See here for the proper LabVIEW bug reporting procedure.
Tags |
May 7 2007, 07:43 PM
Post
#1
Extremely Active Premium Member ![]() Posts: 372 Joined: 6-August 04 From: Gurnee Illinois Member No.: 584 Using LabVIEW Since:1997 LV:8.5 ,8.2.1 ,7.1
For those that are using my icon editor or other home made editor using the lv_icon.vi option
There is a LabVIEW LOCKUP problem when trying to edit a sub pallet in the pallet editor. If you open the pallet editor. ![]() and then try to edit a sub pallet menu icon Nothing happens. The icon editor is running in the background but it is somehow being suppressed by the pallet editor. If you are using my editor or you have set the lv_icon.vi to a non modal state then there is a work around. for Windows press (CTRL-Space-x) and the editor should maximize and work normally. If the icon editor is set to a modal or floating state then you are out of luck. I was unable to get LabVIEW back without the 3 finger salute (CTRL-ALT-DELETE) By default the lv_icon.vit and Sample_lv_icon.vi are set to Dialog which is modal. ![]() So if you are going to create your own icon editor I would recommend setting the Windows appearance to default. I have reported this issue to NI. My thanks to tcplomp for finding this bug and the work around. -------------------- If you are interested in Time saving programming
tools created in LabVIEW then download my Icon Editor Updated July 7th 08 and my SubVI Helper Updated Jan 7th 08
| Ad |
Post
May 25 2007, 06:31 AM
Post
#2
![]() CCT It Premium Member ![]() Posts: 1331 Joined: 13-June 05 From: Woerden, Netherlands Member No.: 2399 Using LabVIEW Since:2001 LV:8.5.1 ,6.1 ,8.2.1
My Blog
My Gallery
Maybe an option, if you don't get a valid VI reference (path check or something) you could maximize the window yourself?
Ton --------------------
Jun 19 2007, 05:33 AM
Post
#3
My Blog
My Gallery
There is a LabVIEW LOCKUP problem when trying to edit a sub pallet in the pallet editor. The same issue arises when the icon is edited from the VI properties... Ton --------------------
Apr 10 2008, 04:41 PM
Post
#4
![]() LV R&D Envoy NI ![]() Posts: 1226 Joined: 15-August 06 From: Austin, TX Member No.: 5877 Using LabVIEW Since:2000 LV:8.5.1 ,. ,.
My Gallery
This bug is not fixed in 8.5.1. It will be fixed in the next full version of LabVIEW.
-------------------- "A VI outside a class is a gun without a safety. Data outside a class is a target."
--- A message from LabVOOP R&D
| Time is now: 22nd November 2008 - 07:07 AM |
