See here for the proper LabVIEW bug reporting procedure.
Tags |
Aug 2 2007, 12:06 AM
Post
#1
Extremely Active Premium Member ![]() Posts: 430 Joined: 2-February 05 From: Southern California Member No.: 1519 Using LabVIEW Since:2004 LV:8.20 ,7.1.1 ,8.0.1
This bug seems to start up in LabVIEW 8.0. If you click on a color box the selection area pops up. If you press the [Esc] key you will still get a Value Change event with the previous color value.
Also, if you enter the popup area and then subsequently click outside of the popup area anywhere else on the panel, you will also get a Value Change event. This does not occur if you do not first enter the color selection area. UPDATE: CAR ID #4C2ANAK8
| Ad |
Post
Aug 2 2007, 12:57 AM
Post
#2
![]() Extremely Active JKI ![]() Posts: 612 Joined: 19-June 03 From: Bay Area, CA (USA) Member No.: 121 Using LabVIEW Since:1998 LV:8.5.1 ,8.6 ,8.2.1
My Blog
This bug seems to start up in LabVIEW 8.0. If you click on a color box the selection area pops up. If you press the [Esc] key you will still get a Value Change event with the previous color value. Also, if you enter the popup area and then subsequently click outside of the popup area anywhere else on the panel, you will also get a Value Change event. This does not occur if you do not first enter the color selection area. Reading your post just jog my memory. Additionally the value change events fires twice (when only one is expected). ![]() PJM
Attached File(s)
Aug 2 2007, 03:29 PM
Post
#3
![]() LV R&D Envoy NI ![]() Posts: 1226 Joined: 15-August 06 From: Austin, TX Member No.: 5877 Using LabVIEW Since:2000 LV:8.5.1 ,. ,.
My Gallery
I don't see a CAR number. Has someone reported this to NI?
-------------------- "A VI outside a class is a gun without a safety. Data outside a class is a target."
--- A message from LabVOOP R&D
Aug 2 2007, 03:45 PM
Post
#4
I don't see a CAR number. Has someone reported this to NI? Doing that right now. Wanted to get some independent verification first.
Aug 2 2007, 06:37 PM
Post
#5
![]() Very Active Member Posts: 129 Joined: 29-October 04 From: Vancouver, B.C. Member No.: 932 Using LabVIEW Since:1998 LV:8.5.1 ,7.1.1 ,.
Something similar to this was reported here. (The "Value Change" event fires twice for normal colour selections)
CAR: 42FC9DIQ Jaegen This post has been edited by jaegen: Aug 2 2007, 06:39 PM -------------------- "Duck was a neutral party, so he brought the ultimatum to the cows." -- Click, Clack, Moo: Cows That Type
| Time is now: 22nd November 2008 - 02:17 AM |
