Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags |
Sep 28 2004, 08:55 AM
Post
#1
![]() Very Active Member Posts: 216 Joined: 6-August 04 From: Sachsenheim D-74343 Germany Member No.: 582 LV:7.1.1
Hi!
If I like to scroll an object on the front panel e.g a button, and I will scroll it for only a millimeter, every time the object is scrolling with the "fence grid" from the blank front panel. Can I switch-off this function somehow? --------------------
| Ad |
Post
Sep 28 2004, 09:58 AM
Post
#2
Extremely Active Member Posts: 391 Joined: 6-February 04 From: switzerland Member No.: 253 Using LabVIEW Since:1997 LV:7.1.1 ,6.1 ,.
Do you mean this from the Tools->Options:
Disable "Enable panel grid alignment" and you have a front panel like "LV prior 7.0" Didier This post has been edited by didierj: Sep 28 2004, 10:00 AM
Sep 28 2004, 10:41 AM
Post
#3
QUOTE (didierj @ Sep 28 2004, 11:58 AM) Do you mean this from the Tools->Options: Disable "Enable panel grid alignment" and you have a front panel like "LV prior 7.0" Didier Yes, thanks Oh, the diagram have a grit, too Someone said you can enable the grid alignment with a shortcut, is this right? --------------------
Sep 28 2004, 12:57 PM
Post
#4
![]() Extremely Active Premium Member ![]() Posts: 375 Joined: 3-June 04 From: Trois-Rivières, Québec Member No.: 447 LV:7.1.1 ,. ,.
QUOTE (Sarah83 @ Sep 28 2004, 05:41 AM) Yes, thanks Oh, the diagram have a grit, too Someone said you can enable the grid alignment with a shortcut, is this right? While moving an object with grid on, hit "g" to toggle the grid. On a related note, use "a" to toggle wire autorouting on the diagram. --------------------
Sep 28 2004, 01:01 PM
Post
#5
QUOTE (jpdrolet @ Sep 28 2004, 02:57 PM) While moving an object with grid on, hit "g" to toggle the grid. On a related note, use "a" to toggle wire autorouting on the diagram. Thanks, this is for what I have searched. --------------------
Dec 31 2004, 12:04 AM
Post
#6
Instant Human, just add coffee Premium Member ![]() Posts: 889 Joined: 31-January 03 From: Waterford, CT USA Member No.: 45 Using LabVIEW Since:1992 LV:8.2.1 ,7.1 ,8.0.1
Has anyone else noticed that if you have several items spaced out just the way you want them, then you select them all and hit shift-up|down|left|right that as they move they INDIVIDUALLY snap to the gird, ruining your spacing? Most annoying.
-------------------- ************************************************************* "Always listen to the experts, they'll tell you what can't be done, and why. Then go do it." ~The Notebooks of Lazarus Long (by Robert Heinlein) *************************************************************
Dec 31 2004, 12:28 PM
Post
#7
Very Active Member Posts: 66 Joined: 15-October 04 From: Braunschweig Member No.: 833 Using LabVIEW Since:1993 LV:8.5 ,8.2.1 ,7.1
QUOTE (Michael Ashe @ Dec 31 2004, 02:04 AM) Has anyone else noticed that if you have several items spaced out just the way you want them, then you select them all and hit shift-up|down|left|right that as they move they INDIVIDUALLY snap to the gird, ruining your spacing? Most annoying. Haven't noticed that yet, but you can use the 'Group' feature from the 'Reorder' icon menu to group those items into one grouped item so they keep their spacing
Dec 31 2004, 01:55 PM
Post
#8
Yes, you can group, but that is a hassle if you are doing a lot of controls and moving stuff hither and yon while trying to lay out a new interface. Hmm, maybe I should submit a bug report.
Dec 31 2004, 08:01 PM
Post
#9
![]() Confucius say: Crowded elevator always smell different to midget Admin ![]() Posts: 2363 Joined: 13-October 02 From: Planet Earth Member No.: 2 Using LabVIEW Since:1994 LV:8.5 ,8.2.1 ,7.1.1
My Blog
My Gallery
QUOTE (Michael Ashe @ Dec 30 2004, 07:04 PM) Has anyone else noticed that if you have several items spaced out just the way you want them, then you select them all and hit shift-up|down|left|right that as they move they INDIVIDUALLY snap to the gird, ruining your spacing? Most annoying. I honestly have never used the Grid feature... . It's one of those things I always turn off. It's easier to align things relative to other controls rather than the grid. The grid is never in the right place that I want it to be. Most of the time, what looks natural to the eye does not conform to the grid. I realize this was a "most requested feature" from NI customers... I think I requested it as well --------------------
Jan 1 2005, 08:46 PM
Post
#10
QUOTE (Michael_Aivaliotis @ Dec 31 2004, 03:01 PM) ...I realize this was a "most requested feature" from NI customers... I think I requested it as well I think the grid is useful and has its place, but is also in need of a little more refinement before it is fully ready for prime time. Don't get me wrong, I am very glad NI implemented it and don't want to seem ungrateful. I just wish it had a few things "polished up" a bit. Perhaps in LV 8? -------------------- ************************************************************* "Always listen to the experts, they'll tell you what can't be done, and why. Then go do it." ~The Notebooks of Lazarus Long (by Robert Heinlein) *************************************************************
| Time is now: 22nd November 2008 - 06:13 AM |
