See here for the proper LabVIEW bug reporting procedure.
Tags |
Jan 14 2007, 10:03 PM
Post
#1
Changing the world, one VI at a time. JKI ![]() Posts: 1692 Joined: 22-October 02 From: San Francisco, CA Member No.: 17 Using LabVIEW Since:1995 LV:8.2.1 ,8.5 ,7.1.1
My Blog
My Gallery
[CAR 45E9BHJ1]
The "Wait on Notification from Multiple" function seems to have a bug in how it sets "notifiers out" in the case of a timeout. If an instance of "Wait on Notification from Multiple" is called successively (for example, in a loop), calls that timeout will pass out notifiers (in "notifiers out") from previous calls which did not timeout. I would expect "notifiers out" to be an empty array if the function times out. See "TEST - Wait on Notification from Multiple.vi" (attached) for an example that demonstrates this bug. In this example, "Wait on Notification from Multiple.vi" is called twice in a For Loop. On the first iteration a notification is successfully received and on the second iteration a timeout occurs. On the second (timeout) iteration, the value of "notifiers out" contains the notifiers that there fired on the first call. I would expect "notifiers out" to be an empty array if the function times out.
TEST___Wait_on_Notification_from_Multiple.vi ( 28.2K )
Number of downloads: 137--------------------
| Ad |
Post
Jan 15 2007, 01:59 AM
Post
#2
![]() LV R&D Envoy NI ![]() Posts: 1226 Joined: 15-August 06 From: Austin, TX Member No.: 5877 Using LabVIEW Since:2000 LV:8.5.1 ,. ,.
My Gallery
-------------------- "A VI outside a class is a gun without a safety. Data outside a class is a target."
--- A message from LabVOOP R&D
| Time is now: 22nd November 2008 - 06:52 AM |
