> Related links
Visit our LabVIEW Wiki Machine Vision and Imaging Portal
Tags
> [CR] USB Continuous Acquire V1.0.2, File Updated: 13 Jun 2007
Karissap
post Jun 12 2007, 01:31 PM
Post #1
Member
Using LabVIEW Since:2005
LV:8.5 ,8.0.1 ,7.1.1
Australia Nothing Selected Nothing Selected
File Name: USB Continuous Acquire V1.0.2
File Submitter: Karissap
File Submitted: 5 Jun 2007
File Category: Machine Vision and Imaging
Copyright © 2007, Karissa Purcell
All rights reserved.
Author:
Karissa Purcell
karissa.purcell@gmail.com
Distribution:
This code was downloaded from the LAVA Code Repository: http://forums.lavag.org/downloads.html
Description:
This VI uses the NI-IMAQ for USB drivers to continously acquire an IMAQ image.
The USB camera is selected from a list generated from the "IMAQ USB enumerate cameras" vi.
Grab rate is controlled using an event structure. This is so that image processing routines can use other event cases.
*Tested with a Logitech QuickCam IM
Dependancies:
Labview 8.0.x or higher
IMAQ drivers
NI-IMAQ for USB drivers (http://sine.ni.com/devzone/cda/epd/p/id/5030)
Support:
If you have any problems with this code or want to suggest features:
http://forums.lavag.org/CR-USB-Continuous-Acquire-t8428.html
Change Log:
1.0.2: Changed error cluster wiring
1.0.1: Fixed list control to select camera, improved error control.
1.0.0: Initial release of the code.
License:
BSD licencse
Click here to DOWNLOAD this file
Test Engineer
Certified LabVIEW Architect(CLA)
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Ton
post Jun 12 2007, 05:34 PM
Post #2
CCT It
Premium Member
Using LabVIEW Since:2001
LV:8.5.1 ,6.1 ,8.2.1
Netherlands hol_utrecht Nothing Selected My Blog My Gallery
Somehow I can't download the files!
Ton
Certified LabVIEW Developer
Shouldn't you be programming a Code Repository solution?
Tags
+Quote Post
crelf
post Jun 12 2007, 08:57 PM
Post #3
I'm a LAVA, not a fighter.
V I Engineering, Inc.
Using LabVIEW Since:1993
LV:8.5 ,. ,.
Australia United States Nothing Selected My Blog
QUOTE (tcplomp @ Jun 13 2007, 03:34 AM) *
I'm workin' on it...
Tags
+Quote Post
crelf
post Jun 12 2007, 10:11 PM
Post #4
LV:8.5 ,. ,.
It should be okay now.
Tags
+Quote Post
Ton
post Jun 13 2007, 04:17 AM
Post #5
CCT It
Premium Member
QUOTE (crelf @ Jun 13 2007, 12:11 AM) *
Ton
Tags
+Quote Post
Time is now: 22nd November 2008 - 05:02 AM
