> Related links
Check out the related Code Repository Files or visit the LabVIEW Wiki Internet Portal
Tags
> Hacking challenge, can you out-hack G hacker
Norm Kirchner
post Oct 6 2004, 05:12 PM
Post #1
Premium Member
Using LabVIEW Since:2000
LV:8.6 ,8.2.1 ,7.1.1
United States us_texas us_ohio My Gallery
For those of you w/ NI-Scope (those w/out, look on the device drivers CD)
If you notice on the splash screen, it has the powered by LabVIEW text.
Must be an EXE built in LV
c:\Program Files\IVI\Drivers\niScope
Challenge: lightbulb2.gif Can you get the main scope FP published over the web via the browser plugin?
here's some hints
you can turn on the web server via the exe's ini file
you can create the html necessary to view a vi using LabVIEW 7.0 web publishing tool
you can simply edit the vi that it points to by editing the two references within the html code.
So far I can get it to publish any of the exe's vi's w/ open front panels to the local machine, just not across the net. Looks like some kind of access problems.
SIDE NOTE: if you know how to fix the error "Remote panel server failed to send requested VI" I'll be forever grateful as this is the error that stops me. frusty.gif
G Hacker was here
This post has been edited by njkirchner: Oct 6 2004, 05:55 PM
Norman J. Kirchner Jr.
Automation Software Engineer
~,~ The Captain Was Here
Premium Blend
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Time is now: 22nd November 2008 - 06:54 AM
