> Related links
Tags
> Audio signals
Sarah83
post Aug 26 2004, 09:41 AM
Post #1
Member
LV:7.1.1
Germany Nothing Selected Nothing Selected
is it possible to send some audio signals e.g. .wav from one port to an other port over LV?
Now I send only stings (numbers and text).
I like to test a signal, I will sent it from one port to an other port and after this I will compare both signals with a graph, but I don't know if I can sent .wav, too.
Regards, Sarah.
BMW E30, My Home
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Mikrobi
post Aug 26 2004, 10:17 AM
Post #2
Member
Using LabVIEW Since:1999
LV:5.0 ,8.0.1 ,8.20
Poland Nothing Selected Nothing Selected
QUOTE (Sarah83 @ Aug 26 2004, 04:41 AM)
If you use SI Read.vi (Sound Input) you will get sound arrays:
1D [I8] for mono 8-bit sound
1D [I16] for mono 16-bit sound
2D [I8] for mono 8-bit sound
2D [I16] for mono 16-bit sound
depend what configuration (SI Cinfig.vi) you use.
There is few method to send it as string:
1. from String subpalete: Array to Spreadsheet String
or
2. from Advanced>>Data Manipulation subpalett : function TypeCast :
- to input connect sound array from SI Read.vi
- to type connect empty string
output will be string
When you recieve string from serialport you sholul use just this method like when you send audio to serial.so
regards
Mikrobi
Tags
+Quote Post
Mikrobi
post Aug 26 2004, 11:22 AM
Post #3
Member
LV:5.0 ,8.0.1 ,8.20
QUOTE
or
When you recieve string from serialport you sholul use just this method like when you send audio to serial.so use Type Cast and connect to input string from serial port and to type input connect I8 or I16 array
regards
Mikrobi
I think, the Type Cast method will be the best method.
regards
Mikrobi
Tags
+Quote Post
Time is now: 22nd November 2008 - 02:16 AM
