> Related links
Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags
> Saving Executable Vi's
Paul
post Jul 27 2004, 03:35 PM
Post #1
Active
Member
LV:7.0
I was wondering how to save a VI without a block diagram, only allowing the user to access the GUI.
Thank You
Paul F.
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Bryan
post Jul 27 2004, 05:03 PM
Post #2
Member
Using LabVIEW Since:1999
LV:7.1 ,8.0 ,8.20
us_pennsylvania us_california us_virginia
FILE >> SAVE WITH OPTIONS >> CHANGED VIs >> REMOVE DIAGRAMS
Make sure you keep a copy with the diagrams, if you don't you won't be able to make changes to it later.
Tags
+Quote Post
Michael_Aivaliot...
post Jul 28 2004, 01:18 AM
Post #3
Group Icon
Admin
Using LabVIEW Since:1994
LV:8.5 ,8.2.1 ,7.1.1
Hey, you can always add a password.
File>>VI Properties then select ->Security
Tags
+Quote Post
Bryan
post Jul 28 2004, 02:32 PM
Post #4
Member
LV:7.1 ,8.0 ,8.20
I would make it a long password too. Not too long ago I was browsing the NI Developer Zone and came across a VI that cracks password protected VIs via the brute force method. The longer the password was, the longer it took. I have a 10 or so character password that I apply to some of my VIs and I didn't have the patience to wait around long enough to see if it could crack them.
Tags
+Quote Post
Paul
post Jul 29 2004, 11:38 AM
Post #5
Active
Member
LV:7.0
Would saving without the block diagram prevent the user from accidently/intentionally rearanging the front panel icons, or is there a seperate lock command for those?
Thank You
Paul F.
Tags
+Quote Post
Bryan
post Jul 29 2004, 02:45 PM
Post #6
Member
LV:7.1 ,8.0 ,8.20
If you go to the very last button to the right on the tool bar, (the one that contains "move forward" "group" "ungroup" etc.) There's a selection called "Lock".
Just select all controls that you want to lock in place and go up and select "Lock" and there ya go. biggrin.gif
This post has been edited by Bryan: Jul 29 2004, 02:45 PM
Tags
+Quote Post
Michael_Aivaliot...
post Jul 29 2004, 02:53 PM
Post #7
Group Icon
Admin
QUOTE (Paul @ Jul 29 2004, 07:38 AM)
Actualy, password locking would prevent ANY editing including front panel changes.
QUOTE (Bryan @ Jul 29 2004, 10:45 AM)
Yes, this is a good option as well. It sounds like you are running LabVIEW code on a test system and your operators are aborting the VI or something. When you build your VI, you should design it so it automatically runs on startup and has all the menus and toolbars disabled. If you have to click the RUN button to execute your application then something is wrong.
Tags
+Quote Post
Bryan
post Jul 29 2004, 03:14 PM
Post #8
Member
LV:7.1 ,8.0 ,8.20
QUOTE (Michael Aivaliotis @ Jul 29 2004, 09:53 AM)
Really? I actually didn't know that. I've always done mine like you suggested below:
QUOTE
biggrin.gif That reassures me that I'm programming wisely. I've never had a whole lot of interaction with other LabVIEW programmers, I've learned all I know right now pretty much on my own and have worked independently with LabVIEW (most places I've worked, I have been the only LabVIEW programmer in my department).
It's great to get confirmation from seasoned LabVIEW programmers that I'm going down the right path. biggrin.gif
Tags
+Quote Post
Time is now: 8th January 2009 - 01:06 AM
