Visit our LabVIEW Wiki Code Distribution Portal
Tags |
Jul 16 2007, 08:21 PM
Post
#1
![]() Active Member Posts: 21 Joined: 17-April 06 Member No.: 4775 Using LabVIEW Since:2005 LV:8.2.1 ,8.0.1 ,7.1
Hello Everyone,
Is there a flag indicating whether or not a VI is actually a VI (.vi) or in executable form (.exe)? I need this so that I can conditionally find the relative path. Using the "Current VI's Path", you get the exe's path with the actual VI name appended to it (i.e. - C:\Projects\My Application.exe\Application.vi) Any thoughts? ~Zack
| Ad |
Post
Jul 16 2007, 08:23 PM
Post
#2
![]() Extwemely Active Premium Member ![]() Posts: 1621 Joined: 23-January 05 From: Here Member No.: 1431 Using LabVIEW Since:2003 LV:8.6 ,7.0 ,.
The Application class has a property called Kind which will return an enum telling you whether you're running inside LabVIEW or in a built executable. You can get it simply by dropping a property node on the diagram.
-------------------- More than meets the eye...
Jul 17 2007, 05:01 AM
Post
#3
More Active Member Posts: 32 Joined: 19-October 04 Member No.: 858 Using LabVIEW Since:2000 LV:8.5 ,6.1 ,.
Here are some VIs that I use. I cannot find where I got them and I'm sorry to the author for not siting his/her work.
The CallerIsExe.vi is the one that will help you. Just drop it in a VI and wire the Current VI's Path constant into it.
Attached File(s)
Jul 17 2007, 05:02 PM
Post
#4
Relying on the exe extension is problematic. You might have a file which is not an executable file but has an exe extension or you might have a directory which has an .exe at the end of its name or you might be running on Linux or Mac, where you don't have the extension.
A better way would simply be to use the property I mentioned and then output T or F based on its value. Another option for simplifying the subVI as it is now is to to use the Call Chain primitive and index out the second element, which would be the calling VI. You can then open a reference to it and get its path using a property node instead of having to wire its path into the subVI, but I would advise the first method. As for the base path VI, it suffers from the same basic problem. I prefer the OpenG method, which is basically getting the path of the VI (using the method I mentioned) and then stripping in a loop until the File/Directory Info primitive returns T in its directory output, like this quick example (which does not do error handling): ![]() This is also platform independent. -------------------- More than meets the eye...
Jul 17 2007, 05:13 PM
Post
#5
More Active Member Posts: 30 Joined: 3-July 03 From: Long Island, NY Member No.: 133 Using LabVIEW Since:1993 LV:8.20 ,. ,.
Here are some VIs that I use. I cannot find where I got them and I'm sorry to the author for not siting his/her work. The author's name is included in the context help documentation. -------------------- Jon Sweeney
Jul 17 2007, 06:14 PM
Post
#6
Yen, Those are very good points. I'll start using the Kind property now.
| Time is now: 22nd November 2008 - 02:26 AM |
