> Related links
Check out our User Interface Code Repository Files or visit the LabVIEW Wiki User Interface Portal
Tags
> Slider return to default when released?, car accelerator
boyracer38
post Nov 23 2004, 03:50 PM
Post #1
Active
Member
LV:7.1
Is there a way to make a slider control return to the default position when released?
The aim is to have a control which acts like the accelerator of a car.
When released, it will spring back to 0.
Thanks
Jason
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
boyracer38
post Nov 23 2004, 03:53 PM
Post #2
Active
Member
LV:7.1
In conjuction with the lever mentiond on my previous post:
The harder the accelerator is pressed, the faster the car accelerates. This will be illustrated with a Tachometer (RPM). When the accelerator is released, the car will decelerate.
So a ramp up/down function is needed??
Tags
+Quote Post
Paulo Almeida
post Nov 23 2004, 07:33 PM
Post #3
Member
LV:7.0
Portugal
QUOTE (boyracer38 @ Nov 23 2004, 03:50 PM)
Thanks
Jason
If you use a Event structer associate with your slider, i think you can do that. Use the mouse up event. i hope this example can help you.
bye
Attached File(s)
Tags
+Quote Post
boyracer38
post Nov 24 2004, 09:39 AM
Post #4
Active
Member
LV:7.1
That really helps thanks!!!!
Thanks
Jason
Tags
+Quote Post
Time is now: 22nd November 2008 - 03:38 AM
