> Related links
Tags
> how to capture the screen image?
cls9215
post Oct 6 2004, 06:24 PM
Post #1
Active
Member
LV:7.0
hello everybody:
I have a question about capture screen image in LabVIEW 7.0.
What vi is can be used to implement this function??
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Jimmy-Chen
post Oct 7 2004, 05:36 AM
Post #2
More Active
Member
LV:7.0
Taiwan
QUOTE (cls9215 @ Oct 7 2004, 02:24 AM)
hello everybody:
I have attached a VI(Saved in LabVIEW 7.0) in this topic.
This attachment code can help you capture and paste screen image on front panel.
Holp this can help you..
This post has been edited by Jimmy-Chen: Oct 7 2004, 05:44 AM
Best Regards
Jimmy Chen
Tags
+Quote Post
Minh Pham
post Sep 29 2008, 10:57 PM
Post #3
Member
Using LabVIEW Since:2006
LV:8.5.1 ,8.2.1 ,7.1
Australia Vietnam Nothing Selected
You can use the Invoke note to get the control/indicator image, also the whole front panel img if you want.
Minh Pham <><><>Stop Writing...Start Wiring<><><>
Tags
+Quote Post
giopper
post Oct 11 2008, 04:42 PM
Post #4
Active
Member
Using LabVIEW Since:1997
LV:8.20 ,8.0 ,7.1
Germany Italy Nothing Selected
QUOTE (cls9215 @ Oct 6 2004, 08:24 PM) *
hello everybody:
I attach a VI that I use to programmatically update the snapshot of
To run this VI you need the clipbrd.llb library.
The VI uses a call to Win32 API function "keybd_event" in user32.dll,
therefore it only works under Win32.
The "invoke node" method suggested before should be platform independent
but does not provide the entire screen.
Note:
the enumerator used to select the "print screen" key includes many other
(probably all) possible values to call the "keybd_event" function
(I found it somewhere but I don't remember where,
I apologize with the author for the lack of credits worshippy.gif )
I use LabVIEW 8.2 and I can down-convert the file only to 8.0.
I hope you can find a way to convert it down to LabVIEW 7.0
(volunteers?)
G
Attached File(s)
Tags
+Quote Post
Time is now: 22nd November 2008 - 02:30 AM
