> Related links
Visit the LabVIEW Wiki Application Design & Architecture Portal
Tags
> how to generate a button clicked event
kingson
post Oct 27 2004, 04:21 PM
Post #1
3 more posts to go!
Member
LV:7.1
Hi all,
I intend to programatically generate a Value Changed event for a latched boolean control.
just because I want to reuse the process code for this evnet while it is not convenient to
put it in a sub-vi.
I tried to link a boolean constant TRUE to the property Value(Signaling), but get an error
that this doesnt work for a latched boolean control.
Is there any way out?
Thanks.
This post has been edited by kingson: Oct 27 2004, 04:22 PM
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
kingson
post Oct 27 2004, 05:02 PM
Post #2
3 more posts to go!
Member
LV:7.1
QUOTE (kingson @ Oct 27 2004, 05:21 PM)
Hi all,
put it in a sub-vi.
Thanks.
I just come up with a workaround in which I use switched boolean instead of latched. I can access its property Value(Signaling).
Then in the Value Changed event process, I wire a FALSE constant to the local variable of
this boolean control to reset the value.
Tags
+Quote Post
todd
post Oct 27 2004, 08:58 PM
Post #3
Member
Using LabVIEW Since:2006
LV:7.1.1 ,. ,.
United States Nothing Selected Nothing Selected
Here's how I reset the button and catch errors.
Attached thumbnail(s)
Attached image(s)
Attached Image Attached Image
Tags
+Quote Post
kingson
post Oct 28 2004, 03:00 PM
Post #4
3 more posts to go!
Member
LV:7.1
QUOTE (todd @ Oct 27 2004, 09:58 PM)
Will the "Delete Selected" Value Changed event executed again when you reset its value?
What I did is examplifed in the attached file.
Attached File(s)
Tags
+Quote Post
todd
post Oct 28 2004, 04:56 PM
Post #5
Member
LV:7.1.1 ,. ,.
QUOTE (kingson @ Oct 28 2004, 08:00 AM)
No. It would execute again If the property was 'Value (Signaling)' instead of 'Value'.
I haven't yet installed 7.1.
Tags
+Quote Post
kingson
post Oct 29 2004, 08:53 AM
Post #6
3 more posts to go!
Member
LV:7.1
QUOTE (todd @ Oct 28 2004, 05:56 PM)
Not to make it excute twice is most I am concerned now. The demo above runs well locally
but if I control it remotely from a web browser, it will get executed once again. After spending
quite some time, incidently I popup a dialog in the event processing, and then the second event doesnt show up.
This demo will show two different results when you select to popup dialog or not. Run it by
Tool->Web Publishing Tool...->Preview in Browser
So now I am confused with the Labview event processing. Maybe the popup dialog prevents the second event.
This post has been edited by kingson: Oct 29 2004, 08:54 AM
Attached File(s)
Tags
+Quote Post
kingson
post Oct 29 2004, 10:38 AM
Post #7
3 more posts to go!
Member
LV:7.1
Finanally I give up singaling value to generate an event. I turned to make the process as a user event, and generate this user event wherever its needed.
This works like the helper function in other language(pseudo code).
void onOKButton()
saveHelper()
void onSaveButton()
saveHelper()
void saveHelper()
//do the real work
You can say this can be done easily in subVI. But in my case, the subVI input parameters consume a lot space which I cant fit it in.
Attached File(s)
Tags
+Quote Post
Time is now: 22nd November 2008 - 02:06 AM
