> Related links
Check out our XNodes Code Repository Files and visit our LabVIEW Wiki XNodes Portal
Tags
> Macro, Unknown External Node
Aitor Solar
post Apr 2 2007, 06:55 AM
Post #1
Member
Using LabVIEW Since:2000
LV:8.5 ,8.20 ,7.1.1
Spain spn_Madrid Nothing Selected
Does anybody knows what the Macro External Node is for? Is located in the <LVdir>/resource/Macro.llb/;DMacroizer (without extension). Unfortunately, this External Node and its subVIs are password-protected sad.gif . Presumably, given its name, it transforms something in a "macro" (whatever is that).
Saludos,
Aitor
This post has been edited by Aitor Solar: Apr 2 2007, 07:11 AM
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
AdamRofer
post Apr 2 2007, 07:24 PM
Post #2
More Active
Group Icon
WIKI Moderator
LV:8.5 ,6.1 ,7.1.1
United States us_california Nothing Selected
QUOTE (Aitor Solar @ Apr 1 2007, 10:55 PM) *
Saludos,
Aitor
I'm not sure how far back this goes (probably as far back as the Macroizer thing exists), but this VI appears to run in one instance. Apparently you can have an automatic "macroization" of any VI you want.
(This was tested in LabVIEW 8.20)
Step one: take a VI "xx.vi", rename it "xx.vim"
Step two: drag it onto the block diagram
Now this VI is a subVI, but note you cannot double click on it to enter the VI itself. I imagine that all the other problems that plague External Nodes in general exist here also, which might be why this behavior is not advertised. You can still access the VI through the VI Heirarchy, although if you copy the VI around the Block Diagram then you might not see it listed as a subVI of that VI (?!?!). I'm sure a lot more "interesting" results can be found...I really don't know what purpose this could have, but then again the locked VI might have some more stuff in it than just this.
Weird stuff.
Adam Rofer
Tags
+Quote Post
daal
post Apr 2 2007, 07:51 PM
Post #3
More Active
Premium Member
Using LabVIEW Since:1996
LV:8.5 ,8.6 ,.
Canada ca_quebec Nothing Selected
QUOTE (AdamRofer @ Apr 2 2007, 03:24 PM) *
Weird stuff.
Just a note to get this working, you need to enable external node with "ExternalNodesEnabled=True" in Labview.ini
And in my case it doesn't work with drag and drop from explorer, I need to use "Select a VI" from the palette
Dany
Tags
+Quote Post
AdamRofer
post Apr 2 2007, 07:57 PM
Post #4
More Active
Group Icon
WIKI Moderator
LV:8.5 ,6.1 ,7.1.1
QUOTE (DanyAllard @ Apr 2 2007, 11:51 AM) *
Dany
Thanks for the clarification Dany, I had that set from before so I forgot it was necessary. What happens when you drag the .vim from explorer onto a Block Diagram?
Adam Rofer
Tags
+Quote Post
daal
post Apr 2 2007, 08:47 PM
Post #5
More Active
Premium Member
LV:8.5 ,8.6 ,.
QUOTE (AdamRofer @ Apr 2 2007, 03:57 PM) *
Nothing happens. The VIM doesn't appear on the block diagram.
Tags
+Quote Post
Time is now: 22nd November 2008 - 02:28 AM
