Check out our User Interface Code Repository Files or visit the LabVIEW Wiki User Interface Portal
Tags |
Jul 1 2004, 11:55 AM
Post
#1
One hit wonder! Member Posts: 1 Joined: 1-July 04 From: Upstate NY Member No.: 495 LV:7.1.1
wire wizards;
I need to figure out how to apply conditional formatting to a table of measurement results. In Excel,(am I allow to swear like that in here ;->) conditional formatting can be applied to table columns or rows such that if the contents of a particular cell is greater than a value, I can apply one condition (i.e. color the cell GREEN to indicate a 'PASS' condition), and if the contents of that cell are less than the same value, I can apply a different condition (i.e. color the same cell RED). This allows in a quick glance through *alot* of values to find any failing data. Is this something easily accomplished in LV? (BTW Win2K, LV7.0 PDS) Thanks in advance Rick
| Ad |
Post
Jul 1 2004, 03:45 PM
Post
#2
![]() Very Active Premium Member ![]() Posts: 148 Joined: 13-November 03 From: Kennesaw, GA USA Member No.: 195 Using LabVIEW Since:1997 LV:8.5 ,8.2.1 ,.
Rick,
Tables in LabVIEW are always an array of strings. There's no 'conditional formatting' as such, but the attached VI gives a trivial example of using property nodes on the table to recolor the cells at runtime. Hope This Helps. Dave
Attached File(s)
-------------------- David Boyd
Sr. Test Engineer Respironics
Aug 17 2004, 12:39 PM
Post
#3
One hit wonder! Member Posts: 1 Joined: 17-August 04 Member No.: 601 LV:7.1 |
Dave:
Do you know if there is a way to hide the column and rows separation in a table??? thank you Lucas
Aug 17 2004, 06:12 PM
Post
#4
![]() Very Active Member Posts: 61 Joined: 30-March 04 From: California Member No.: 333 LV:7.1
QUOTE (lucas_dili @ Aug 17 2004, 07:39 AM) Dave: Do you know if there is a way to hide the column and rows separation in a table??? thank you Lucas Lucas, By blending your table, and seperator with the same color( ie white) you can hide the seperator. Vince -------------------- Best Regards,
Vince
Aug 23 2004, 04:41 PM
Post
#5
QUOTE (lucas_dili @ Aug 17 2004, 07:39 AM) Dave: Do you know if there is a way to hide the column and rows separation in a table??? thank you Lucas Lucas, If I understand what you want, I don't think it's quite possible. The 'grid' of lines can be repainted any color you like (through the control editor), but if you've set background colors of cells (using the example I gave you), there will always be a perceptible line between adjacent cells painted different colors. If you change the FOREground colors of cells (meaning the text), and leave all the BACKgrounds the same, and paint the grid the same color as the background, then the grid lines will 'appear to disappear'. Did that make sense to anyone but me?? Dave -------------------- David Boyd
Sep 22 2004, 06:11 PM
Post
#6
More Active Member Posts: 25 Joined: 25-June 04 From: Pawcatuck, CT Member No.: 483 Using LabVIEW Since:2002 LV:7.1.1 ,6.1 ,.
I'm fairly new at creating nice interfaces so forgive me if this is too elementary.
I was just trying something like this in LabVIEW 6.1 in a table. The Active Cell cluster in the Property Node uses a cluster that is the Row number and Column number. Make a property node that has Active Cell and Cell Background Color in it. Once you know the row of the data that is out of range put that number in for the row and -2 in for the column in the Active Cell cluster and put the new color in the Cell Background Color (I use color box constants because they're easier for me). To color a column instead of a row, reverse the numbers. To color a whole table, use -2 in both numbers. This post has been edited by Jack Kelledes: Sep 22 2004, 06:11 PM
Dec 30 2004, 06:39 PM
Post
#7
Instant Human, just add coffee Premium Member ![]() Posts: 889 Joined: 31-January 03 From: Waterford, CT USA Member No.: 45 Using LabVIEW Since:1992 LV:8.2.1 ,7.1 ,8.0.1
Hmm, I should have scrolled down to the bottom of this topic before I coded up this example
Oh well, here is a simple example of using -2 to color alternating rows. Any more is an exercise left to the student... Cheers
Attached File(s)
-------------------- ************************************************************* "Always listen to the experts, they'll tell you what can't be done, and why. Then go do it." ~The Notebooks of Lazarus Long (by Robert Heinlein) *************************************************************
| Time is now: 8th January 2009 - 08:08 PM |
