> Related links
Check out the related Code Repository Files or visit the LabVIEW Wiki Internet Portal
Tags
> Losing packet in TCP, Losing packet when the TCP/IP link go do
action
post Nov 15 2004, 03:28 PM
Post #1
One hit wonder!
Member
LV:7.0
I have constructed a labview application that gathers data and then sends it over a connection if it is up,
otherwise it buffer the data till the link is up and running.
When the connection is lost and then come back on line I will miss some packets.
As soon as I receive an error out from the TCP/IP box I stop sending any new packets.
Any one how know why I lose packets?
Since I am using the TCP protocol I expected that the packet that was sent and not
delivered has to be resent whiteout me doing this in my application. The number of
packets that is lost seams to have to do with the how many packet I send per second.
Higher speed more packet lost.
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Jim Kring
post Nov 16 2004, 09:43 PM
Post #2
Changing the world, one VI at a time.
JKI
Using LabVIEW Since:1995
LV:8.2.1 ,8.5 ,7.1.1
United States us_california Nothing Selected My Blog My Gallery
QUOTE (action @ Nov 15 2004, 07:28 AM)
One would expect that the packet which generated the error would be lost -- that's what the error is telling you. Are you losing more packets which were sent without generating an error, prior to the disconnect?
| Book | OpenG | LAVA | Champion | VIPM | Builder | Blog | JKI |
Tags
+Quote Post
Mike Ashe
post Nov 17 2004, 07:26 PM
Post #3
Instant Human, just add coffee
Premium Member
Using LabVIEW Since:1992
LV:8.2.1 ,7.1 ,8.0.1
United States us_connecticut us_washington
Are you returning a "packet XXX recieved" notification. It seems that adding a little bit of info to the buffer you build up (when the connection is down) might workaround your problem. I agree that it would be nice to know why you are loosing the packets, but making your recovery robust seems more important.
The reason I say robust recovery is more important is that I have seen multiple ways that LabVIEW's TCP/IP comms have problems over the years. Spurious timeout errors (you set the timeout to 2 seconds and the read VI returns in 50 millisec with a TO error) to buffer overflow errors when you try to transmit to fast. I have run into som many types of errors that I assume that there will be multiple error modes with TCP/IP and implement accordingly.
Best of luck!
"Always listen to the experts, they'll tell you what can't be done, and why.
Then go do it."
~The Notebooks of Lazarus Long (by Robert Heinlein)
Tags
+Quote Post
Time is now: 22nd November 2008 - 02:21 AM
