See here for the proper LabVIEW bug reporting procedure.
Tags |
Aug 6 2007, 03:00 PM
Post
#1
![]() Very Active Member Posts: 61 Joined: 12-November 04 From: Germany Member No.: 1013 Using LabVIEW Since:1994 LV:8.5.1 ,8.2.1 ,7.1.1
I've encountered the following bug: See attachment
It is one of the bad and strange ones. Wolfram Edit: I've replaced the attachment. There was a race condition in the previous demonstration VIs. Wolfram This post has been edited by Wolfram: Aug 6 2007, 03:50 PM
Attached File(s)
| Ad |
Post
Aug 6 2007, 04:05 PM
Post
#2
Certified Kool-Aid Kid Premium Member ![]() Posts: 1155 Joined: 6-December 02 From: Pittsburgh PA USA Member No.: 29 Using LabVIEW Since:1998 LV:7.1 ,. ,.
I've encountered the following bug: See attachment It is one of the bad and strange ones. Wolfram Edit: I've replaced the attachment. There was a race condition in the previous demonstration VIs. Wolfram Thanks for sharing. THe bug fix list for LabVIEW 8.5 has an item that talks about writing to a control via property nodes and it over-rides a read from a local. I wonder if this is related. This bug reminds me of trying to chip ECL circuits. Bad siganls can propogate backwards throught a gate there as well. Ben
Aug 6 2007, 04:38 PM
Post
#3
Drawing Tool - LVOOP example application Premium Member ![]() Posts: 1168 Joined: 29-January 06 From: Helsinki Member No.: 4014 Using LabVIEW Since:2004 LV:8.5.1 ,8.2.1 ,7.1.1
My Blog
I was able to reproduce the bug in LabVIEW 8.2.1 and LabVIEW 8.5. I guess this issue is related to the LabVIEW in-placeness algorithm. Would you please report this bug to NI if you have not already done so.
What happens is that LabVIEW decides not to make a buffer copy for the subVI as it incorrectly thinks that the buffer is not modified by the subVI. However the buffer is modified by the subVI by calling a property node for an indicator. As a buffer copy is not made, the call to the property node actually modifies the original buffer. This results the buffer to become empty after the subVI call. I changed the property node for local variable and the bug disappeared. Replacing the local variable with property node reproduced the bug once again. The bug appeared for both value and value (signalling) properties. I found even stranger issue. The buffer modifications "backpropagate" to a constant on block diagram. See the attached project (for LabVIEW 8.5). To reproduce, open block diagram of main.vi. Take a look at the constant there. Then run the VI. Hide the block diagram and show it again by pressin Ctrl+E twice. The constant value has been modified. ![]() main before execution ![]() main after execution subVI
buffer_backpropagation.zip ( 16.35K )
Number of downloads: 89Tomi --------------------
Aug 6 2007, 04:44 PM
Post
#4
Very Active Member Posts: 78 Joined: 12-October 04 Member No.: 793 Using LabVIEW Since:2002 LV:8.2.1 ,7.1 ,6.0.2
Nice find, and a very good demonstration. I can confirm this bug for 6.0.2, 7.0, 7.1, 8.0 and 8.2.1,
Some observations: -Replacing the sub-vi graph with a simple data indicator: still bugged. -Replacing the sequence loop with a case statement: still bugged. -Replacing the clusters/arrays with dbls: still bugged. -Replacing the top level sequence loop with other error primitives (flatten/unflatten) and wiring the errors: still bugged. -Replacing the sub-vi value property node with a local: bug goes away. -Routing the error wire in the top level vi around the sequence: bug goes away. -The bug doesn't appear on the first run, but does appear on subsequent runs. Ouch... Looks like a ref to the sub-vi data is being incorrectly retained where the data enters the top level sequence loop. Very nice find! Joe Z. I've encountered the following bug: See attachment
Aug 6 2007, 04:46 PM
Post
#5
I was able to reproduce the bug in LabVIEW 8.2.1 and LabVIEW 8.5. I guess this issue is related to the LabVIEW in-placeness algorithm. Would you please report this bug to NI if you have not already done so. What happens is that LabVIEW decides not to make a buffer copy for the subVI as it incorrectly thinks that the buffer is not modified by the subVI. However the buffer is modified by the subVI by calling a property node for an indicator. As a buffer copy is not made, the call to the property node actually modifies the original buffer. This results the buffer to become empty after the subVI call. I changed the property node for local variable and the bug disappeared. Replacing the local variable with property node reproduced the bug once again. The bug appeared for both value and value (signalling) properties. I found even stranger issue. The buffer modifications "backpropagate" to a constant on block diagram. See the attached project (for LabVIEW 8.5). To reproduce, open block diagram of main.vi. Take a look at the constant there. Then run the VI. Hide the block diagram and show it again by pressin Ctrl+E twice. The constant value has been modified. ![]() main before execution ![]() main after execution subVI
Number of downloads: 89Tomi I'll take care of reporting this to NI. Ben
Aug 6 2007, 04:49 PM
Post
#6
My Blog
I'll take care of reporting this to NI. I was just about to file a report bu you do that --------------------
Aug 6 2007, 04:51 PM
Post
#7
I was just about to file a report bu you do that OK, I'll do it this time but if you ever make Champion (hack, cough cough...), I'll expect you to do all of the bug reports. Service Request = 1007895. Matt will update this thread with CAR once filled. Ben
Aug 6 2007, 08:03 PM
Post
#8
My Blog
OK, I'll do it this time but if you ever make Champion (hack, cough cough...), I'll expect you to do all of the bug reports. Is it always the rookie that files all the bug reports? --------------------
Aug 6 2007, 08:31 PM
Post
#9
...the rookie.... No. Just the one that wants it fixed. Ben
Aug 6 2007, 11:03 PM
Post
#10
One hit wonder! NI ![]() Posts: 1 Joined: 16-March 07 From: Austin Member No.: 8049 Using LabVIEW Since:2006 LV:8.20 ,. ,.
This was reported to R&D (CAR #4C5FFLRK). Thanks for taking the time to report and investigate this everyone.
Another workaround (aside from Joe's method of using a local variable) is to force LabVIEW to copy the data in the wire before it is passed to the sub-VI or the sequence structure in the top-level VI. The bigger trick is predicting when this is going to happen Spex AE
Aug 7 2007, 03:11 AM
Post
#11
![]() LV R&D Envoy NI ![]() Posts: 1226 Joined: 15-August 06 From: Austin, TX Member No.: 5877 Using LabVIEW Since:2000 LV:8.5.1 ,. ,.
My Gallery
Is it always the rookie that files all the bug reports? This is like Supreme Court Justice Stephen Bryer... in an interview, he said he had been the newest justice for 12 years, and the newest justice is the one who has to answer the door if anyone knocks while the judges are debating. 12 years of answering the door! -------------------- "A VI outside a class is a gun without a safety. Data outside a class is a target."
--- A message from LabVOOP R&D
Aug 8 2007, 04:54 AM
Post
#12
![]() Very Active Member Posts: 129 Joined: 29-October 04 From: Vancouver, B.C. Member No.: 932 Using LabVIEW Since:1998 LV:8.5.1 ,7.1.1 ,.
... Another workaround (aside from Joe's method of using a local variable) is to force LabVIEW to copy the data in the wire before it is passed to the sub-VI or the sequence structure in the top-level VI. ... This is the exact sort of thing I imagined that new "Always Copy" primitive would be used for when I first saw it ... it's a perfect workaround for memory manager bugs (not that there are ever any of those Jaegen -------------------- "Duck was a neutral party, so he brought the ultimatum to the cows." -- Click, Clack, Moo: Cows That Type
Aug 8 2007, 09:11 AM
Post
#13
My Blog
I was thinking how bad this bug actually is. I found a very common use case of passing data to dialog windows where this bug can cause a lot of harm. When a main VI calls a subVI that is used to display data it's common to use value property nodes within the subVI. However using value property node may cause severe troubles as this bug modifies data in constants and wire buffers elsewhere in the calling VI. See the images below for this use case. ![]() Main VI passes data for subVI to be visualized ![]() SubVI uses value property node to modify the displayed data ![]() Main VI after execution, moving mouse over the constant displays the changed constant value
buffer_bug_8.0.zip ( 15.04K )
Number of downloads: 73Download the example project for LabVIEW 8.0 |
