Tags
> [Wiki] XNodes:List of XNode Abilities
PJM_labview
post Sep 23 2007, 07:36 AM
Post #1
JKI
Using LabVIEW Since:1998
LV:8.5.1 ,8.6 ,8.2.1
United States France Nothing Selected My Blog
This is the discussion topic for the wiki article: List of Xnode Abilities
What are the difference between Ability Name and Public Name? What is the Public Name used for?
I initially tought that the Public Name was used in the reply output of some abilities, but this is not the case.
Does anybody have a list of supported replies command?
So far I found the following replies commands:
  • UpdateImageAndBounds
  • UpdateTerms
  • GenerateCode
I am trying to get LabVIEW to call the "Size" ability. I tried UpdateSize, OnResize, Size but none worked. Any idea?
Thanks
PJM
Got VIPM?
JKI . VIPM . EasyXML . OpenG . LAVA . Builder . Blog
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
PJM_labview
post Sep 23 2007, 07:33 PM
Post #2
JKI
After digging a bit more, here is a possible - mostly untested - reply list (items in bold have been tested).
  • SaveForPrevious
  • AugmentSelf
  • ReplaceSelf
  • ModifyCode
  • GenerateCode
  • IssueWarning
  • SdfX
  • SimX
  • XNodeType
  • PreserveUserCodeGUID
  • UpdateTerms
  • UpdateLabel
  • UpdateImage
  • UpdateHelp
  • UpdateAutotoolRegions
  • ShowMenu
  • FailTransaction
  • ChangeTransactionName
PJM
Got VIPM?
Tags
+Quote Post
Gavin Burnell
post Sep 23 2007, 07:59 PM
Post #3
Premium Member
Using LabVIEW Since:1994
United Kingdom uk_yorkshire Nothing Selected
QUOTE (PJM_labview @ Sep 23 2007, 08:33 PM) *
Ummm, which version of LabVIEW is this for ? I know there were substantial changes in abilities (and replies?) between 8.0 and 8.2, I assume that there have been more changes with 8.5....
Gavin Burnell
Lecturer and EPSRC Advanced Research Fellow
School Physics and Astronomy
University of Leeds, UK.
Tags
+Quote Post
PJM_labview
post Sep 23 2007, 08:25 PM
Post #4
JKI
These replies are for LabVIEW 8.21.
Please note that the one I did not test might not even be valid replies.
PJM
Got VIPM?
Tags
+Quote Post
Aitor Solar
post Sep 25 2007, 06:59 AM
Post #5
Member
Using LabVIEW Since:2000
LV:8.5 ,8.20 ,7.1.1
Spain spn_Madrid Nothing Selected
QUOTE (PJM_labview @ Sep 23 2007, 09:36 AM) *
I think Size is only called when the user resizes the XNode. Why do you need to call it? You can invoke an UpdateImageAndBounds reply to call the Bounds ability and tell LabVIEW the new dimensions for your XNode.
Saludos,
Aitor
Tags
+Quote Post
PJM_labview
post Sep 25 2007, 04:13 PM
Post #6
JKI
Aitor
I had a use case were this would have been convenient. Basically after a right click selection, I needed to redraw my xnode. But prior to that I had to resize it. Since I could not do it (invoking the size through a reply), I was able to achieve what I was trying to do by just running part of the size code in the SelectMenu3.vi before sending the UpdateImageAndBounds reply.
PJM
Got VIPM?
Tags
+Quote Post
AdamRofer
post Sep 25 2007, 04:50 PM
Post #7
More Active
Group Icon
WIKI Moderator
LV:8.5 ,6.1 ,7.1.1
United States us_california Nothing Selected
QUOTE (PJM_labview @ Sep 22 2007, 11:36 PM) *
  • UpdateTerms
  • GenerateCode
Thanks
PJM
Public Name is a publicly viewed name for the ability that changes on different versions of LabVIEW.
Ability Name is the name recognized by LabVIEW internally.
Previous explanation:
http://forums.lavag.org/Wiki-XNodes-t6811.html#entry26206
Example:
CODE
<Item Name="GetGrowInfo.vi" Type="Ability VI" URL="GetGrowInfo.vi">
<Property Name="NI.XItem.Name" Type="Str">GrowInfo</Property>
</Item>
In this example, GetGrowInfo is the Public Name (it describes the function more properly here), and GrowInfo is the Ability Name.
Naming your VI "GetGrowInfo.vi" is, of course, only a suggestion. You can choose to ignore the Public Name.
The reason this situation ended up becoming slightly ugly is that NI didn't plan to rewrite their Ability Names very carefully, so you have this situation:
1) LabVIEW 8.0: BuildPopup (now with public name "BuildMenu") is created. An input or output cluster contains X elements.
2) LabVIEW 8.?: BuildMenu (now with public name "BuildMenu2") is created to fix a problem or add functionality to (1). NI at this point did not use their current renaming strategy.
3) LabVIEW 8.2?:BuildMenu3 (with public name "BuildMenu3") is created to fix a problem or add functionality to (2). When this Ability is incorporated, the public names for the two previous "revisions" are set to BuildMenu2 and BuildMenu despite the confusion that now occurs.
The reason they do this is so that (a) you can see that BuildPopup was simply the first attempt in the series of the BuildMenu Abilities, and (b) backwards compatibility is retained.
This system works well now, but unfortunately the existence of old versions complicates the naming scheme like this.
As for replies, you should be able to call a large amount of "Abilities" (by their Ability Name) by specifying the reply as such. Your list is the first that I've seen.
It seems like you have the "Size" situation taken care of.
- Adam
Adam Rofer
Tags
+Quote Post
PJM_labview
post Sep 26 2007, 04:46 PM
Post #8
JKI
Adam,
Thanks for the info.
I never realized what was the public name because I used the XNode Manager from Aitor thumbup1.gif and I never had to mess with the xml file directly.
As for the replies, I though I tried to call a couple of them by their name unsucessfully. I will give it another shot.
PJM
Got VIPM?
Tags
+Quote Post
Michael_Aivaliot...
post Sep 29 2007, 10:33 PM
Post #9
Group Icon
Admin
LV:8.5 ,8.2.1 ,7.1.1
Someone please add the info from this thread in the xnodes wik article or make a new page.
Tags
+Quote Post
Time is now: 22nd November 2008 - 06:42 AM
