> Bug reporting guidelines:
See here for the proper LabVIEW bug reporting procedure.
Tags
> Combo Box bugs (2)
Mellberg
post Jan 30 2007, 07:31 AM
Post #1
Active
Member
Using LabVIEW Since:1995
LV:8.2.1 ,7.1.1 ,.
Sweden swe_west_sweden swe_goetaland
Hi Folks,
Just want to report two LV-bugs I found. The bugs are reported to NI.
First, if a combo box is set to 'allow undefined strings', you can't write 'ABBA' if 'abba' already exists among the 'strings []', i.e. a pull down-menu item.
Second, if a combo box string-item (one of the pull down-menu items) contains a string that is 276 chars or more in length, this can either cause LabVIEW to pop up a 'crash' dialog or crash hard without any dialog.
These two bugs exists from, at least 7.0 to 8.2, as far as I know.
//Mellberg
This post has been edited by Mellberg: Jan 30 2007, 07:40 AM
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Mellberg
post Apr 2 2007, 12:59 PM
Post #2
Active
Member
LV:8.2.1 ,7.1.1 ,.
NI's 'BugID': 44J9B2E8
Tags
+Quote Post
VDB
post Apr 20 2007, 01:19 PM
Post #3
More Active
Member
Using LabVIEW Since:1997
LV:8.0 ,. ,.
Germany Netherlands Nothing Selected
One other strange thing I just found out:
It's not possible to enter a comma in a combo box???
Is there a good reason for this??
VDB
Tags
+Quote Post
Yair
post Apr 21 2007, 07:20 PM
Post #4
Extwemely Active
Premium Member
Using LabVIEW Since:2003
LV:8.6 ,7.0 ,.
Israel Nothing Selected Nothing Selected
QUOTE (VDB @ Apr 20 2007, 04:19 PM) *
Is this in 8.0?
I just tried it in versions both before and after 8.0 and I have no problem in typing a comma into a combo box.
Can you upload an example VI with detailed instructions?
More than meets the eye...
Tags
+Quote Post
VDB
post Apr 23 2007, 06:56 AM
Post #5
More Active
Member
LV:8.0 ,. ,.
QUOTE (yen @ Apr 21 2007, 09:20 PM) *
Is this in 8.0?
It's 8.2. Start LabVIEW, new VI, create a combobox (doesn't matter if modern, classic or system) and try to type a comma.
Pasting a comma works. Maybe it's because of the German Windows...
VDB
Tags
+Quote Post
JFM
post Apr 23 2007, 07:43 AM
Post #6
Member
LV:8.5 ,8.2.1 ,7.1.1
Sweden Nothing Selected Nothing Selected
QUOTE (VDB @ Apr 23 2007, 08:56 AM) *
VDB
I can reproduce this on WinXP (English).
Defining the list of allowable values works with commas, but entering commas into the Combo box don't.
I think you should report this to NI as a separate bug, and maybe start a new bug thread here at LAVA.
/J
Wired but not weird...
Tags
+Quote Post
Yair
post Apr 23 2007, 07:57 PM
Post #7
Extwemely Active
Premium Member
LV:8.6 ,7.0 ,.
QUOTE (VDB @ Apr 23 2007, 09:56 AM) *
Works fine in a version which is above 8.0, but is not 8.2 (or 8.2.1), so either this was fixed, or it could be an issue with locale settings. You could try setting your OS settings (Control Panel>>Regional and Language Options) to use the period instead of the comma and see if that changes it.
Tags
+Quote Post
VDB
post Apr 24 2007, 06:39 AM
Post #8
More Active
Member
LV:8.0 ,. ,.
QUOTE (yen @ Apr 23 2007, 09:57 PM) *
The behavior stays the same, I guess it's a bug..
VDB
Tags
+Quote Post
Mellberg
post Jun 14 2007, 06:29 AM
Post #9
Active
Member
LV:8.2.1 ,7.1.1 ,.
QUOTE (Mellberg @ Apr 2 2007, 02:59 PM) *
According to NI here in Sweden, this bug is solved in LV8.5.
//mellberg
Tags
+Quote Post
Time is now: 22nd November 2008 - 02:33 AM
