> Related links
Visit our LabVIEW Wiki Hardware Portal
Tags
> VISA USB, Problem opening more than 32 resources
Khodarev
post Oct 12 2004, 12:12 PM
Post #1
Enough LAVA to be dangerous
Member
LV:7.0
The situation is following: the program communicate with devices via usb interface. All is good until number of opened VISA resources is less than 32. When this limit is reached no more VISA's can be opened. So i can control only 32 devices at the time. Thus question is: is it possible to overcome this limit or not? Thank you in advance.
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
FLX
post Oct 12 2004, 04:29 PM
Post #2
Member
Using LabVIEW Since:2000
LV:7.1 ,8.0 ,7.0
ger_bavaria Nothing Selected Nothing Selected
QUOTE (Khodarev @ Oct 12 2004, 02:12 PM)
I found this FAQ at usb.org.
Maybe you running in a bandwidth limit. But I am just guessing.
Q6: How many USB peripherals can I connect at once?
A6: Technically, you can connect up to 127 individual USB peripherals at one time. Due to the fact that some devices reserve USB bandwidth, the practical maximum of devices is less than the theoretical maximum. However, PCI-USB add-in cards provide an independent USB bus to which even more peripherals can be connected.
Tags
+Quote Post
Time is now: 22nd November 2008 - 02:19 AM
