See here for the proper LabVIEW bug reporting procedure.
Sep 14 2006, 05:20 PM
Post
#1
![]() Very Active Premium Member ![]() Posts: 141 Joined: 13-November 03 From: Kennesaw, GA USA Member No.: 195 Using LabVIEW Since:1997 LV:8.5 ,8.2.1 ,.
To demonstrate, do the following:
1) On a new VI, drop a table control from the 'List & Table' palette. 2) Popup and invoke the control editor on the table. 3) Show Parts Window. Change the width of the Y scrollbar from default (17) to 32 pixels. 4) Change the width of the frame from default (250) to 265 (to match the scrollbar change). 5) Apply changes, then dispose the control editor window. 6) Observe that the table has the 'fat' vertical scrollbar. Save and close the VI. 7) Reopen the VI - the scrollbar reverts to default width. I also tried saving the control as a strict typedef. The typedef retains the change when reopened, but instances of it on VI FPs don't reflect the modification. EDIT: The typedef does not retain the change either - I may have had it lurking on my clipboard when I tried it earlier. I wanted a 'fat' scrollbar for my touchscreen UI... My guess, FWIW: this is a bug related to the 'BigSavings' introduced in LV8 to reduce VI footprint on disk. What I'd really like is for someone to check whether this behavior remains in 8.20 - I haven't received my 'official' SSP CDs, so I don't have it installed. Best regards, Dave -------------------- David Boyd
Sr. Test Engineer Respironics Tags
| Ad |
Post
Tags
Sep 14 2006, 05:55 PM
Post
#2
![]() Active Member Posts: 15 Joined: 17-May 04 From: Dallas, TX Member No.: 415 Using LabVIEW Since:1992 LV:8.2.1 ,7.1 ,.
Dave,
Sorry to report that the behavior is unchanged in 8.20. I also tried saving the control as a strict typedef. The typedef retains the change when reopened, but instances of it on VI FPs don't reflect the modification. EDIT: The typedef does not retain the change either - I may have had it lurking on my clipboard when I tried it earlier. What I've seen (both in 8.0 and 8.20) is that the typedef does retain the customizations, but you only see them if you open the typedef while a containing VI is in memory. If you open only the typedef itself (or open it first) you won't see the customizations. Very weird... Regards, Scott Tags
Sep 14 2006, 06:34 PM
Post
#3
Dave, Sorry to report that the behavior is unchanged in 8.20. What I've seen (both in 8.0 and 8.20) is that the typedef does retain the customizations, but you only see them if you open the typedef while a containing VI is in memory. If you open only the typedef itself (or open it first) you won't see the customizations. Very weird... Regards, Scott Thanks, Scott, for confirming this... I neglected to add that I did observe this behavior when I checked a LabVIEW version *ahem* between 8 and 8.20. And just now I opened my typedef file and Hey Presto! there's my 'fat' scrollbar... so your observations about the order of opening TD vs. VI seem to be confirmed. If only there were a way to trick LabVIEW into using all the custom control's attributes when on the FP.... Dave -------------------- David Boyd
Sep 14 2006, 07:42 PM
Post
#4
![]() Very Active Member Posts: 75 Joined: 17-March 04 From: knoxville Tn. Member No.: 310 Using LabVIEW Since:2003 LV:8.20 ,8.0.1 ,7.1
Thanks, Scott, for confirming this... I neglected to add that I did observe this behavior when I checked a LabVIEW version *ahem* between 8 and 8.20. And just now I opened my typedef file and Hey Presto! there's my 'fat' scrollbar... so your observations about the order of opening TD vs. VI seem to be confirmed. If only there were a way to trick LabVIEW into using all the custom control's attributes when on the FP.... Dave I just figured out something else, If I do everything you say I can recreate what you see. But in LabVIEW 8.20 if you open a blank project and then do everything from inside the project the VI and controls are just fine. And they also are able to be built into an EXE OK. It also does not matter if the control is type def'd or not. Weird. This post has been edited by jhoskins: Sep 14 2006, 07:43 PM -------------------- One day I'm going to grow up and be somebody else, but until then I will just keep on being me.
Joe Tags
Sep 14 2006, 08:21 PM
Post
#5
But in LabVIEW 8.20 if you open a blank project and then do everything from inside the project the VI and controls are just fine. And they also are able to be built into an EXE OK. Right you are! Nice catch. It also works in 8.0. You don't need to start from scratch either. Just put the existing files into a project. Scott Tags
Sep 14 2006, 08:27 PM
Post
#6
Right you are! Nice catch. It also works in 8.0. You don't need to start from scratch either. Just put the existing files into a project. Scott Thanks, and right you are -------------------- One day I'm going to grow up and be somebody else, but until then I will just keep on being me.
Joe Tags
Sep 15 2006, 11:43 AM
Post
#7
I just figured out something else, If I do everything you say I can recreate what you see. But in LabVIEW 8.20 if you open a blank project and then do everything from inside the project the VI and controls are just fine. And they also are able to be built into an EXE OK. It also does not matter if the control is type def'd or not. Weird. So far I'm unable to get this to work - I recreated the customized control w/in a LabVIEW 8.0 project, along with a VI which uses it, but it still seems to show the default scrollbar appearance once reloaded. Sorry, but can you give me a step-by-step of how you did this workaround? Thanks so much to you and to Scott for knocking this around - this is why I love the online LabVIEW community so much. Best, Dave -------------------- David Boyd
Sep 15 2006, 12:32 PM
Post
#8
So far I'm unable to get this to work - I recreated the customized control w/in a LabVIEW 8.0 project, along with a VI which uses it, but it still seems to show the default scrollbar appearance once reloaded. Sorry, but can you give me a step-by-step of how you did this workaround? Thanks so much to you and to Scott for knocking this around - this is why I love the online LabVIEW community so much. Best, Dave First off just turning it into a project works great witout any little quirks, which I found investigating this morning. Steps I took: 8.20
It's funny how we can get Labview to do anything we want except for what we want it to do. -------------------- One day I'm going to grow up and be somebody else, but until then I will just keep on being me.
Joe Tags
Sep 18 2006, 12:45 AM
Post
#9
I would say that this is a BIG BUG. It's funny how we can get Labview to do anything we want except for what we want it to do. It's just a little wish - just one of those UI dress-ups you turn your attention to when the project has reached the 90%+ functional mark. Thanks again for all the experimentation on my behalf. Dave -------------------- David Boyd
Sep 18 2006, 12:35 PM
Post
#10
It's just a little wish - just one of those UI dress-ups you turn your attention to when the project has reached the 90%+ functional mark. Thanks again for all the experimentation on my behalf. Dave David, Are you sure that you dragged the control fromn the project onto the the front panel. Even when I do this with the tab control I get the same results. Which version of LabVIEW are you using. 8 or 8.2 or something in between for now. I have all. Let mw know so that I can try to help you troubleshoot this in the same version that you are using. -------------------- One day I'm going to grow up and be somebody else, but until then I will just keep on being me.
Joe Tags
Sep 19 2006, 03:53 AM
Post
#11
I wonder if this is not an 8.0 vs 8.0.1 issue in your case. I tried it in 8.0.1 and 8.2, but not 8.0. Though obviuosly still a bug, maybe it was "cleaned" up enough in 8.0.1 to get it to work in the project scenario. What ver are you using? Then again, I guess you could just wait 'til you get your 8.2 CD's. Regards, Scott Tags
Sep 25 2006, 03:23 AM
Post
#12
I wonder if this is not an 8.0 vs 8.0.1 issue in your case. I tried it in 8.0.1 and 8.2, but not 8.0. Though obviuosly still a bug, maybe it was "cleaned" up enough in 8.0.1 to get it to work in the project scenario. What ver are you using? Then again, I guess you could just wait 'til you get your 8.2 CD's. Regards, Scott Scott. I am using 8.0, never having dealt with the patch/masscomp situation. My official 8.2 CDs arrived this past Friday. I don't know if I'll migrate the present app development to 8.2 anytime soon. Thanks again for all the testing you did on my behalf. Eventually I'll get a bug report into NI for this. Dave -------------------- David Boyd
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
6 | Rick M | 1639 | 30th December 2004 - 06:39 PM Last post by: Michael Ashe |
0 | Mikrobi | 877 | 30th August 2004 - 01:23 PM Last post by: Mikrobi |
2 | sirzrx | 1207 | 11th November 2004 - 04:37 PM Last post by: sirzrx |
1 | Mikrobi | 1208 | 26th February 2005 - 09:16 AM Last post by: skywalkerxp |
| Time is now: 6th October 2008 - 01:54 PM |
