> Related links
Check out our VI Scripting Code Repository Files and visit the LabVIEW Wiki VI Scripting article
Tags
3 Pages V   1 2 3 >
> [CR] Scripting Tools.zip
Gavin Burnell
post Jun 7 2007, 01:00 PM
Post #1
Premium Member
Using LabVIEW Since:1994
LV:8.5.1 ,8.6 ,8.2.1
United Kingdom uk_yorkshire Nothing Selected
File Name: Scripting Tools.zip
File Submitter: Gavin Burnell
File Submitted: 24 May 2007
File Updated: 7 Nov 2008
File Category: VI Scripting
File Version: 0.18.01
LabVIEW Version: 8.5.x
License: The BSD License
Scripting Tools.zip 0.18.01
Copyright © 2007, University of Leeds, UK
All rights reserved.
Author:
Gavin Burnell
G.Burnell@leeds.ac.uk
Distribution:
This code was downloaded from the LAVA Code Repository: http://forums.lavag.org/downloads.html
Description:
This is a LabVIEW 8.2 Library of VIs to help with scripting.
The public VIs include routines to get hold of the block diagram references, control terminal references, get the
connector pane reference and select the connector pane pattern and wire controls up to it. There are a number of
routines to help wire the block diagram up, including creating a selection of the primitives (I got bored of coding
them all up !).
I've stuck in some routines that work with tags - hidden away is the capability to tag LabVIEW vi-server objects
with arbitary data. One possibility is to use this to identify bits of the block diagram of a vi for moving and
rewiring via scripting.
NB If you are installing this with the Array XNodes (also from the Code repository) then I strongly recommend
unzipping the two files into the same common directory and preserving the names. That should help linkage problems.
Dependancies:
Support:
If you have any problems with this code or want to suggest features:
http://forums.lavag.org/CR-Scripting-Toolszip-t8399.html
Change Log:
0.18.01 Repackage for LabVIEW 8.5.1
Change Create Free Text Label to polymorphic and add a polymorph for creating labels on block diagrams
0.17.01 Adds another routine for XNode support to get the terminal descriptor from a vi reference.
0.16.02 Update .opgb file to allow the library to be built as an OpenG package file for install via VIPM
0.16.01 Minor bug fixes, added a routine to convert a ref to an enum describing its class, reworked find all objects
to get the selector tunnel of a case structure too. Added a number of routines to the XNode Support
sub-library.
0.15.01 Added new routines to tidy up wires and delete LabVIEW objects.
Added a new example that will take a selected case structure without a wire selector, looks for
an error cluster wire that tunnels in and out, deletes the in tunnel and wires it to the selector
instead. This is for those situations when you realise you should have wrapped your vi in an error
case structure... !
0.14.02 Fixed the cleanup wiring example by adding a routine to return references for wires specifically.
0.14.01 Added a routine to create a free text label on a vi front panel.
0.13.02 Added routines to create constants and controls/indicators from aribtary variant data. Reorganised some
of the tagging support vi's out of private scope and renamed the misspelt private directory. Added a couple
more examples - one is a tool to set tags on selected elements for doing template based scripting and the
other is a complete (although sparse) XNode that will test whether a single LVObject references, or an array
of LVObject references can be cast to a specific type of reference. (Think about getting all objects in a
diagram and then filtering for those that are decorations, or sub-bi nodes or...). The Generate Code ability
vi of this XNode demonstrates how to use a template vi with tagging to minise the hassle of generating code
for XNodes.
This release is in OpenG Package format
0.12.01 Added a few new routines, one to expand a shift register, one to deterine if an object is selected,
and a polymorphic vi that returns a reference of any given LVObject class (essentially wrapping
class specifier constants for all possible class types). Also added a couple of examples, including
one that will do a clean up wire operation on all selected wires or all wires in the structure.
0.11.01 Wrapped all vis in a case structure wired to error in for error handling
added a get sub-vi nodes in heirarchy and get all sub-vis routines
tried to find and fix the worst wiring excesses
0.10.04 Updated the README
0.10.03 fixed a bug with the creation of (un)bundle by name nodes.
0.10.02 fixes a couple of bugs, and adds some create bundle/unbundle node functions.
0.10.01 Original release
License:
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the
following conditions are met:
* Redistributions of source code must retain the above copyright notice, this list of conditions and the
following disclaimer.
* Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the
following disclaimer in the documentation and/or other materials provided with the distribution.
* Neither the name of the University of Leeds nor the names of its contributors may be used to endorse or
promote products derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Gavin Burnell
Lecturer and EPSRC Advanced Research Fellow
School Physics and Astronomy
University of Leeds, UK.
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Yair
post Jun 7 2007, 05:56 PM
Post #2
Extwemely Active
Premium Member
Using LabVIEW Since:2003
LV:8.6 ,7.0 ,.
Israel Nothing Selected Nothing Selected
Nice.
More than meets the eye...
Tags
+Quote Post
ohiofudu
post Jun 7 2007, 11:09 PM
Post #3
More Active
Member
Using LabVIEW Since:2004
LV:8.0 ,7.1.1 ,6.1
Germany Nigeria Nothing Selected
Hi Burnell,
Could you Please post Examples on how to use these tools(Vis) I have not being able to use some of the vi.
Thanks
Ohiofudu
Ohiofudu Israel
Tags
+Quote Post
Gavin Burnell
post Jun 11 2007, 03:15 PM
Post #4
Premium Member
QUOTE (ohiofudu @ Jun 8 2007, 12:09 AM) *
Hi Burnell,
Thanks
Ohiofudu
I've just posted a new version which has a couple of examples, adds some more features, and fixes a couple of minor bugs.
Gavin Burnell
Tags
+Quote Post
Mike Ashe
post Jun 11 2007, 08:01 PM
Post #5
Instant Human, just add coffee
Premium Member
Using LabVIEW Since:1992
LV:8.2.1 ,7.1 ,8.0.1
United States us_connecticut us_washington
Nice tool(s) Gavin!
Just a very minor nit, your subdirectory \Prviate should be \Private
Great idea to create the examples, now perhaps to add a few more complex ones. Do you take donations?
(Of examples, I mean)
One other thought, you also posted your Scripting Tools here in this thread.
Perhaps you might consider splitting the Scripting Tools out of that and including a link to the CR version to make sure someone doesn't get confused or maybe just edit the post to add a link to your CR version so they know that updated versions are available. In any event, great work.
"Always listen to the experts, they'll tell you what can't be done, and why.
Then go do it."
~The Notebooks of Lazarus Long (by Robert Heinlein)
Tags
+Quote Post
Gavin Burnell
post Jun 11 2007, 08:41 PM
Post #6
Premium Member
QUOTE (Mike Ashe @ Jun 11 2007, 09:01 PM) *
Er, yes. I do a lot of coding whilst travelling on the train, which means sometimes my typing isn't as accurate as it should be... will fix that next time.
I'll happily include any donated examples or indeed bug fixes, new functions, whatever (day job time permitting of course wink.gif ) !
Hmmm, I don't seem to be able to edit my posts in that thread any longer. At the time I posted that version, the tools were in code-repository purdah -that version worked well enough for the XNodes but had several bugs in them and I'd replace it if I could...
Gavin Burnell
Tags
+Quote Post
ohiofudu
post Jun 11 2007, 08:50 PM
Post #7
More Active
Member
LV:8.0 ,7.1.1 ,6.1
QUOTE (Gavin Burnell @ Jun 11 2007, 10:15 AM) *
Hi Gavin,
Thanks for the Examples Great Job.
Ohiofudu Israel
Tags
+Quote Post
Michael_Aivaliot...
post Jun 12 2007, 02:21 AM
Post #8
Group Icon
Admin
LV:8.5 ,8.2.1 ,7.1.1
QUOTE (Gavin Burnell @ Jun 11 2007, 01:41 PM) *
I've edited the post to include a link to the CR file. FYI, this is a perfect use case for using the "report post to moderator" button. Click on that button and describe what you want me to do and I will do it.
Tags
+Quote Post
rolfk
post Jun 12 2007, 07:51 AM
Post #9
<customize this text>
Premium Member
LV:8.5.1 ,8.2.1 ,7.1.1
Netherlands Switzerland Nothing Selected
QUOTE (Michael_Aivaliotis @ Jun 11 2007, 09:21 PM) *
Or one could get a premium membership. wink.gif Allows you to edit posts even months later.
Rolf Kalbermatter
Tags
+Quote Post
Michael_Aivaliot...
post Jun 12 2007, 04:21 PM
Post #10
Group Icon
Admin
QUOTE (rolfk @ Jun 12 2007, 12:51 AM) *
I couldn't have said it better myself!
Tags
+Quote Post
Gavin Burnell
post Jun 12 2007, 09:27 PM
Post #11
Premium Member
QUOTE (rolfk @ Jun 12 2007, 08:51 AM) *
Rolf Kalbermatter
In the meantime, have another incremental update. I've included an example of using the scripting tools in an XNode, because you can't build zip files with XNodes in them via the LabVIEW project window, I've switched to packaging as an OpenG Package format. I've subsequently realised that I've packaged up some cruft as well oops.gif
Gavin Burnell
Tags
+Quote Post
Mike Ashe
post Jun 13 2007, 01:21 PM
Post #12
Premium Member
QUOTE (Gavin Burnell @ Jun 12 2007, 05:27 PM) *
In the meantime, ... I've switched to packaging as an OpenG Package format.
Are you going to submitt this to be a package available to VIPM any time soon? I think it would be a great addition.
Then go do it."
Tags
