Tags
> [Wiki] Flattened pixmap
Ton
post Sep 3 2007, 10:49 AM
Post #1
CCT It
Premium Member
Using LabVIEW Since:2001
LV:8.5.1 ,6.1 ,8.2.1
Netherlands hol_utrecht Nothing Selected My Blog My Gallery
This is the discussion topic for the wiki article: Flattened pixmap
Certified LabVIEW Developer
Shouldn't you be programming a Code Repository solution?
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Ton
post Sep 3 2007, 11:49 AM
Post #2
CCT It
Premium Member
QUOTE (tcplomp @ Sep 3 2007, 12:49 PM) *
When is the 32 bit value added?
Ton
Tags
+Quote Post
eaolson
post Sep 3 2007, 03:18 PM
Post #3
Member
Using LabVIEW Since:1998
LV:7.1.1 ,8.0.1 ,8.20
United States us_texas us_illinois
QUOTE (tcplomp @ Sep 3 2007, 06:49 AM) *
What do you mean? Added to what?
Tags
+Quote Post
Ton
post Sep 3 2007, 03:33 PM
Post #4
CCT It
Premium Member
QUOTE (eaolson @ Sep 3 2007, 05:18 PM) *
The wiki entry states:
QUOTE
Image depth describes the bit depth of the colors in the image. It's value affects how the image and colors elements are interpreted. Valid values are: 1, 4, 8, 24, and 32. It is a U8
But I can't find anywhere (webhelp from NI up to 8.5) about this 4 byte image depth.
Ton
Tags
+Quote Post
eaolson
post Sep 5 2007, 09:06 PM
Post #5
Member
QUOTE (tcplomp @ Sep 3 2007, 10:33 AM) *
You're right, it doesn't seem to be mentioned in the help. A 32 bit image is just a 24 bit image with transparency. In a 24-bit image, the image array is 3 bytes, stored in [R, G, B, R, G, B...] order. For a 32 bit image, it's the same, just with an alpha channel: [A, R, G, B, A, R, G, B...] If you open up some of the picture functions (e.g. Draw Flattened Pixmap), you can see NI is handling the 32-bit case. I think only PNGs work with transparency in LabVIEW. Windows XP introduces a BMP with transparency, but I don't know if LabVIEW handles that case. JPGs don't do transparency.
Tags
+Quote Post
neB
post Sep 5 2007, 09:47 PM
Post #6
Certified Kool-Aid Kid
Premium Member
LV:7.1 ,. ,.
United States Germany Nothing Selected
QUOTE (tcplomp @ Sep 3 2007, 11:33 AM) *
Ton
Just a guess...
Before monitors were VGA there were CGA that offered a whole 16 colors, any four of which could used at any time. wink.gif
Like I said, just a guess.
Anyone have eperience in LabVIEW with four bit colors?
Ben
Tags
+Quote Post
eaolson
post Sep 6 2007, 12:45 AM
Post #7
Member
QUOTE (Ben @ Sep 5 2007, 04:47 PM) *
Just a guess...
Ben
Interesting suggestion, but I kind of doubt it. The image array is an array of bytes, not bits and I doubt CGA applications cared much about transparency. smile.gif A four-bit depth image is an indexed image. Rather than store the color information for each pixel like in a 24-bit image, the image array stores the index into the colors array, where the actual colors are stored as U32s. In the flattened pixmap, the only real difference between a 1-bit, 4-bit, and 8-bit image is the length of the colors array (i.e. the size of the color palette).
Tags
+Quote Post
Ton
post Sep 6 2007, 06:44 PM
Post #8
CCT It
Premium Member
The reason I started this thread is because the Wiki makes a false statement (which I will remove) that the Pixmap support 4 byte color information
Ton
Tags
+Quote Post
eaolson
post Sep 6 2007, 10:18 PM
Post #9
Member
QUOTE (tcplomp @ Sep 6 2007, 01:44 PM) *
I added the 32 bit back in. You can have 4 byte images, and 32 is a valid entry in the image depth element. It's not mentioned in the help, but the 32 bit case is handled by the picture VIs. A 32 bit (4 byte) image is the special case where you have image consisting of RGB color data and alpha channel (transparency). So in some cases, the image array will consist of sequences of four bytes.
Tags
+Quote Post
rolfk
post Sep 8 2007, 03:00 PM
Post #10
Premium Member
Using LabVIEW Since:1992
LV:8.5.1 ,8.2.1 ,7.1.1
Netherlands Switzerland Nothing Selected
QUOTE (eaolson @ Sep 5 2007, 07:45 PM) *
CGA was 16 colors resulting in 4 BITs per pixel. Those were depending on the format actually packed directly into the bitmap with two pixels per bytes. Windows Bitmaps however always store bit depts of 8 bit and smaller as a palette with indeces, since they do always assume an RGB value as color.
The other thing discussed here are 4 BYTE or 32 bit bitmaps. While NI never really documented that, the Picture control was able to handle 32 bit (where it really simply ignores the 4th byte) bitmaps since the early days of this control. The Picture control VI functions didn't support that in the beginning but I had modified them myself and that worked correctly even in LabVIEW 4 in a picture control.
Rolf Kalbermatter
Tags
+Quote Post
Collapse
> Similar Topics
    Topic Title Replies Topic Starter Views Last Action
No New Posts   2 eaolson 887 29th September 2006 - 10:44 PM
Last post by: crelf
No New Posts 5 Tomi Maila 2590 17th March 2007 - 05:48 AM
Last post by: Michael_Aivaliotis
No New Posts   8 AdamRofer 2202 4th June 2007 - 07:35 PM
No New Posts   4 Michael_Aivaliotis 1897 2nd April 2007 - 08:00 PM
Last post by: Jim Kring
Time is now: 7th October 2008 - 12:37 AM
