Jul 7 2007, 07:08 PM
Post
#1
![]() Confucius say, Man with tight trousers is pressing his luck. Admin ![]() Posts: 2304 Joined: 13-October 02 From: Planet Earth Member No.: 2 Using LabVIEW Since:1994 LV:8.5 ,8.2.1 ,7.1.1
My Blog
My Gallery
-------------------- Tags
| Ad |
Post
Tags
Jul 7 2007, 08:37 PM
Post
#2
Drawing Tool - LVOOP example application Premium Member ![]() Posts: 1154 Joined: 29-January 06 From: Helsinki Member No.: 4014 Using LabVIEW Since:2004 LV:8.5.1 ,8.2.1 ,7.1.1
My Blog
My understanding is that NI uses the abbreviation LabVOOP and not LVOOP. I'd prefer the official abbreviation.
Jul 7 2007, 10:01 PM
Post
#3
My Blog
My Gallery
My understanding is that NI uses the abbreviation LabVOOP and not LVOOP. I'd prefer the official abbreviation. As far as I know, it's written as LVOOP. Even in this document. Can you give an example where NI uses labvoop?
Jul 8 2007, 07:26 AM
Post
#4
My Blog
As far as I know, it's written as LVOOP. Even in this document. Can you give an example where NI uses labvoop? I think Stephen Mercer once said that it's LabVOOP and not LVOOP. LabVOOP Design Patterns document suggest the LabVOOP name. Perhaps we should ask Aristos Queue, I hope he notices this discussion... -------------------- Tags
Jul 9 2007, 01:31 PM
Post
#5
![]() LV R&D Envoy NI ![]() Posts: 1144 Joined: 15-August 06 From: Austin, TX Member No.: 5877 Using LabVIEW Since:2000 LV:8.5.1 ,. ,.
My Gallery
As far as I know, it's written as LVOOP. Even in this document. Can you give an example where NI uses labvoop? I prefer LabVOOP. NI uses LVOOP on all docs posted to ni.com. I personally want this changed to LabVOOP. I'll take any help I can get, such as LAVA using LabVOOP in all references. Why my preference? Frankly, LabVOOP is pronouncable. -------------------- "A VI outside a class is a gun without a safety. Data outside a class is a target."
--- A message from LabVOOP R&D Tags
Jul 9 2007, 01:54 PM
Post
#6
![]() I'm a LAVA, not a fighter. V I Engineering, Inc. ![]() Posts: 3472 Joined: 13-October 03 From: Michigan, USA Member No.: 181 Using LabVIEW Since:1993 LV:8.5 ,. ,.
My Blog
Why my preference? Frankly, LabVOOP is pronouncable. Not cleanly if you've got a mouthful of crackers... -------------------- ![]() Tags
Jul 9 2007, 02:28 PM
Post
#7
My Gallery
Not cleanly if you've got a mouthful of crackers... But then, most things aren't pronouncable cleanly when you have a mouth full of crackers. The exception being "I have a mouth full of crackers" which is correctly pronounced only when true. ;-) -------------------- "A VI outside a class is a gun without a safety. Data outside a class is a target."
Jul 9 2007, 02:59 PM
Post
#8
My Blog
But then, most things aren't pronouncable cleanly when you have a mouth full of crackers. The exception being "I have a mouth full of crackers" which is correctly pronounced only when true. ;-) -------------------- ![]() Tags
Jul 12 2007, 01:53 AM
Post
#9
Extremely Active Member Posts: 328 Joined: 26-March 06 From: Victoria, BC Canada Member No.: 4568 Using LabVIEW Since:1998 LV:8.6 ,8.5.1 ,8.2.1
But then, most things aren't pronouncable cleanly when you have a mouth full of crackers. The exception being "I have a mouth full of crackers" which is correctly pronounced only when true. ;-) While pronounciation might be possible with a mouthful of cracker, pronunciation would undoubtredly be a bit compromised. But, then again, I'm an OED kind of guy. What about OOPinG? In one pronunciation it would be a single word -- "OOPinG" a la looping". In another it could be almost three -- OOP in G, meaning "Object Oriented Programming In Of course this shouldn't but confused with OOPSinG.... ;-) This post has been edited by Val Brown: Jul 12 2007, 02:07 AM -------------------- The power of NeuroCARETM
Tags
Jul 12 2007, 12:27 PM
Post
#10
My Blog
What about OOPinG? -------------------- ![]() Tags
Jul 14 2007, 03:21 AM
Post
#11
I doubt that myself but I only live in Canada (now). I was originally born and lived in Washington, DC, then Pittsburgh, PA, then Long Island, NY. I especially think the "OOP in G" pronunciation is quite good and exact -- the idea is that the implementation of OOP is done in the G Language. Of course, one could do sort of reverse sort and excise on that idea and use instead: GiOOP For G implementing OOP. That would sound like "Gee -- OOP" and that might have a bit of panache. -------------------- The power of NeuroCARETM
Tags
Jul 14 2007, 03:42 AM
Post
#12
My Blog
...that would sound like "Gee -- OOP" and that might have a bit of panache. Sounds like the beginnings of a Monty Python sketch: We are the Knights that go "GeeeeeeeeeOOP"! -------------------- ![]() Tags
Jul 14 2007, 06:28 PM
Post
#13
Sounds like the beginnings of a Monty Python sketch: We are the Knights that go "GeeeeeeeeeOOP"! Yes, well a lot of this can sound like a Monty Python routine... ;-) OK, so how about: BROOL (rhymes with pool) Meaning: By Reference Object Oriented LabVIEW. or even: BROOPiL (sounds Brew Pull) By Refence Object Oriented Programming in LabVIEW Of course, the second choice also describes the behavior of many after working with LabVIEW so perhaps there's some "symmetry" to that... Isn't the real issue with the NI implementation that it isn't "really" by reference but by value? Of course, in saying this I'm taking the other threads at face value and not referencing them but I hope the point is still clear. -------------------- The power of NeuroCARETM
Tags
Jul 14 2007, 08:08 PM
Post
#14
![]() Extwemely Active Premium Member ![]() Posts: 1551 Joined: 23-January 05 From: Here Member No.: 1431 Using LabVIEW Since:2003 LV:7.0 ,7.1 ,.
"G" is really only a term used informally int he community at large as it's a trademark of a company other than NI (I can't remember who right now) PBS? (Sesame Street is brought to you by the letter G) OK, so how about: BROOL (rhymes with pool) or even: BROOPiL (sounds Brew Pull) Maybe BUGGER? (Chris, I will leave it to you to come up with suitable words for that acronym). -------------------- More than meets the eye...
Tags
Jul 19 2007, 02:17 AM
Post
#15
My Blog
