See here for the proper LabVIEW bug reporting procedure.
Oct 10 2006, 12:41 AM
Post
#1
More Active Member Posts: 30 Joined: 3-July 03 From: Long Island, NY Member No.: 133 Using LabVIEW Since:1993 LV:8.20 ,. ,.
Has anyone seen this behavior before?
I was building a front panel for a subvi with a table and several enums on it. When I tried to save it, the asterisk that indicates changes would briefly flash off and then appear again, no matter how many times I tried to save it, PLUS one of the enum controls would occasionally dim (as if it had been changed and the changes had not yet been applied. But if I clicked on it, it would be okay again, PLUS the Run Arrow became broken (possibly because of the dim enum). When I clicked on the broken arrow, the vi started running and could not be stopped by the "Abort Execution" (stop sign) control or "ctrl-." Turning on Execution Highlighting showed nothing; looking at the hierarchy window showed no green execution arrows. I tried to close LabVIEW but got a neverending "Resetting vi" dialog. I finally just had to abort LabVIEW using the task manager and lose my table changes. This happened after a fresh reboot that I did, after noticing the save/asterisk problem the first time. Befuddling. At least it hasn't happened again, yet. -------------------- Jon Sweeney
Tags
| Ad |
Post
Tags
Nov 27 2006, 02:33 PM
Post
#2
I want a LabVIEW icon under my name! Member Posts: 3 Joined: 24-June 05 Member No.: 2470 LV:7.1
Has anyone seen this behavior before? I was building a front panel for a subvi with a table and several enums on it. When I tried to save it, the asterisk that indicates changes would briefly flash off and then appear again, no matter how many times I tried to save it, PLUS one of the enum controls would occasionally dim (as if it had been changed and the changes had not yet been applied. But if I clicked on it, it would be okay again, PLUS the Run Arrow became broken (possibly because of the dim enum). When I clicked on the broken arrow, the vi started running and could not be stopped by the "Abort Execution" (stop sign) control or "ctrl-." Turning on Execution Highlighting showed nothing; looking at the hierarchy window showed no green execution arrows. I tried to close LabVIEW but got a neverending "Resetting vi" dialog. I finally just had to abort LabVIEW using the task manager and lose my table changes. This happened after a fresh reboot that I did, after noticing the save/asterisk problem the first time. Befuddling. At least it hasn't happened again, yet. yes, i have seen at least the save/asterisk problem before, using 8.01 on linux. it appears after copying and renaming strict type definitions and the VI that contains these controls using a console. after loading the VI, the save/asterisk problem appears. a workaround that works for me, is to open the renamed type definition, change e,g the label and save it. the VI can be saved without any problems. hope, that helps. Tags
Nov 27 2006, 08:47 PM
Post
#3
![]() More Active NI ![]() Posts: 31 Joined: 28-September 06 Member No.: 6320 Using LabVIEW Since:2003 LV:8.20 ,. ,.
yes, i have seen at least the save/asterisk problem before, using 8.01 on linux. it appears after copying and renaming strict type definitions and the VI that contains these controls using a console. after loading the VI, the save/asterisk problem appears. a workaround that works for me, is to open the renamed type definition, change e,g the label and save it. the VI can be saved without any problems. hope, that helps. I could not reproduce that problem in either 8.0 or 8.2 in Linux using the steps you listed. This is what I tried: 1. New VI. 2. Drop numeric control. 3. Customize control. 4. Make the control a strict typedef 5. Apply changes. 6. Save both the control and the VI. 7. Close both. 8. Rename both 9. Open the VI. When I opened the VI, it searched for the control. If I chose the new name for the control, the VI was "good" (no broken arrow) and the VI had a doc mod (the asterisk). This is correct behavior. If I chose to ignore the control, then the VI was broken and had a doc mod (also correct). If you have another way to reproduce this problem every time then let me know. Tags
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
6 | kingson | 1765 | 29th October 2004 - 10:38 AM Last post by: kingson |
2 | pallen | 1214 | 10th November 2004 - 08:07 PM Last post by: pallen |
5 | becktho | 1479 | 25th February 2005 - 02:10 PM Last post by: Götz Becker |
1 | i2dx | 1040 | 9th January 2006 - 10:40 PM Last post by: atreding |
| Time is now: 6th October 2008 - 01:52 PM |
