> Related links
Check out our OOP Code Repository Files or visit the LabVIEW Wiki OOP Portal.
Tags
> GOOP strict typedef controls
m3nth
post Nov 5 2004, 06:50 PM
Post #1
Member
Using LabVIEW Since:2006
LV:8.5 ,. ,.
United States Nothing Selected Nothing Selected
I'm a little confused. After using GOOP, the data clusters that are generated are strictly typedefed, but can't be opened directly from the right click menu. I can use Advanced > Customize... as usual, but normally for my strict typedef controls, the Update from Typedef and Open Typedef options are enabled on the right click menu. What is the reason or idea behind these menu options being disabled and is there a way to enable them without interfering with the reason I'm guessing they are probably like that in the first place?
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
maximus
post Nov 6 2004, 10:07 AM
Post #2
Active
Member
LV:7.0
Netherlands
I reorganized the layout of the templates used by goop (include strict type defs), to my personal layout, and i've got no problems.
Tags
+Quote Post
m3nth
post Nov 6 2004, 03:46 PM
Post #3
Member
LV:8.5 ,. ,.
QUOTE (maximus @ Nov 6 2004, 05:07 AM)
I looked at doing this but goop library is passworded... my second option then has been to do the modifications to each class after I make it--is this what you're referring to? Or is there a way to make it actually generate the customized files you want in the first place?
Tags
+Quote Post
Jim Kring
post Nov 7 2004, 08:16 PM
Post #4
Changing the world, one VI at a time.
JKI
Using LabVIEW Since:1995
LV:8.2.1 ,8.5 ,7.1.1
United States us_california Nothing Selected My Blog My Gallery
QUOTE (m3nth @ Nov 6 2004, 07:46 AM)
Try OpenGOOP -- no passwords...
| Book | OpenG | LAVA | Champion | VIPM | Builder | Blog | JKI |
Tags
+Quote Post
maximus
post Nov 8 2004, 06:25 PM
Post #5
Active
Member
LV:7.0
Netherlands
Tags
+Quote Post
m3nth
post Nov 8 2004, 06:57 PM
Post #6
Member
LV:8.5 ,. ,.
QUOTE (maximus @ Nov 8 2004, 01:25 PM)
Thanks Jim.
Tags
+Quote Post
didierj
post Nov 9 2004, 12:42 PM
Post #7
Member
Using LabVIEW Since:1997
LV:7.1.1 ,6.1 ,.
Switzerland France Nothing Selected
QUOTE (m3nth @ Nov 5 2004, 08:50 PM)
When you make canges on the data-cluster in GOOP (downloaded from NI) you'll have to also re-save the object reference. Otherwise you have broken methods.
Didier
Tags
+Quote Post
Time is now: 22nd November 2008 - 04:46 AM
