Tags |
May 7 2007, 09:55 PM
Post
#1
![]() LV R&D Envoy NI ![]() Posts: 1226 Joined: 15-August 06 From: Austin, TX Member No.: 5877 Using LabVIEW Since:2000 LV:8.5.1 ,. ,.
My Gallery
This is the discussion topic for the wiki article: http://wiki.lavag.org/LabVIEW_configuration_file
-------------------- "A VI outside a class is a gun without a safety. Data outside a class is a target."
--- A message from LabVOOP R&D
| Ad |
Post
May 7 2007, 11:00 PM
Post
#2
My Gallery
I looked at the Easter Egg tokens. There are a few missing...
ICantBelieveItsNotButter=0x12345678 (works in LV6 and 6.1 only) ILuvLV20=TRUE (works in LV8.2 only) And one other... (which has actually been posted in various locations so I expect it to show up soon, but I'm not giving away all the toys...) -------------------- "A VI outside a class is a gun without a safety. Data outside a class is a target."
May 7 2007, 11:17 PM
Post
#3
![]() I'm a LAVA, not a fighter. V I Engineering, Inc. ![]() Posts: 3740 Joined: 13-October 03 From: Michigan, USA Member No.: 181 Using LabVIEW Since:1993 LV:8.5 ,. ,.
My Blog
ICantBelieveItsNotButter=0x12345678 (works in LV6 and 6.1 only) ILuvLV20=TRUE (works in LV8.2 only) Thanks Stephen (I'm glad you went to the most important section first -------------------- ![]()
May 8 2007, 03:05 PM
Post
#4
My Blog
I recently contacted Scott Hannahs of Info-LabVIEW fame about his LabVIEW Options page:
QUOTE (crelf @ May 07 2007, 01:00 PM) I've already migrated Brian Renken's settings across with his permission, and I'd really like to include yours, if that's okay with you. QUOTE (Scott Hannahs @ May 07 2007, 09:22 PM) Works for me. I have some automated scripts that try to strip out the options from the code for each version of LabVIEW and compare it to the previous one to figure new options and dropped options. -Scott Firstly: thank you so much Scott for allowing us to migrate his comprehensive list of LabVIEW Configuration File settings across to the LAVA wiki! Secondly: anyone got some time to do even a small part of the migrations? There's a lot there, and if we all chip in then it should take no time -------------------- ![]()
May 8 2007, 04:24 PM
Post
#5
Extremely Active Premium Member ![]() Posts: 430 Joined: 2-February 05 From: Southern California Member No.: 1519 Using LabVIEW Since:2004 LV:8.20 ,7.1.1 ,8.0.1
Secondly: anyone got some time to do even a small part of the migrations? There's a lot there, and if we all chip in then it should take no time How do you want to do this? If you know where it goes, put it in the right category, otherwise "unknown"? If you know what it does or is, explain it, else leave explanation blank? Or try it out ...
May 8 2007, 04:56 PM
Post
#6
My Blog
How do you want to do this? If you know where it goes, put it in the right category, otherwise "unknown"? If you know what it does or is, explain it, else leave explanation blank? Or try it out ... I think the first thing to do would be identify which ones are already in the wiki, and once you've confirmed that each of their details are correct (eg: whcih versions of LabVIEW support it) scratch it off the list. The settings are currently loosley categorised on the wiki under which page they appear on in the LabVIEW tools>options menu item (if they appear there at all). This is a very loose restriction, so you don't need to keep to it: just choose what you think is the most appropriate category and shove it in there. For things that you don't know, just put "Unkown". There's templates for a number of settings sorted by their datatypes here - as it's a wiki, if a datatype doesn't exist, I encourage you to create one and put a copy of it on the templates page. -------------------- ![]()
May 8 2007, 05:04 PM
Post
#7
I think the first thing to do would be identify which ones are already in the wiki, and once you've confirmed that each of their details are correct (eg: whcih versions of LabVIEW support it) scratch it off the list. The settings are currently loosley categorised on the wiki under which page they appear on in the LabVIEW tools>options menu item (if they appear there at all). This is a very loose restriction, so you don't need to keep to it: just choose what you think is the most appropriate category and shove it in there. For things that you don't know, just put "Unkown". There's templates for a number of settings sorted by their datatypes here - as it's a wiki, if a datatype doesn't exist, I encourage you to create one and put a copy of it on the templates page. The first thing then, is to create a huge list from Scott's site that can be checked against the wiki listings. Then the resultant list of unlisted list items could be divided out into reasonable chunks to add to the wiki. I will work on creating such a list, and will upload it to this discussion.
May 8 2007, 05:35 PM
Post
#8
My Blog
I will work on creating such a list, and will upload it to this discussion. -------------------- ![]()
May 8 2007, 09:55 PM
Post
#9
Extremely Active Member Posts: 269 Joined: 15-September 05 Member No.: 3014 Using LabVIEW Since:1998 LV:7.1.1 ,8.0.1 ,8.20
Just a couple of comments: Is it really necessary to color the datatype text? Frankly, I find it distracting (Blue text; it's a link. Oh, no it's not.) Also, is it a good idea to make the "operating system" values little icons? Yes, they're cute, but again, they decrease readability. I know I have to squint to really make out the Sun logo.
I just noticed that clicking on the Discussion button creates a thread in this forum, even if you don't actually create a post. Sorry for the clutter.
May 8 2007, 11:09 PM
Post
#10
Just a couple of comments: Is it really necessary to color the datatype text? Frankly, I find it distracting (Blue text; it's a link. Oh, no it's not.) Also, is it a good idea to make the "operating system" values little icons? Yes, they're cute, but again, they decrease readability. I know I have to squint to really make out the Sun logo. I agree on the datatype text coloring; it is unnecessary since the format is so readable anyway. The only reason that coloring would be helpful would be if you were scanning for keys by datatype -- highly unlikely. I will take the color off of the ones I am modifying (which is practically all of them, right now). I kinda like the OS glyphs. It doesn't take long to figure out what the icons mean, and after that I think it actually enhances the readability.
May 9 2007, 12:12 AM
Post
#11
![]() Confucius say: Crowded elevator always smell different to midget Admin ![]() Posts: 2363 Joined: 13-October 02 From: Planet Earth Member No.: 2 Using LabVIEW Since:1994 LV:8.5 ,8.2.1 ,7.1.1
My Blog
My Gallery
For things that you don't know, just put "Unkown". There's templates for a number of settings sorted by their datatypes here - as it's a wiki, if a datatype doesn't exist, I encourage you to create one and put a copy of it on the templates page. Actually, there are ways in the wiki to create real templates. See here. This simplifies repetative tasks and makes editing easier. This allows us to change the formatting of the entries later at any time. I'll create one for this.Just a couple of comments: Is it really necessary to color the datatype text? Like I said, this becomes easier when a template is createdI just noticed that clicking on the Discussion button creates a thread in this forum, even if you don't actually create a post. Sorry for the clutter. That's ok. If there's no response within a certain time to the post the thread gets deleted automatically.I suggest you all wait until I make a template before we get too far ahead. --------------------
May 9 2007, 01:55 AM
Post
#12
My Blog
Just a couple of comments: Is it really necessary to color the datatype text? It's not necessary - just like it's not necessary to have wires and control/indicator nodes of different colors (try programming in black and white
== autoWireMax == Example: autoWireMax=24 Description: Maximum distance between nodes for autowiring to be active Datatype: ![]() Permitted Values: 1 to 232 Default Value: 16 LabVIEW Versions: 6.x, 7.x, 8.x ... Also, is it a good idea to make the "operating system" values little icons? Yes, they're cute, but again, they decrease readability. I know I have to squint to really make out the Sun logo. That's kind of the point: most of our brains work in images much more efficiently than text, so now that your brain knows the logo, it will be able to recognise it much more quikly: you won't have to squint again - your brain learned it, and knows what it means now. All that aside, the beauty of the wiki is that if you feel strongly about it, go ahead and edit it. -------------------- ![]()
May 9 2007, 03:51 AM
Post
#13
