attached File  Disable_Enable_Hide_Show_v80.zip ( 116.58K ) Number of downloads: 57
Tags
+Quote Post
kbersch
post Jul 11 2008, 07:57 PM
Post #6
Member
LV:8.2.1 ,6.0.2 ,.
I did a little more testing and found a bug in the two support files. Here they are with the fix.
Attached File(s)
Attached File  Get_controls_in_cluster.vi ( 39.81K ) Number of downloads: 88
Tags
+Quote Post
Yair
post Jul 12 2008, 07:38 PM
Post #7
Extwemely Active
Premium Member
Using LabVIEW Since:2003
LV:8.6 ,7.0 ,.
Israel Nothing Selected Nothing Selected
Kelly, relying on control labels is something I generally find potentially dangerous. A more robust method would be using the control references directly. You can see a quick example here (in 7.1, if memory serves). In actual code, I would probably separate the action from the group input, but it shows the concept well enough.
More than meets the eye...
Tags
+Quote Post
Time is now: 22nd November 2008 - 07:40 AM
