Tags |
Jan 19 2007, 11:01 PM
Post
#1
![]() Extremely Active Premium Member ![]() Posts: 588 Joined: 8-December 03 From: Dallas, Texas Member No.: 208 Using LabVIEW Since:2000 LV:8.6 ,8.2.1 ,7.1.1
My Gallery
I just did a search for "pie"
as in a search for one of my posts for pie chart. and got a no results found. the funny thin is the page that I was looking at previously had a post at the top that used the word pie numerous times. Does anyone else have the same difficulty searching for things here??? ~,~ -------------------- Norman J. Kirchner Jr.
Automation Software Engineer ~,~ The Captain Was Here Premium Blend ![]()
| Ad |
Post
Jan 20 2007, 03:21 AM
Post
#2
Very Active NI ![]() Posts: 213 Joined: 14-March 06 From: Austin, TX Member No.: 4441 Using LabVIEW Since:1999 LV:8.6 ,8.5 ,8.0
I have also had trouble getting results when searching on LAVA. But I figured it was just user error...
-D
Jan 20 2007, 04:24 PM
Post
#3
![]() Very Active Member Posts: 85 Joined: 13-August 03 From: Plymouth, Michigan Member No.: 151 Using LabVIEW Since:1993 LV:8.6 ,8.5.1 ,8.2.1
You can use google to seach lava using the "site:" option. I did the search "pie site:lavag.org" and I had 261 hits. A search of "pie njkirchner site:lavag.org" gets 8 hits including the one for which you were looking. Of couse it would be nice if LAVA's search worked better. Maybe if more of us became premium members this kind of improvement could be pushed.
as in a search for one of my posts for pie chart. and got a no results found. the funny thin is the page that I was looking at previously had a post at the top that used the word pie numerous times. </rant> Does anyone else have the same difficulty searching for things here??? ~,~ This post has been edited by gleichman: Jan 20 2007, 04:27 PM
Jan 20 2007, 04:58 PM
Post
#4
![]() I'm a LAVA, not a fighter. V I Engineering, Inc. ![]() Posts: 3740 Joined: 13-October 03 From: Michigan, USA Member No.: 181 Using LabVIEW Since:1993 LV:8.5 ,. ,.
My Blog
...Maybe if more of us became premium members this kind of improvement could be pushed. Maybe - why not try and find out? Maybe we could add the Google site search into our site somewhere instead of using the default engine? Although I agree that the Invision Power Board search function is limited, I don't think you can select which forum categories to search with the Google engine. I'm wonering if the issue is that "pie", being only a three letter word, is considered too short for the engine, whereas "piechart" returns meaningful data, as does "+pie* + chart". "pie*" also returns a crapload of threads, although "pie" is all over the place (like in the word "copied") so that's not much good either... -------------------- ![]()
Jan 20 2007, 04:59 PM
Post
#5
Certified Kool-Aid Kid Premium Member ![]() Posts: 1155 Joined: 6-December 02 From: Pittsburgh PA USA Member No.: 29 Using LabVIEW Since:1998 LV:7.1 ,. ,.
I have also had trouble getting results when searching on LAVA. But I figured it was just user error... -D Ditto. Ben
Jan 20 2007, 05:08 PM
Post
#6
![]() CCT It Premium Member ![]() Posts: 1331 Joined: 13-June 05 From: Woerden, Netherlands Member No.: 2399 Using LabVIEW Since:2001 LV:8.5.1 ,6.1 ,8.2.1
My Blog
My Gallery
Maybe we could add the Google site search into our site somewhere instead In the portal I have on the right pane as first item the "Search Lava" which uses Google if I enter pie I'll get 12 hits Ton --------------------
Jan 20 2007, 05:21 PM
Post
#7
My Blog
In the portal I have on the right pane as first item the "Search Lava" which uses Google Hey - that's pretty sweet -------------------- ![]()
Jan 21 2007, 12:05 AM
Post
#8
![]() Confucius say: Crowded elevator always smell different to midget Admin ![]() Posts: 2363 Joined: 13-October 02 From: Planet Earth Member No.: 2 Using LabVIEW Since:1994 LV:8.5 ,8.2.1 ,7.1.1
My Blog
My Gallery
I made some tweaks to the LAVA search engine. Can everyone try it out and let me know if it's better?
Jan 22 2007, 03:30 PM
Post
#9
My Gallery
Well the pie search is definetly more fruitful. Although it looks as though it still prioritizes words with 'pie' inside of them rather than the word ' pie ' alone.
Feb 26 2007, 05:36 PM
Post
#10
My Blog
I just did a search for "UML" and got nothing
Mar 30 2007, 09:19 PM
Post
#11
My Gallery
Well I may have to edit my original post. Nice job on the Google search.
BUT WAIT!! Does anyone else see this problem... when I click on a search result, no page pops up and I have no popup blockers on and the only way to see the clicked result is to shift click the result and a new window pops up. I'm using IE 6.0 and No I can not use firefox, I like activex too much. -Norm -------------------- Norman J. Kirchner Jr.
Mar 30 2007, 10:46 PM
Post
#12
My Blog
My Gallery
when I click on a search result, no page pops up and I have no popup blockers on and the only way to see the clicked result is to shift click the result and a new window pops up. I'm running IE7 and it's working fine. What I mean is that when I click on a link it opens it in the same browser window. What was your expectation? Also, IE7 has tabs so you can shift+middleclick to open it in a tab. By default the links open in the same window, what are you looking for?
I'm using IE 6.0 and No I can not use firefox, I like activex too much. --------------------
Apr 2 2007, 02:14 PM
Post
#13
My Gallery
Well I suppose I didn't make the problem clear.
Nothing happens when I click a link. nada. And I need to stay @ IE6. -------------------- Norman J. Kirchner Jr.
