Tags |
Jan 19 2007, 10:48 AM
Post
#1
Extremely Active Member Posts: 369 Joined: 24-August 06 Member No.: 5958 Using LabVIEW Since:1995 LV:8.5 ,8.2.1 ,7.1.1
I reported this bug december 2005, and just recently checked if it was still present in LabVIEW 8.2 (sorry I don't have a CAR for this one).
/J ------- The Problem.vi contains a pre-allocated array, that is populated by using a second array that is auto indexed in a FOR loop. The crash:
Solution: Change the dimension size input (Initialize array) from constant to control (this changes the type of the array wires)
LV7_1_1_Loop_bug.zip ( 14.16K )
Number of downloads: 95This post has been edited by JFM: Jan 19 2007, 11:04 AM -------------------- Wired but not weird...
| Ad |
Post
Jan 19 2007, 10:56 AM
Post
#2
<customize this text> Premium Member ![]() Posts: 1001 Joined: 9-April 04 From: Rotterdam Member No.: 349 Using LabVIEW Since:1992 LV:8.5.1 ,8.2.1 ,7.1.1
I reported this bug december 2005, and just recently checked if it was still present in LabVIEW 8.2 (sorry I don't have a CAR for this one). /J ------- The Problem.vi contains a pre-allocated array, that is populated by using a second array that is auto indexed in a FOR loop. The crash:
Number of downloads: 95The idea about FPGA might be interesting here. Earlier versions of LabVIEW did not support (or should I say use) fixed sized arrays although the typedescriptor explicitedly had this feature documented as long as the document about Typedescriptors exists. FPGA was to my knowledge the first environment really needing fixed size arrays so they pushed that. The particular problem you see also seems a bit like pains of the early attempts to get the constant folding optimization into LabVIEW. Not sure if the FPGA Toolkit adds this feature to the LabVIEW environment but I rather think that it is there independant of the existence of the FPGA Toolkit (but can't currently check as I have the FPGA Toolkit also installed). Rolf Kalbermatter
Jan 23 2007, 05:52 AM
Post
#3
CAR# 3SL9US00.
/J -------------------- Wired but not weird...
Jan 23 2007, 03:17 PM
Post
#4
![]() Very Active Member Posts: 165 Joined: 9-February 05 From: region Eindhoven, the Netherlands Member No.: 1555 Using LabVIEW Since:2008 LV:7.1.1 ,8.5.1 ,8.2.1
I've seen something related (most probably already reported too). It seems an array control or constant can remember that it was wired to a fixed size array. Then when you paste it somewhere else, the array wire does not allow to be changed size anymore. I was unable to remove the problem changing control/wire properties or by setting FPGA options off and restarting LV.
Workaround: create the wire/control again from scratch.
| Time is now: 22nd November 2008 - 05:18 AM |
