Tags
> Bug reporting guidelines:
See here for the proper LabVIEW bug reporting procedure.
> Automatic type cast in build array causes crash/data corruption
CHorn
post Nov 27 2006, 11:49 PM
Post #1
I've come back for more.
Member
Using LabVIEW Since:2002
LV:8.0.1 ,7.1 ,6.1
Nothing Selected Nothing Selected Nothing Selected
When wiring variables of different types into a "build array" function, i.e. when automatic type casting is used, LabVIEW can crash completely or the resulting array can contain incorrect values.
The details depend on the exact configuration of the input for the build array function.
LV 8.01 and LabVIEW 8.20 (I discovered this using 8.01) seem to be affected on WinXP, Mac OSX (PPC) seems to be not affected.
This is a pretty nasty bug because instead of crashing it can result in incorrect numeric results and is then really hard to allocate because usually one does trust really essential basics of the programming language like automatic type casts.
P.S.: I posted this already in the NI forums but I thought this might be interesting...Attached File  TestBuildArrayCastCrash.vi ( 8.53K ) Number of downloads: 159
Attached File  TestBuildArrayCastIncorrectResult.vi ( 16.27K ) Number of downloads: 146
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Ton
post Nov 28 2006, 06:57 AM
Post #2
CCT It
Premium Member
Using LabVIEW Since:2001
LV:8.5.1 ,6.1 ,8.2.1
Netherlands hol_utrecht Nothing Selected My Blog My Gallery
It looks like the constant folding is doing very weird.
If you use execution highlighting, you will see that the for-loop will run just once...
But if I change the contant to a complex type (cxt/cdb/csg) it will run 100 times (I=99)
Extended and double will run as well, other file types not...
However if I forced a data change to I32 I saw that I went to 1 and then got this:
EDIT: what is the NI-forums discussion link?
Ton
This post has been edited by tcplomp: Nov 28 2006, 07:09 AM
Certified LabVIEW Developer
Shouldn't you be programming a Code Repository solution?
Tags
+Quote Post
CHorn
post Nov 28 2006, 08:28 AM
Post #3
Member
LV:8.0.1 ,7.1 ,6.1
QUOTE (tcplomp @ Nov 28 2006, 07:57 AM) *
My guess is that it's some kind of buffer overflow when allocating memory for the array that uses automatic type casts. This would explain why sometimes weird stuff happens and sometimes it crashes. In this example the loop gets "damaged".
QUOTE
http://forums.ni.com/ni/board/message?boar...ssage.id=217205
I think this is a very grave bug. Fortunately it is restricted to certain input configurations and to the combination of complex double with integers (all kinds) and singles. I didn't test very thoroughly though.
Christian
Tags
+Quote Post
Adam Kemp
post Nov 28 2006, 10:58 PM
Post #4
More Active
NI
Using LabVIEW Since:2003
LV:8.20 ,. ,.
United States Nothing Selected Nothing Selected
This was reported to R&D (#43Q7NJPT) for further investigation. Thanks for bringing it to our attention.
Tags
+Quote Post
neB
post Nov 29 2006, 01:42 PM
Post #5
Certified Kool-Aid Kid
Premium Member
Using LabVIEW Since:1998
LV:7.1 ,. ,.
United States Germany Nothing Selected
QUOTE (Adam Kemp @ Nov 28 2006, 05:58 PM) *
Adam,
Thank you very much for updating this thread!
Ben
Tags
+Quote Post
Collapse
> Similar Topics
    Topic Title Replies Topic Starter Views Last Action
No New Posts 9 YouMiss 5562 12th September 2007 - 06:18 PM
Last post by: TobyD
No New Posts   5 todd 2837 10th February 2004 - 06:59 PM
Last post by: TomWP
No New Posts   1 andy810915 2440 4th September 2003 - 04:30 AM
Last post by: Michael_Aivaliotis
No New Posts   3 DMiller 2463 9th July 2004 - 04:48 AM
Last post by: Jim Kring
Time is now: 6th October 2008 - 11:30 PM
