> Related links
Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags
> An Executable Debug tool
tims
post Sep 22 2004, 02:27 AM
Post #1
I want a LabVIEW icon under my name!
Member
LV:6.1
Here is a tool, that i have just created, that lets a developer, to externally control front panels that are imbedded in an executable. I thought other developers, who use lots of executables, would find this useful too.
Some Basic Instructions:
- To be able to display a VI's front panel, the application builder has to be forced, in the applications builder's 'VI Settings', to leave it in.
- 'Open' Button
This displays a dialog box which you use to select the actual executable you want to access.
- If the executable is already running and the correct Port is already open, when selected, the program immediately displays the exes displayable VI's.
- It the executable is not running, a dialog box is displayed that says it is waiting for the executable to be opened. The user can either open the executable manually or use the 'Open App' button.
- There are more combinations handled but i am not going to describe them all there.
- 'Refresh' Button
If VI's are loaded dynamically, the user will have to use the refresh button to update the displayed list.
- The rest of the UI is self explanatory.
Some Notes:
- This program modifies , VI Server port setting and host address, in the executables ini file, if these settings are important or you don't want this port left open keep a copy of the original ini file so it can be replaced.
- I have included the executable, which is compiled in LV6.1, i have never tested its use on a LV7.x executable and so i am including the code as well.
- To use the LabVIEW code it needs OpenG's file library.
If you have any questions let me know.
Tim
Attached File(s)
Attached File  Display_Files_in_Exe.zip ( 325.27K ) Number of downloads: 286
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Mike Ashe
post Dec 22 2004, 07:57 PM
Post #2
Instant Human, just add coffee
Premium Member
Using LabVIEW Since:1992
LV:8.2.1 ,7.1 ,8.0.1
United States us_connecticut us_washington
QUOTE (tims @ Sep 21 2004, 09:27 PM)
...snip...
Tim
Thanks Tim, nifty tool. Do you have any updates planned?
"Always listen to the experts, they'll tell you what can't be done, and why.
Then go do it."
~The Notebooks of Lazarus Long (by Robert Heinlein)
Tags
+Quote Post
Time is now: 22nd November 2008 - 02:16 AM
