> Related links
Visit our LabVIEW Wiki LabVIEW Embedded Portal
Tags
2 Pages V   1 2 >
> any RIO/ FPGA users out there?, any RIO/ FPGA users out there?
mattnrel
post Sep 24 2004, 04:24 PM
Post #1
I've come back for more.
Member
LV:7.1
Are there any NI-RIO/FPGa users out there intested in discussing issues regarding this product?
matt hill
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
lavezza
post Sep 26 2004, 06:41 PM
Post #2
More Active
Member
Using LabVIEW Since:1996
LV:7.1.1 ,8.2.1 ,8.5
United States us_arizona us_florida
My cRIO system just shipped. I haven't done any FPGA programming yet, so I'm sure I'll have a lot to talk about in the coming weeks.
Tags
+Quote Post
Richard_Jennings
post Sep 28 2004, 03:32 AM
Post #3
Active
Member
Using LabVIEW Since:1991
LV:8.20 ,. ,.
us_texas Nothing Selected Nothing Selected
QUOTE (mattnrel @ Sep 24 2004, 08:24 AM)
matt hill
Hi Matt,
I'll repost our earlier email Q&A:
On Monday, September 27, 2004, at 10:05 AM, Hill, Matt wrote:
I'm acquiring PCM encoded streams and decoding them and sending the results to an RT target in real time. (The decoded data must be sent every 2.5 ms.) I'm trying to implement this routine as many times as I can on a single board. Basically I'm running out of space. I'm trying to determine what coding techniques are the most efficient. And there doesn't seem to be any way to isolate a bit of code and benchmark how much of the FPGA it occupies, so it's a difficult process.
>>Are you using single-cycle loops? They save a lot of space on the FPGA. Also watch out for the extra logic added by DIO arbitration.
Also, I'm trying to achieve high speed in my processing. In this area I can isolate code and test it, but benchmarking every available coding option is a bit tedious. It would be nice to have some general guidelines.
>>I use: single-cycle loops, pipelining, a digital line as a flag to verify and benchmark execution on a scope, avoid deeply nested logic, pipeline execution whenever possible.
Here are some examples of the questions I have:
1. It seems that the fastest way to send data from the FPGA to the RT target is to use a single IRQ on the FPGA, and then to post data word by word in a synchronous indicator. A synchronous indicator only updates once it has been read by the RT target. This technique is undocumented by NI, but one of their FPGA people showed it to me. I have found this to yield the highest transfer rates. It would be nice to understand why this is faster than sending the data in an array.
>>Under LabVIEW 7.0 the max data rate I could achieve was 4.2 Mbits/sec. I stored data into on-chip memory in one loop and read it out in another. The read-out loop would place the data into an array and flag an interrupt. I haven't tried this with the synchronous indicator - just found out about it Thursday. Interrupt driven transfers worked, but even on our monster machine, the CPU was bogged down handling interrupts.Forget about placing a graph on the front panel to display the data. My solution was to complain loudly to NI and route the byte-aligned data in parallel out the external connector to a 6534 DIO card. It's a horrible kludge but it gets the data in the PC.
2. I have problems where my FIFOs become unlinked with the program and return random data, but there is no error. This I believe this unlinking is a bug that occurs when you rename an FPGA vi or copy it. Has anyone else experienced this?
>> I haven't.
3. When storing data temporarily, I use FIFOs. These can be created as flip-flops, look up table or block memory. I would like to know the trade off between speed and FPGA space when comparing flip-flops to block memory.
>> Don't know
4. What is the penalty incurred for creating a subvi within FPGA code, both is terms of time and space?
>>I was told none. Everything is treated as one monilithic program by the compiler.
5. How does saving data in a shift register compare with saving it in a fifo?
>>Shift registers are mapped directly into logic gates. Not sure what overhead is added by fifos.
6. If I have a Boolean constant linked to 5 data sinks, should I separate this into five constants, thinking it will require less signal routing in the fpga, or link all sinks to the same constant?
>>Don't know, but I think this would be something the compiler would optimize.
7. If I send a U8 source into a U32 sink, I get the grey dot indicating a data type mismatch and Labview changes the data to the correct type for me. Is it more efficient to let labview perform the conversion, or should I insert a conversion node myself.
>>Don't know, but I would guess it's the same
8. To what lengths should I go to avoid using case structures?
>>I use them wherever I need them. I avoid deeply nested case structures, and try to minimize the number of cases. In the next issue of LabVIEW Technical Resources is a short article on LabVIEW FPGA that you might find interesting.
The FPGA code has its own rules and there seems to be very little documentation available to explain the optimal way of approaching common tasks. Any little tips and tricks that anyone has discovered would be very appreciated.
>>What are yours? Richard
Tags
+Quote Post
mattnrel
post Sep 28 2004, 04:11 PM
Post #4
Member
LV:7.1
I'm migrating this thread to LAVA from the Info-Labview list so that others can follow it...
matt
-----Original Message-----
From: Richard Jennings [mailto:Richard_Jennings@sandia.gov]
Sent: Monday, September 27, 2004 7:48 AM
To: Hill, Matt
Subject: Re: any NI-RIO/FPGA users out there interested in sharing
experiences?
Hi Matt,
What are you trying to do. I've been using LabVIEW FPGA for almost a year.
Richard
On Friday, September 24, 2004, at 09:37 AM, Hill, Matt wrote:
> Hi. I've been using NI's FPGA module (PXI-7831R Reconfigurable I/O)
> for 3 months now and it's definitely got it's own set of quirks.
> Anyone else out there using this product who's interested in
> discussing issues surrounding it?
> matt hill
> Denver, CO
> USA
Tags
+Quote Post
pzucchel
post Sep 29 2004, 07:12 AM
Post #5
Enough LAVA to be dangerous
Member
LV:7.1
As you know, Yes! i have some slides on our development that are going to be presented at the next NIDays in Lausanne. I will post the appropriate link in this forum, as soon as they will be available. I have made my own list of "hints" based on a few months of development on the system PXI7831R.
Regards
Piero
Tags
+Quote Post
Mobile-it
post Sep 20 2005, 10:09 AM
Post #6
Member
LV:7.1.1
Nothing Selected Nothing Selected Nothing Selected
QUOTE (lavezza @ Sep 26 2004, 08:41 PM) *
Hi!
I am learning the labview FPGA module (just starting at the moment and not much time)
Do you have some good starting points (please not the ni.com website!)
Thanks in advance.
Tags
+Quote Post
LV_FPGA_SE
post Nov 1 2005, 11:21 PM
Post #7
NI
Using LabVIEW Since:1993
LV:8.5.1 ,8.2.1 ,8.6
us_texas Canada Germany My Gallery
QUOTE (mattnrel @ Sep 28 2004, 10:11 AM) *
For LabVIEW to read an array from the FPGA VI front panel it needs to read every array element individually across the 32-bit PCI bus. In addition it needs to perform a few cycles of overhead operations before being able to retrieve the data so it will take a bit longer to read an array than reading the same number of element individually from a synchronous display indicator.
In LabVIEW 8 you should use DMA to transfer data from the FPGA to the host.
QUOTE
The Flip-Flop setting uses FPGA real estate to store the data in the FIFO; block memory uses the additional user memory on the FPGA. In most application you should use block memory to reduce the amount of FPGA real estate required by your VI.
QUOTE
In general there is no penalty for using a subVI. You do need to consider the difference between reentrant and non-reentrant. Reentrant will create multiple copies of the subVI on the FPGA, but they can run in parallel (faster, more space required). Non-reentrant only makes one copy of the VI that needs to be shared between multiple callers.
QUOTE
I would only use a shift register for a very small number of elements as it will use up FPGA real estate. FIFOs can be used between different loops and different subVIs. (their main purpose)
QUOTE
I have not tried this but I would think one constant should be fine.
QUOTE
It should not make a difference.
QUOTE
Case structures are very efficient on the FPGA and should be used where appropriate.
Christian L
NI Systems Engineering - Real-Time and Embedded Control Technologies
"I like my G code neat."
Tags
+Quote Post
yannis
post Sep 12 2006, 09:33 AM
Post #8
4 more posts to go!
Member
Using LabVIEW Since:2006
LV:8.0 ,. ,.
United Kingdom Romania Nothing Selected
I see that the last post is kind of old.
I am pretty new in LabView and i'm trying to use a cRIO and I have some isues to discuss. I just what to now if anyone's still wathing the topic.
Manny thanks,
Yannis
Tags
+Quote Post
Jeffrey Habets
post Sep 12 2006, 11:05 AM
Post #9
Premium Member
Using LabVIEW Since:1997
LV:8.20 ,8.0.1 ,7.1.1
Netherlands hol_limburg Netherlands Antilles
It's been a while since I did cRIO (it was in LV71), but I'm sure I'm not the only one reading here..
Just shoot..
QUOTE (yannis @ Sep 12 2006, 11:33 AM) *
Manny thanks,
Yannis
Greetings, Jeffrey
NI CLA & VIT
Tags
+Quote Post
yannis
post Sep 12 2006, 11:33 AM
Post #10
4 more posts to go!
Member
LV:8.0 ,. ,.
QUOTE (jeffreyhabets @ Sep 12 2006, 12:05 PM) *
Just shoot..
Hi Jeffrey,
My application is to log data on the host. I want to control the acquisition frequency too. The application I found in the FPGA courses are basic and for the one line handshaking one it appears to get blocked at one frame so I can't store the data in a file.
My question would be what shoud I use to transfer the values from the cRIO to the host takeing into account that my process takes 2 seconds an it is cyclic.
Regards
Yannis
Tags
+Quote Post
Jeffrey Habets
post Sep 22 2006, 03:07 PM
Post #11
Premium Member
QUOTE (yannis @ Sep 12 2006, 01:33 PM) *
Hi Jeffrey,
Regards
Yannis
I'm not sure if I understand what you mean exactly.. I take it that you just want to send data from your cRIO to your host and log it there. You are not controlling (e.g. sending setpoints) from host to cRIO are you?
What you probably should use here is an RT program on the cRIO controller that has one DAQ loop for your acquisition and another parallel loop for communication with the host. Now, if you are using LV8 or higher, the comm. with the host could be simply done with shared vars. Otherwise you probably want to implement some basic tcp/ip communication here or maybe use VI-Server.
Greetings, Jeffrey
NI CLA & VIT
Tags
+Quote Post
yannis
post Sep 22 2006, 03:29 PM
Post #12
4 more posts to go!
Member
LV:8.0 ,. ,.
Hi Jeffrey,
Indeed, that's what I want to do, only acquisition without any control. I did that and it works, and the data is tansmited to the host through a FIFO, if that can be cosiderated shared variables. By the way, can you indicate some good books for LabView and more than that, which will contain information about FPGA? I couldn' find to many tutorial in this field and for most of the books I can't see the summary.
The logged data contains a column that shows the increment of the loops. Does that increment coresponds to the value of the loop timer?
Many thanks,
Yannis
Tags
+Quote Post
vhdl
post Oct 16 2006, 04:13 PM
Post #13
Member
LV:8.0.1 ,. ,.
Belgium Nothing Selected Nothing Selected
I just wanted to tell you that I am also a LabVIEW cRIO user.
Tags
+Quote Post
mrak1
post Oct 16 2006, 06:43 PM
Post #14
2 more posts to go!
V I Engineering, Inc.
LV:8.20 ,8.0 ,7.1
United States Nothing Selected Nothing Selected
QUOTE (yannis @ Sep 22 2006, 11:29 AM) *
Be careful when using the loop timer from a while loop in LabVIEW FPGA. Depending on the speed of your FPGA VI, the iteration terminal could top out quickly. In other words, the iteration terminal counts from 0 to 2 E+9 but does NOT roll over. The loop will continue to iterate but the iteration terminal will always put out the same number after reaching 2 E+9.
Also, I have used DMA for fast data transfer from the FPGA to the cRIO RT controller. In my project, I was only interested in a particular amount of data following a digital trigger.
- the RT would have a separate state machine that indefinately waits for an interrupt from the FPGA
- FPGA would wait for a trigger ( analog trigger, digital, etc) coming from an input card
- Once the trigger was received => buffer the data in the DMA FIFO and generate an interrupt to the RT
- The RT state machine would then wake-up and begin emptying the DMA buffer ( empty until comp
