This root forum called Rusty Nails is for anything and everything related to hacking LabVIEW. Please use the subforums (Xnodes or VI Scripting) for specific issues.
Tags |
Jun 7 2007, 09:27 PM
Post
#1
![]() Very Active Premium Member ![]() Posts: 77 Joined: 2-September 03 From: Sarasota, FL Member No.: 162 Using LabVIEW Since:1994 LV:8.5 ,8.2.1 ,.
Just pondering this possibility. I have not opened up the supersecret stuff in awhile since LV7.0 and am wondering if this
is possible to do. I also would like to know the last version of LabVIEW that properly exposes all the scripting classes. I tried it in my oldest version which is 7.1 and it already seemed to be buttoned up by NI. Of course I am assuming the use of a activex GIF control (anigif, for example) to programmatically read each GIF frame. -------------------- Michael Sachs
Intelligent Systems www.viScience.com
| Ad |
Post
Jun 8 2007, 04:13 AM
Post
#2
![]() CCT It Premium Member ![]() Posts: 1331 Joined: 13-June 05 From: Woerden, Netherlands Member No.: 2399 Using LabVIEW Since:2001 LV:8.5.1 ,6.1 ,8.2.1
My Blog
My Gallery
Jun 8 2007, 08:31 AM
Post
#3
![]() Extwemely Active Premium Member ![]() Posts: 1621 Joined: 23-January 05 From: Here Member No.: 1431 Using LabVIEW Since:2003 LV:8.6 ,7.0 ,.
7.1 was the last version where you could easily access the private stuff. In 8.0 it requires a license (although I understand some people have been able to work around that).
In any case, at least 7.1 does not expose a way of doing anything with the picture ring's images, so I don't think that would be possible. NI does not provide a means of reading GIFs (only writing them), but many graphics packages probably allow batch saving all the images as seperate files. You should then be able to automatically spawn some VIs and set those images as their icons (using the Set VI Icon method). Icons you can easily (manually) copy into picture rings (although they're limited to a small image). Another option you can try is Rolf's VIs included in this tool which allow copying an image into the clipboard. This should allow you to automate some of the process. A third option would be to ditch the picture ring and use the picture control for the animation (although that would be slower). Of course, if you just want the animation itself, you can simply drop the GIF on the front panel. -------------------- More than meets the eye...
Jun 8 2007, 10:04 AM
Post
#4
![]() Very Active Premium Member ![]() Posts: 119 Joined: 21-January 06 From: Leeds, UK Member No.: 3951 Using LabVIEW Since:1994 LV:8.5.1 ,8.6 ,8.2.1
Just pondering this possibility. I have not opened up the supersecret stuff in awhile since LV7.0 and am wondering if this is possible to do. It doesn't seem that the import picture methods have been exposed for scripting (at least in 8.2.1). In general only stuff that NI itself has found a need to script is scriptable - which is fair enough given that end users aren't supposed to mess with stuff that is unsupported, unstable, only for internal use by NI, not necessarily forwrds compatible and might eat your grandmother -------------------- Gavin Burnell
Lecturer and EPSRC Advanced Research Fellow School Physics and Astronomy University of Leeds, UK.
| Time is now: 22nd November 2008 - 02:38 AM |
