Check out our VI Scripting Code Repository Files and visit the LabVIEW Wiki VI Scripting article
Tags |
Jun 8 2004, 10:50 AM
Post
#1
![]() More Active Member Posts: 40 Joined: 16-April 04 Member No.: 356 LV:7.1 ,6.0 ,.
When I select the item from the ring constant, and LabVIEW puts it's value to New VI Object VI, then the vi which path connected to Owner path would create a new VI object depend on what I selected in the ring.
So I want to know what defines the item's vale. For example , When I select "Waveform Chart" from the ring, LabVIEW should put it's value----21010 to New VI Object VI, what decide the Waveform Chart's counterpart value? the control's Class ID? or type Description? or others?
| Ad |
Post
Jun 8 2004, 03:11 PM
Post
#2
![]() Extremely Active JKI ![]() Posts: 624 Joined: 19-June 03 From: Bay Area, CA (USA) Member No.: 121 Using LabVIEW Since:1998 LV:8.5.1 ,8.6 ,8.2.1
My Blog
Hi Keiran
First a reminder. Scripting is not support by NI and is not complete at this time. There are a lot of thing on can not do. Now, what exactly are you trying to do ? are you trying to set the value after you create the waveform chart ? Or are you trying to figure out where that 21010 come from ? or something else ? Sorry that I can not be more hopefull at that time. PJM --------------------
Jun 20 2004, 11:30 AM
Post
#3
Thanks PJM labview,^_^
| Time is now: 8th January 2009 - 08:01 PM |
