Check out our User Interface Code Repository Files or visit the LabVIEW Wiki User Interface Portal
Tags |
Oct 13 2004, 02:52 PM
Post
#1
5 more posts to go! Member Posts: 5 Joined: 13-October 04 From: Toronto, Canada Member No.: 804 LV:7.1 |
Hello,
I am creating a program that displays some simple data. It draws a pie-chart from 3 numeric values, and also displays a bunch of numbers, percentages, strings and so on. Everything up to there is fine. My problem involves taking what I have now (above) and making it into a single object. Since I want to display that data for several cases at once, it would be much easier to make it all into one repeatable code/function/object. Is there a way to group a bunch of objects on the front panel into a single object group, including respective code as well? Thanks in advance, -Phil
| Ad |
Post
Oct 14 2004, 05:27 AM
Post
#2
Extremely Active Member Posts: 391 Joined: 6-February 04 From: switzerland Member No.: 253 Using LabVIEW Since:1997 LV:7.1.1 ,6.1 ,.
QUOTE (pjama @ Oct 13 2004, 04:52 PM) Is there a way to group a bunch of objects on the front panel into a single object group, including respective code as well? The only way to do it in LabVIEW (from version 7.0 up) is to use a subpanel. Creating custom controls the way known from text-based languages is not yet possible. For further informations on subpanels look at the online help and the examples (menu: File>Find Examples...). Didier
Oct 14 2004, 02:18 PM
Post
#3
Thanks for the reply.
That way works pretty efficiently. However I am looking to run the same VI with several different values. I think the method you mentioned views the VI 'realtime', so it might not work with what I am doing. What I tried now, is capturing an image of the front panel for each case and displaying those images. This method has some sort of delay. I think taking images of the front panel might be a slow process. If you have any ideas, that'd be great. If not, I thank you again for your help thus far. -Phil
Oct 15 2004, 05:42 AM
Post
#4
![]() Very Active Member Posts: 116 Joined: 9-June 03 From: Perth, Western Australia Member No.: 111 Using LabVIEW Since:2006 LV:6.0.2 ,. ,.
QUOTE (didierj @ Oct 14 2004, 01:27 PM) The only way to do it in LabVIEW (from version 7.0 up) is to use a subpanel. Creating custom controls the way known from text-based languages is not yet possible. For further informations on subpanels look at the online help and the examples (menu: File>Find Examples...). But you could combine all your controls into a single cluster, change the code to a subvi with a cluster reference into it. In your application create several copies of the cluster and wire the cluster references to copies (as required) of the subvi. You can also modify/edit controls (use the spanner) quite extensively including removing parts or hiding bits of them (and including pictures) so perhaps a normal control could be modified too. For a pie chart might a guage work? cheers, Alex. -------------------- "Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the universe trying to build bigger and better idiots. So far, the universe is winning." Robert Cringley.
| Time is now: 22nd November 2008 - 04:22 AM |
